Metal Prep
Discussion in 'The Hokey Ass Message Board' started by CGkidd, Aug 19, 2006.
  1. CGkidd
    CGkidd
    I have a axle that I am looking at powder coating. The problem is it has stome rough spots in it where the old brackets were grinded off. What can I do to fill in the grind markings to make it smooth prior to powder coating?
    Eric
  2. Bondoboy
    Bondoboy
    eastwood company sells "bondo" that is for that exact purpose.
  3. For filling nicks and gouges I use a product called "Lab-metal" by a company named "Alvin". It can take the 400 degree heat required when powder coating.
    I believe they have a website.
  4. scottybaccus
    scottybaccus
    If you wanna get serious, fill with bronze rod using a tig or lead using a torch.
  5. CGkidd
    CGkidd
    Does the Lab-metal cause any change in color of the powder coating? How does the Lab-metal hold up to the prep from the powder coater?
  6. oddbald
    oddbald
    from NH
  7. I haven't noticed any color change. My powder coat guy had sandblasted my wheels before I applied the Lab-metal and then blasted them again (lightly) after that to make sure he had uniform surfaces (tooth) throughout.
  8. CGkidd
    CGkidd
    Thanks for the responses.
    Eric
  9. GomezGarage
    GomezGarage
    I work at a metal shop and we use JB Weld. Never had a problem.
