Technical Soda Blasting
Discussion in 'The Hokey Ass Message Board' started by lake_harley, Dec 2, 2021.
  1. lake_harley
    lake_harley
    I want to clean a Powerglide transmission case and have been thinking of using Armex baking soda. Never used it before and wonder if it will work in my syphon-type beadblast cabinet? Normally I use gl*** bead, but in this case I'm thinking soda blasting would be better since it's water soluble and I could be more ***ured that it's flushed out of all of the p***ages by pressure washing after blasting. Thoughts...experience?
    Thanks
    Lynn
  2. alchemy
    alchemy
    Sounds like it would work if you can be sure the cabinet is truly empty before you add the soda.
    Coca-Cola actually has acid in it. How about blasting with Coke to clean up the aluminum? Set up the power washer in the driveway with all the flat Coke from the back of the pantry. o_O
    warhorseracing likes this.
  3. AccurateMike
    AccurateMike
    Lynn, I use soda in a Jeggs 81502 benchtop cabinet. Soda doesn't flow like sand or gl***. Add a little humidity and it gets worse. If you fill the bottom of the cabinet, a funnel forms around the pick-up tube and you stop siphoning. I tilt and shake the cabinet. After a while, you end up lifting the grate and piling up media over the inlet. Lately, I made a hopper by cutting a gallon bottle to fit the "funnel" bottom of the cabinet. It is cut just below the grating. I put the media in a box off to one side and fill the hopper as I go. It's a bunch easier/faster than opening up and clearing off the grating to lift it to push the soda around. I thought about a ********. It's not going to move the stuff right to left, only down the sides of the cabinet's hopper. Still could use one as the funnel still forms in my bottle hopper. I'm glad I didn't bolt the cabinet down. I end up doing some lifting and dropping to keep moving forward. I have a great big bag of dessicant that came out of an Italian injection molding machine. (I actually probably have 50 of them). I put this in the cabinet and then dry it out in the oven about once a week. That helps the flow a bunch. I've done about 30 carbs with mine. Still on the initial ~10# fill. The 35# bag will last a while. It works great ! I flush the soda out with warm water in an ultrasonic cleaner. Good luck ! Mike
  4. lake_harley
    lake_harley
    alchemy.....I just wouldn't be able to bring myself to clean it with Coke. I'm a die-hard Pepsi guy.:D
    Mike....Thanks for the info and how it worked in your experience. That's exactly the type of helpful info I hoped to get. Sounds like a 50# bag of Armex would last me forever, or until it turned into a solid clump, whichever comes first!
    Thanks
    Lynn
  5. blowby
    blowby
    from Nicasio Ca
    Screenshot 2021-12-02 7.46.12 AM.png I use it in one of these and just wash it off the driveway when done. Takes a lot longer on heavy corrosion than gl*** beads.
    loudbang and AccurateMike like this.
  6. AccurateMike
    AccurateMike
    No doubt. It is great for blowing the carbon and stains off of carbs and aluminum stuff. Not worth **** on rusty steel or good paint on anything. Any greasy residue is always tough. I have the benchtop cabinet in my ba*****t, where I do carbs. I just built a new barn, I think I need a bigger cabinet with some cobby abrasive in it, for everything else. I have room out there. Pressure fed is really the answer for any blaster. Every siphon/gravity cabinet I have ever used needed at least some love to keep working. Soda is just a little more sticky. Mike
  7. You want one of these…
    Harbor freight sells them cheap and they don’t cost a lot!
  8. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Well there is always the local car wash.............
  9. kabinenroller
    kabinenroller
    I used soda to clean a distributor, it worked good except that I did outside in the gr*** next to my shop. The soda killed the gr***!
  10. You are a Man after my own heart. Pepsi is the world’s greatest liquid!
  11. VOETOM
    VOETOM
    from MO
    I had my local sand blaster do my 1962 Powerglide case and he used a mild process with small grit sand and stayed a ways away from it. It came out fine and his method easily stripped all the previous rebuilder's paint off and did no damage whatsoever. I then cleaned it at the local car wash before building it.
  12. Walnut shells make aluminum look great
  13. lostone
    lostone
    from kansas
    Me too!! At times though I add a little bourbon in the cup first to kill any germs that might be lurking there!!
