Hot Rods 34 Drag Truck 60's Style
Discussion in 'The Hokey Ass Message Board' started by Barbarian, Oct 26, 2021.
  1. brigrat
    brigrat
    from Wa.St.
    Post pics of the 6x2, if it has carbs!
  2. Barbarian
    Barbarian
    from New Jersey
    Posted them on page 2 but they didn't expand for some reason. These should get bigger. Original intake, drilled for 4 or 3 bolt carbs. Will be going with some 2" risers and frogmouth scoops.
    A3A21B49-EE85-492D-AF45-1638C9546356.jpeg 4BB6F884-7A1A-4F01-8786-797FC139A835.jpeg
  3. Jacksmith
    Jacksmith
    from Aridzona
    I vote 6 2's!
  4. sawbuck
    sawbuck
    from 06492 ct
    see if you can find a truck grill
    see if you can find a truck grill ....they repop 32 truck grills
  5. Barbarian
    Barbarian
    from New Jersey
    I had a super nice 32 commercial grille I sold to a buddy last year ugh!
    mad mikey, kidcampbell71 and loudbang like this.
  6. Barbarian
    Barbarian
    from New Jersey
    Progress a little slow but been making some other moves. Picked up a 303 olds for another build later on. Also say goodbye to the 6x2, someone paid handsomely for it.
    I’ll drop this as a teaser for what I'm picking up later on this week for this build:
    525C2CB0-114B-4C84-A7FE-9417176B66AD.jpeg 6B35A34E-FDCD-40DB-80A6-79FB74BEB36F.jpeg 617149CA-01DF-410C-AD47-15C92F9BD947.jpeg
  7. Barbarian
    Barbarian
    from New Jersey
    @sawbuck how much is yours channeled and chopped? Any pics of the inside you can share? A chop and shortened bed has been haunting my mind.
    loudbang and kidcampbell71 like this.
  8. sawbuck
    sawbuck
    from 06492 ct
    4 inch cop 5 inch channel ... its kinda tight.. i am 5 10 185 ....a big guy would have trouble ...i will look for some pics
    brEad and loudbang like this.
  9. Barbarian
    Barbarian
    from New Jersey
    thanks! Mine is channeled roughly 4-5”, been playing in photoshop by shortening the bed to 50” and a 4” chop. Looks proportionally right. Its a wild look for sure. This pickup has a 49" box and 5" chop, no channel and on a 32 frame/wheelbase so the box distance between the cab and fender is longer here.
  10. sawbuck
    sawbuck
    from 06492 ct
    i think ona 34 frame the distance from cab to fender is longer than a 32 ....that looks like a 34 frame ?
    lurker mick and loudbang like this.
  11. -Brent-
    -Brent-
    One of the things I love about the in-progress mock-up pics from post 61 is that if the final look/shape/proportions were to be taken from there - there's both restraint and it looks wild. It's a balancing act.
  12. Barbarian
    Barbarian
    from New Jersey
    10000% agree, in my mind the end goal is for it to look absolutely wild but never goofy. It shouldn’t be cartoony nor stray too far from as if it was actually built in the 60s. Hence the addition of early sbc intake and 471 setup
  13. Barbarian
    Barbarian
    from New Jersey
    Finally got the blower home. Now to figure out pulley sizes to underdrive if enough to get around 5lbs of boost so I don’t grenade the motor hahah. Pulleys I got with it are 32 and 34 tooth and the larger bottom pulley is 38 tooth. I believe I have to be in the -6% ratio range so either a new top or bottom pulley will be needed. I need a belt and a water pump pulley so maybe I can just find a whole kit.
    8FEED5FB-B221-4124-A12F-4E438C577235.jpeg 59A7205A-4014-4880-AEDA-B719FB4B6F87.jpeg 22AA3678-EF66-4D04-B2A0-162BEFA8AC67.jpeg
  14. wheeltramp brian
    wheeltramp brian
    Nice,I've been wanting a blower lately
    mad mikey and loudbang like this.
  15. Barbarian
    Barbarian
    from New Jersey
    You'll never be happy until you get one. Trust me, I know. I tried to justify the 6x2 cool factor vs. the blower. Then you hear a blower and you say F the 6x2, give me the whine! Then your mind goes in the direction of, you can always throw a 6x2 on top of a blower.....
    AHotRod, mad mikey, brEad and 3 others like this.
  16. Barbarian
    Barbarian
    from New Jersey
    Had to measure for pulleys / couldn’t help myself
    C2B99F78-0382-44D3-BB15-89C443D80A01.jpeg 80394710-8647-41AC-8DF6-3AE07FFAF999.jpeg
    apparently this rear cover is super rare. Cleaned it up a bit real quick
    E311F5E4-68B5-4EE4-A24D-55FC0FD8922E.jpeg BC4DB201-CBF6-47F8-8E28-F15C45DAEDFF.jpeg
    Blower and manifold were polished at some point, nice and smooth just dirty with some pits. Will polish it as is, will go with the vibe of the truck. One side was hit with some polish and a wheel no sanding. Other was how it started.
    B4BA5039-22ED-415D-9108-DBC1A84BAC79.jpeg CF798183-596D-42F9-82E0-2EB05979D036.jpeg
  17. Barbarian
    Barbarian
    from New Jersey
    Painted the short block and valve cover tops today. Gold flake it is! Little hard to get a good pic but the valve covers really show it off.
    3EE202F3-27B2-4D29-B028-02D6BD23A5BD.jpeg 67218FED-E811-4617-B5F4-3E1C846B1AA2.jpeg B9E591DE-93AF-4726-BC98-BB1CE63007E7.jpeg CE94B853-ACFD-4384-BDAB-750F1B065BC5.jpeg
  18. Barbarian
    Barbarian
    from New Jersey
    Nothin like flake and fresh clear !
  19. Barbarian
    Barbarian
    from New Jersey
    Well I couldn’t help rough mocking it up after it dried and tearing off the tape. I also have a chrome water pump and pulley, finned fuel pump block off plate. Deciding between Rochesters or strombergs before I buy a top plate but you get the idea. Was debating painting the aluminum heads gold but I’m liking it. The meticulous side of me wants to remove the ‘proma**’ engraving from the heads.
    A75BED66-B338-46FC-8834-F720890C1C0D.jpeg 5C5F35AE-CBEF-4861-81E8-B99E42803969.jpeg 2FEB3E68-7165-4FCB-8D40-66295B8B172E.jpeg 287D21C3-D30F-4CBB-B29E-63DAA021115C.jpeg
  20. winr
    winr
    from Texas
    Perfect ... I think
  21. error404
    error404
    from CA
    Just Gary, loudbang and kidcampbell71 like this.
  22. Barbarian
    Barbarian
    from New Jersey
    Yea I've thought about it a lot. It's lightly engraved, any suggestions how to remove it? I've been thinking of just hitting it with some sandpaper but once you start I have to finish. They are very nice so it kind of pains me to start messing with.
    Just Gary, mad mikey and loudbang like this.
  23. Jacksmith
    Jacksmith
    from Aridzona
    Belt sander and a careful touch...
  24. kidcampbell71
    kidcampbell71
    Thought @402BOSSMAN may have changed the appearance of some late aluminum heads, of his ??
    .. but really can't remember. So there's that.
  25. X38
    X38
    Paint them.
  26. -Brent-
    -Brent-
  27. Barbarian
    Barbarian
    from New Jersey
    One more little detail thats been bugging me off the list. Came off super easy, 240 grit removed the text. Then sanded all the way up to 2000, polished and done. One on the left isn’t scratched, some leftover polish compound I guess I missed until I looked at the pic.
    E7B0C390-AF8A-464F-B2B7-9FD1EAB27044.jpeg F4AB7483-3AB8-4F46-9BD1-E458B7241C33.jpeg C8E78ABB-D152-41A8-9E9F-D434E9974986.jpeg
    mad mikey, Just Gary, Chucky and 6 others like this.
  28. -Brent-
    -Brent-
    Looks great!
  29. loudbang
    Worth the effort :)
    brady1929 likes this.
  30. Barbarian
    Barbarian
    from New Jersey
    agreed! I left the rear of the heads for now. Took all of 30 minutes. Nice “lunch break”
