Hot Rods Let's have our own 85th anniversary event for the 40 ford...
Discussion in 'The Hokey Ass Message Board' started by Moriarity, Feb 10, 2015.
  1. 40ragtopdown
    40ragtopdown
  2. straykatkustoms
    straykatkustoms
  3. straykatkustoms
    straykatkustoms
    Lol! Many times I had seen the article but never took the time to read it until recently. Love that coupe.
    lothiandon1940 likes this.
  4. Dan Hay
    Dan Hay
    65984692368__61190D46-C104-484C-A889-1759A68F71AF.jpg 39 rear cropped.jpg Mick, since you posted that awesome 4 door, here's my 39 4 door, took these photos last night after dropping the jack from a dropped axle and dropped rear spring install. Excuse the dust and messy garage!
  5. straykatkustoms
    straykatkustoms
    My Jaw just hit the ground, That is soo kool! Going to be a kool cruiser.
  6. LOU WELLS
    LOU WELLS
    from IDAHO
  7. even I, as a kid, still cant believe that 1940 was 81 years ago. ww2 ended 76 years ago, my car was built 65 years ago. time seems to go really fast...
  8. neilswheels
    neilswheels
    from England
    I have the t shirt..
  9. neilswheels
    neilswheels
    from England
    06A4C71F-E6AF-4F7E-8345-4BA45E7469A3.jpeg Spotted this at the Goodwood Revival this year
  10. i.rant
    i.rant
    AA5EDA95-24EF-4E6E-ABAF-6C6CDB577C78.jpeg Got mine over to friends pole barn for winter storage this year, see ya in 4 months.:(
    Wife’s happy, :pher car in our garage and out of the weather.]
    PONTNAK123, MO_JUNK, 63fdsnr and 21 others like this.
  11. olscrounger
    olscrounger
    I have a couple as well
    Hamtown Al and lothiandon1940 like this.
  12. lothiandon1940
    lothiandon1940
    ............This is the shirt......framed.:D;)
  13. T&A Flathead
    T&A Flathead
    I’ve got a 40 4dr. Really love your look. Hoping to work on my stance over the long Wisconsin winter. Would you mind sharing more on your suspension drop and tire size. It is spot on IMO. Thanks.
  14. Dan Hay
    Dan Hay
    Thank you sir. It has a Posies spring front and rear, and a dropped axle from Nostalgia Sid in Oklahoma. He heat drops original axles. It also has Pete and Jakes Tube shocks in the front and tube shocks in the rear.
    The tires in the front are 600-16s. They are pretty big so I had to put an extra leaf in the front spring (from a spare spring I had laying around) to raise it back up so the tires would clear the fenders in turning. To be perfect I think it needs 550-16s and that leaf I put in taken out to drop it back down another 1/2". But these tires are good and new tires are expensive so I'm going to run it like this until these wear out. Tires in the rear are 750-16s.
  15. straykatkustoms
    straykatkustoms
  16. T&A Flathead
    T&A Flathead
    Thanks for the info. I was planning on sending a spare axle off to Sid to get that out of the way. Was contemplating using original springs with reversed eye lower instead of going with new. I have too many original springs laying around.
  17. Dan Hay
    Dan Hay
    An original spring will work just fine with a reversed main leaf and a few leaves removed. I don't know off hand how many leaves need removing, might have to experiment or ask someone who has done it to get the stance dialed in.
  18. T&A Flathead
    T&A Flathead
    I made room in my shop to park the 40 next to my project 48 convertible so I can fix a few things and give her an attitude adjustment over the winter. I don’t like undergoing 2 projects at once but I’m making an exception cause this 40 needs some love to make it more roadworthy for longer rides.
    MO_JUNK, DC40, 2bubbas and 11 others like this.
  19. olscrounger
    olscrounger
    Have done a few--usually end up with 8 leaves--just did one
  20. 40LUV
    40LUV
    from Mid Jersey
    Put away at a heated storage place for the Winter. They always look better under fluorescent light. 29552970-ce13-4cb6-b46c-adf20015386d.JPG
    MO_JUNK, hotrodharry2, DC40 and 20 others like this.
  21. straykatkustoms
    straykatkustoms
  22. straykatkustoms
    straykatkustoms
  23. Norris McCarty
    Norris McCarty
    Jim Bouchard, OL 55 and PONTNAK123 like this.
  24. '40s are kind of like*******, aren't they? If not, you'd better see your doctor!!
    The 39 guy likes this.
  25. straykatkustoms
    straykatkustoms
  26. straykatkustoms
    straykatkustoms
  27. kleiva
    kleiva
    from Norway
  28. Crusty Chevy
    Crusty Chevy
  29. southpaw-customs
    southpaw-customs
    The pickup got in the Sedalia newspaper from the 2021 Sedalia Christmas Parade.
  30. Weedburner 40
    Weedburner 40
