Projects 1967 C Dragster Build
Discussion in 'Traditional Hot Rods' started by Scott Mize, Jul 30, 2021.
  1. Scott Mize
    Scott Mize
    160” George Wepplo SEMA tag 43 with Creitz 16” spoke wheels. 260 cu in Dodge Hemi with hilborn fuel injection. Frame found with no changes except some tabs added.
    I’ll try and post photos as the build comes along.
  2. Scott Mize
    Scott Mize
    Dodge Hemi
  3. chris bozic
    chris bozic
    from Pittsburgh
    Nice! What were the rules for C/D back in '67? Sometime in the late 70's I think C/D became inline wedge heads only. I have a modern day (somewhat, last run in 2012) C/D in my garage that I hope to run again someday. Just finished reading the Warren Johnson book. I believe Wepplo built WJ's vega that ran pro-stock and B/A.
    Chris
    AB Normal, Andamo and loudbang like this.
  4. Scott Mize
    Scott Mize
    C/D was for small cu in and lite weight cars. D/D was for flatheads in-line 6 and other combos. C/D couldn’t exceed about 4 lbs per cubic in. Max cu in was 300. Here’s a photo 67 C/D my dad had with Desoto
  5. Very cool!
    Deuces, loudbang and Scott Mize like this.
  6. Very cool, please keep us posted!
  7. chris bozic
    chris bozic
    from Pittsburgh
    Very nice! Looking forward to seeing more of this project. Today c/d is 4.5lbs/cid minimum and runs 6.7s @ just under 200mph.
  8. Scott Mize
    Scott Mize
    Today cleaned up all the added tabs and brackets that weren’t original. Found 3-4 places that will need to be tig welded but no major issues.
  9. Nice project. Keep posting progress.
    Scott Mize and loudbang like this.
  10. loudbang
    Good start. I will be following along. :)
    Scott Mize and Deuces like this.
  11. Nice find, keep us posted.
  12. Scott Mize likes this.
  13. Scott Mize
    Scott Mize
    Right now we don’t plan on making updates to the frame. It is very hard to find a car that hasn’t been modified. It will be a cackle car.
    SS327, FinnishFireball and loudbang like this.
  14. Scott Mize
    Scott Mize
    First time on flat trailer.
  15. Scott Mize
    Scott Mize
    Disassembled front end for cleaning
    saltflats and loudbang like this.
  16. AHotRod
    AHotRod
    I love old drag cars
  17. Scott Mize
    Scott Mize
    Finished disassembly of front end. Cleaned 4 layers of paint off front axle. Cleaned and cleared the axle. Not going to Rechrome from axle.
    AHotRod, 427 sleeper, Chucky and 3 others like this.
  18. Scott Mize
    Scott Mize
    Finally have the engine mounted with handmade motor mounts and firewall.
  19. Scott Mize
    Scott Mize
    Also made a oil filter bracket to clear frame and supply remote oil filter
    Fordors and loudbang like this.
  20. Scott Mize
    Scott Mize
    Have the engine/powerglide mounted with handmade firewall and handmade motor mounts. Dad is doing all the Fab work and he is 85 years old.
    Fordors, winr, thehazguy and 6 others like this.
  21. Scott Mize
    Scott Mize
    Making a lot of headway. Engine goes in next week.
  22. A lot of the old frames are rusted from the inside out. I think as a cackle car you are ok but when hauling the car, build a support to keep the frame from flexing. You might avoid a surprise. :)
    FinnishFireball likes this.
  23. Scott Mize
    Scott Mize
    Thanks for the info. I was lucky that the frame has always been stored inside. We did as thorough a check that could be done including some repair work on two very small cracks. All paint was stripped off with a razor blade and not one area with rust was noted. We will cackle and maybe do a burnout but otherwise it won’t make full passes
  24. Scott Mize
    Scott Mize
    Engine is in with just a little wiring and plumbing.
    Fordors, slayer, winr and 2 others like this.
  25. lippy
    lippy
    from Ks
    Subscribed. Since its a cackle car. Maybe a bit of percentage to make some fumes? Lippy
    SS327 and 427 sleeper like this.
  26. Scott Mize
    Scott Mize
    Well we’ve finally got the dragster finished and cackled it at the Wally Parks Nostalgia Nationals this past weekend. Some photos. IMG_8952.jpeg IMG_8911.jpeg IMG_8951.jpeg IMG_8952.jpeg IMG_2749.jpeg
    DrJekyllMrHyde, SS327, slayer and 7 others like this.
