Holley vs edelbrock what's the performance advantage?
Discussion in 'The Hokey Ass Message Board' started by rocketsled59, Mar 10, 2014.
  1. Truck64
    Truck64
    from Ioway
    No no no... Jon ... My dog's better than your dog. (Because he gets Ken-L-Ration)
    loudbang, Deuces and carbking like this.
  2. gimpyshotrods
    gimpyshotrods
    Just to stir the pot.
    I just took the pair of Carters off of my blower, and put on a set of Holleys.
    Those have a total of eight fuel injectors.
  3. willys36
    willys36
    Yes a topic like this is like answering the question, "how long is a string?"
    Just Gary, carbking and Deuces like this.
  4. F-ONE
    F-ONE
    from Alabama
    Holley...Edlebrock...Carter...Quadrajet...for that matter 2300s..2100s...2-jets...94s...97s...Zeniths...Rochester 1Vs...1100s
    I think it's time for a song.o_O
    Deuces likes this.
  5. carbking
    carbking
    OK, I will play this game.
    Best:
    Environmentalist carburetor - Muir
    Street - Woodward
    Racing celebrity - Winfield
    Graceful - Swan, Eagle
    Anonymous - Smith
    Band - Reo
    Insect - Monarch
    Animal - Buffalo
    Ancient - Maximus
    President - Johnson, Kennedy, Jackson
    Scientific - Franklin
    Relaxing - Breeze
    Evil - Demon
    And finally Performance - Wheeler/Schebler (company founded by 2 of the 4 responsible for the Indy 500)
    Jon.
    Deuces and F-ONE like this.
  6. F-ONE
    F-ONE
    from Alabama
    Jon, you forgot the "Urban Legend".... You know, That mystery carburetor that was on your good friend's cousin's that knew a guy's grandpaw's 1974 Cadillac that got 45 miles to the gallon with incredible performance. The one that was mysteriously removed by the dealer when granpaw bragged about the mileage at the first oil change.
    Deuces likes this.
  7. 19Fordy
    19Fordy
  8. Bad Bob
    Bad Bob
    from O.C. Baby
    Performance= Holley
    Reliability and "Plug n Play"= Edelbrock......IMO.
    All the rest of the ********...Why do you guys do this?
  9. 57 Fargo
    57 Fargo
    Jon got me hooked on genuine Carter’s. I now have several….
  10. 55blacktie
    55blacktie
    As long as you're happy with what you have, the brand shouldn't be important. I have a Holley 4150 Street Avenger 570 that will be replacing a Holley 4000 "Teapot." Ford Performance Parts equips their $11,000 Windsor crate engines with the Street Avenger 570, and the recommend the same for crate engines without carbs. On the other hand, a family member has had a 600 cfm Edelbrock on his 65 Mustang for years/w no complaints.
  11. jimmy six
    jimmy six
    The best comparison is the proper use of an air cleaner. Cover what ever you choose. The bigger the better. Holley, Carter, Edelbrock, Summit, WCFB, Rochester, etc… a stainless or chrome cake cover which already has a center hole works wonders.
    Personally if what you have doesn’t leak even from the top screws your already miles a head…
    Deuces likes this.
  12. '49 Ford Coupe
    '49 Ford Coupe
    Ok, I'll bite..... Years ago I bought a 14' flatbottom boat with a 350 sbc/v-drive with a Carter AFB on it. NEVER did I ever have to take it apart and do anything to it for over 10 years. It would start and run every time I punched the start ****on. A few years later, I built a '69 Camaro with a 454 in it and put a Holley (the best I remember) that had the paper gaskets on the bowls. If I didn't start it up every couple of weeks, the bowls would leak gas all over the engine. I know, the gaskets these days are better, but not back in the '70's. So, when I built The Judge with a 383 Stroker, I elected to use an Edelbrock, since it's a descendent of the Carter. Out of the box, it was a bit "chunky", so I put a digital AFR gauge on it and noted the various readings under various loading conditions. Then I got the "tuning chart" from Edelbrock, and selected "correction" rods and jets, installed them with only taking the top off to install, and since then, the performance has been PERFECT, even when going up hill in cold weather in 4th gear lockup (700R4 with Jag XJS 2.88 ratio - rear end at 1,200 rpm and also with an AIR GAP manifold that everybody seems to think is junk. No, it's not a drag car, but a schizophrenic luxury car, that can change personality with a flip of a switch and push on the throttle. I LOVE the performance. Over 10,000 miles on her since I finished the build and not a single hiccup .....Shoot me....
    gimpyshotrods and Blues4U like this.
  13. Johnny Gee
    Johnny Gee
    from Downey, Ca
    What's in someones head.
    Deuces likes this.
  14. Mud, rocks, cobwebs.... but I vote Rochester.
    jimmy six likes this.
  15. The older I get, the more I realize that the stock carburetor is best most of the time. There are a few exceptions, the Motorcraft/Autolite 4300/4350 comes to mind. I’ve used both Edelbrock and Holley, and for me it would boil down to intended use. Drag Racing, Holley, simply due to parts availability. Street, Quadrajet is my first choice on a Chevy, but have a great running 600 Holley on my 351. Whatever makes you happy.
    Deuces and Blues4U like this.
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
    jimmy six and Deuces like this.
  17. 2OLD2FAST
    2OLD2FAST
    from illinois
    Oh , Rochester ...
    Deuces likes this.
  18. I have never reallyt had a problem with Holleys leaking. Maybe it has to do with my penchant of keeping my carb in good shape. LOL
    I have a personal preferance for holley carbs. They are easy to work on and perform well. I do like a carter AFB, I got an idea that you are not actually going to find an Edelbrock AFB as they have not made new AFBs in decades. Most of the Edelbrock carbs that I have run across are actually Weber carbs.
    If you are willing to put the time in either carb can be made to perform.
    Deuces and bowie like this.
  19. 6sally6
    6sally6
    I like and use the Edelbrock carb and intake.
    They just look sorta outta place on a Ford engine.
    Tuning one can't get much simpler
    6sally6
    '49 Ford Coupe and Just Gary like this.
