Holley vs edelbrock what's the performance advantage?
Discussion in 'The Hokey Ass Message Board' started by rocketsled59, Mar 10, 2014.
  1. ClayMart
    ClayMart
    *#%&@*#&!!! ******! Now it's not working for me either! :mad: Must be too much fuel pressure. Or maybe it's an ignition problem... :rolleyes:
    Deuces likes this.
  2. Atwater Mike
    Atwater Mike
    ...Or it's a HOLLEY! LOL
  3. BSL409
    BSL409
    I would take the Quick fuel over Holley any day I use them both for my race & street cars,
    Tickety Boo and Deuces like this.
  4. BashingTin
    BashingTin
  5. ClayMart
    ClayMart
    OK. Now this is just starting to get on my nerves! LOL! I know I've posted links like this before without this problem.
    I got good results with a site search. 94 hits searching all open threads for "holley vs edelbrock". Copied the URL and pasted it in my reply. Hit "submit reply" to save, click the link and it works the first few time I try it. Then the link goes dead.
    Let's see how long your Google link lasts. Of course you're not linking it back to a page on this site... Maybe that has something to do with it.
  6. OneBad56
    OneBad56
    On the street, I don't think there is an advantage of one vs. the other.
    If there is, its very minor.
    One of the reasons I like the Holley, is the fact they have an industrial look to them, as such just look plain mean and ready to go. The dual quad Holley's look better on my engine.
    Oh, and I don't like the manufacturers name in plain sight like Edelbrock.
    I'm not a brand name pusher.
  7. rocketsled59
    rocketsled59
    Hey 56, ya know its funny you say that about holleys looking right , not so bad lookin at an edelbrock I guess as long as intake isn't too high but the edelbrock looks silly as hell on top of my pro products high rise. And with a velocity stack!?Just not right... As long as it works I suppose
    409 tell me more about your quick fuel. I've been looking at them and I see they are in bowling green KY. In holleys back yard. Maybe some old holley guys figured they could improve on the holley design??
    Deuces likes this.
  8. stimpy
    stimpy
    I know Jon , but I am talking dominator size specs and drag car usage ... you know 200 cfm makes a big difference on time slips with Big CID .
  9. carbking
    carbking
    True, but if one is good, two might be better! ;)
    Of course, sometimes the rules require only a single carb. And if you need more than 950, you would be correct about the dominators.
    I still would prefer multiples.
    Jon.
  10. desotot
    desotot
    A holley is like a toilet, when you give it the royal flush it will get you to the other end of the 1/4 quickly.
    An afb or avs is good if carbs scare you and all you want to do is get from pointA to pointB.
    I think.
  11. robyyo
    robyyo
    from Orange CA
    I use them both, and I like them both. I've noticed over the years that more guys who are just getting into hot rodding use the Edelbrock.
  12. stimpy
    stimpy
    one is enough thanks , the Dominator gives me fits at times as it is , plus I haven't seen too many tunnel rams or high plenum dual carb manifolds that work as well as the set up we have ( team G ) , plus the fact he has a steel hood and doesn't want to cut it or scoop it . next step is a 4 bbl air valve( apx 1300 cfm and mechanical fuel injection ..
    my preference is neither , I am a Rochester q-jet sicko , not the E-brock kind either . but I have rebuilt and tuned Holleys for others and also tuned the AFB clones . to me they are all gas mixers the AFB IMO is more street freindly ,
  13. 1971BB427
    1971BB427
    from Oregon
    That's funny! Must have really bad gas in Texas! My cars sit for months during the winter and when fired up they run great. And I've got double the possible problems with dual Holley carbs on both cars!
  14. GregCon
    GregCon
    from Houston
    It's also erroneous. Carter/Edelbrocks are far more prone to fuel issues given they have their fuel wells/jets located at the lowest point in the carb. Plus, they are ***embled by prisoners and children in sweathouses.
  15. A carb guru I used to know (RIP) told me if you want street manners and fuel economy, use a Q-jet. Good WOT performance, Holley is the only answer. Said the AFB was just a 'middlin' carb and could be made to run 'decent'. Pointed out that by the late 60s, almost all US manufacturers factory-installed Holley carbs on their performance motors and it wasn't about which was cheaper....
    I've run both, and can personally say that I've never had a Holley I couldn't make run right (***uming the CFM match was at least close). Can't say that about Edelbrocks....
    Deuces likes this.
  16. So true. It's like the Pepsi challenge.
  17. rramjet
    rramjet
    I prefer my aluminum manifolds in silver rather than the gold they become when running a Holley.
    nikwho likes this.
  18. carbking
    carbking
    No comment on the edelbrock, as I don't know.
    Carter AFB's have both primary and secondary jets located 0.375 inch above the low point in the bowl. This was an engineered feature of the AFB to help prevent issues from trash caused by lazy users who didn't change fuel filters at recommended intervals. Perhaps you should take the top off of an AFB and check your data.
    Your second statement does not deserve a reply.
    Jon.
  19. indyjps
    indyjps
    Easy. Are you drag racing/Holley, or driving/AFB style. Either one can be set up for either activity depending on your patience and skill level.
    Deuces likes this.
  20. gimpyshotrods
    gimpyshotrods
    There is no way for anybody to ***ign your comments any credibility after that last counter-factual, inflammatory comment.
    You have made an allegation of criminal activity, without presenting any evidence.
  21. arkiehotrods
    arkiehotrods
    According to Edelbrock's website, and this is a quote,
    "Every Edelbrock carburetor is manufactured in the USA"
    I wonder what their lawyers might do if they saw your comment.
    gimpyshotrods likes this.
  22. my47buicksuper
    my47buicksuper
    from sunny fl.
    My oppinon if your raceing get a Holley but for ever day driveing the edelbrock are much better there way more reliable ,if you want both get a Holley and leave it in the trunk (with a rebuild kit) when you want to go to the track rebuild it and through it on but there nothing but a pain in the *** always needing adjustments or rebuild hope you got your awnser
  23. OLDSMAN
    OLDSMAN
    If you are driving an all out race car, the Holley would be the way to go. It is much more tuneable than the AFB, however they need constant tun ing on the street. The AFB, AVS Edelbrock carbs are based on older carter designs, and need little tuning to keep them running right. For street this is the better choice. I have a Q-jet on my convrt, but only because that was the carb on the 455 Olds engine I put in the car. If I was using a Chevy engine it would have an Edelbrock on it. The 42 Chevy I am building for my daughter will have an Edelbrock on it. Just my 2 cents worth
  24. nikwho
    nikwho
    I'll chime in, since I mess with both. Both are quite capable. Every Edelbrock that I have bought has run better out of the box than any Holley or Quick Fuel carb that I have bought. Not super problematic if you are going to put energy into tuning.
    Additionally, every one step in jet sizes for Edelbrock is equal to roughly 4 Holley jet sizes. So, I've always regarded Edelbrock's as a "set it and forget it" type of carb. I've always had Edelbrock's fire up more readily hot and cold, than with a Holley or Quick Fuel carb. I find that with more tuning and effort I can get a Holley to run at least as well, and most often, even better than an Edelbrock.
    If you want to tinker with it, get a Holley. If you want to make some quick adjustments and simply enjoy driving your weekend street car, I'd use an Edelbrock. That said, I have two vehicles currently with Edelbrocks (1405 & 1406), one with an old school Holley 3310 770cfm, one with a Quick Fuel Q-Series 850cfm billet carb, and one with a Quick Fuel Brawler Series 650 cfm carb.
    With either carb, I would suggest getting a tuning/jet kit, a vacuum gauge, and putting a little effort into tuning it. I also reccomend keeping notes, so you know what setup you have in your carb, and know which way to go if you're going to run it at a different elevation, or need to change the tune for where you live.
    Also, if you travel a lot to different elevations, I prefer an Edelbrock for a quick change in jets and needles. You don't have to drain them like you do a Holley.
    Either way, you can get your car running great with either carb. They're just different. You'll always have people in each camp, that think that the other is complete garbage. If that were true, there would not be so many loyalists to one or the other.
  25. The Rat Patrol
    The Rat Patrol
    from Australia
    Truck load of sense in this reply.
  26. RmK57
    RmK57
    Quick fuels are fantastic carbs. Very tune able and the metering is pretty spot on provided you ordered the correct one for your combo. They use pretty much the same gaskets and hard parts as a Holley.
    Deuces likes this.
  27. willys36
    willys36
    I'll comment too. For the street, it really doesn't make any difference performance-wise. Biggest problem is guys buy way too big a carb for their engines. Most, and I mean 99.99%, 4bbl carbs run as 2-bbl carbs the vast majority of the time. Companies started making the spreadbore design to meet emissions and fuel economy standards and still have performance potnetial 'cause street engies just don't need that volume. They all convert liquid fuel to g***eous fuel just fine. Liquids and solids don't burn. Only g***es burn.
    That brings it down to what carb is easiest to set up/has 'the look' and everyone has a favorite. To me a Carter/Edelbrock gives a plain vanilla - copyrod vibe. You know, the rod with a 3**-something SBC, Edelbrock valve covers, Edelbrock air cleaner, Edelbrock front cover, Edelbrock pan, Edelbrock thermostat housing, Edelbrock headers, Yawning viewability. A Holley just has that 'maybe there is something radical inside there' look. Beauty is in the eye of the beholder.
    I bought my Holley 3bbl in '64 when they first came out. Going to college and couldn't afford it but had to have one! It was WAY, WAY too big for my stock 331 hemi (dumber than dumb teenager). I fixed that by machinging up some primary bore inserts from aliminum (same size as a 600cfm Holley), down-sized the jets a bunch and put in the strongest seconday spring they make and got a really strong stoplight bandit. I put a microswitch on the secondary lever with a light on the dash to program when the secondaries open. They rarely do.
    I used a Rochester Quadrajet on my grandson's '59 Elky with a 307 SBC and I love it. Very easy to tune and best of both economy/performance worlds.
    To make a short story long, pick whatever you like, tune it in with some pro help if necessary, and enjoy!
  28. carbking
    carbking
    7 year old thread.
    Jon.
    loudbang, Deuces and gimpyshotrods like this.
  29. willys36
    willys36
    so?
  30. carbking
    carbking
    So there is still no consensus of opinion. Still "my dog is bigger than your dog". ;)
    Jon.
    wvenfield, loudbang, Deuces and 2 others like this.
