Technical ***December 2021 Banger Meet Thread - Run Run Rudolph***
Discussion in 'Traditional Hot Rods' started by Jiminy, Nov 30, 2021.
  1. Phil Damon
    Phil Damon
    from San Diego
    Checking in. Got my block back from machine shop yesterday. Next, mock-up for fit check.
  2. gsnort
    gsnort
    How does one become a member of this group?
    winduptoy likes this.
  3. Jiminy
    Jiminy
    At the top of the page, click on Watch Thread and choose if you want Email notifications or not. There is a new banger thread each month (notice of a new thread will get posted) and you will have to renew your watch thread choices for each month.
    There is also a thread called Motor - Banger Thread Links which is a directory to some interesting banger threads as well as most prior monthly banger threads.
    trikejunkie, winduptoy and Dannerr like this.
  4. V4F
    V4F
    from middle ca.
    6 11/16
  5. denis4x4
    denis4x4
    from Colorado
    It’s about 6” or so and is part of the pan gasket set. I soak mine in oil for a day and then use a razor blade to trim it after I’ve stuffed into the groove
    Old Dawg likes this.
  6. Midnight Rider
    Midnight Rider
    from Australia
    Checking in. It's now summer here and Covid nearly gone, so we can go out again.
    Jet96, winduptoy, Dannerr and 3 others like this.
  7. callcoy
    callcoy
    HARDTIMESAINIT
    Sorry I didn't get back to you sooner but a medical condition has had me laid up for several weeks. Another visit tomorrow with the heart people and I should be ready to go. I did Contact Donovan and they told me what they told you, no new production of the Alum. Model D 4 Banger. By the way I wasn't trying to start a rumor I was just asking if anyone had heard if production was going to be resumed.
    Old Dawg and winduptoy like this.
  8. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Out and about yesterday in mine... Runs better the more it gets driven...
    Winter time is prime driving time here in the south.. Summer, not so much....
  9. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Checking in from San Francisco. Got to run some holiday errands in the roadster today and I couldn't be happier about it. Photo by my friend Xander Cesari.
  10. This came up on Facebook a few hours ago. Dave Wheeler is a good and reasonable fabricator!
    For Sale. 30-31 Model A Ford Ch***is with late 20s Chevy engine and trans. The engine and trans were mounted in the ch***is years ago. I’m told it was driven up until 5 years ago, the body was removed recently. I put some gas in the carbs and it ran and sounded good. The carbs need a rebuild, plugs wires, etc. but the engine seems good. Frame needs some repairs and it needs a wishbone mount. $1,800. Located in Atascadero Ca.
    =AZXaGgyloXbz9T-MpTfUya_5gy5BnBkU3hZRzTj9cIFP9-3dc4VbbX0VTFspZ0xQ4t4PpUVO6B-KPl6vU14WRCiYympD9Vv5AyNoUTq-GwRLG42YrNJAVA9CSCEnQaCVjOYzr3yYR-ihwepJsfgd8W5awu1aUHEKiHLi4HNDFaj4j_clglzVt7G_Wsm3FFaoXgc&__tn__=*bH-R']
    =AZXaGgyloXbz9T-MpTfUya_5gy5BnBkU3hZRzTj9cIFP9-3dc4VbbX0VTFspZ0xQ4t4PpUVO6B-KPl6vU14WRCiYympD9Vv5AyNoUTq-GwRLG42YrNJAVA9CSCEnQaCVjOYzr3yYR-ihwepJsfgd8W5awu1aUHEKiHLi4HNDFaj4j_clglzVt7G_Wsm3FFaoXgc&__tn__=*bH-R']+4
    4545
    12 Comments
    1 Share
    Like
    Comment
    Share
    12 Comments
    View 2 more comments
    All comments
    BeaverMatt and Dannerr like this.
  11. jim1932
    jim1932
    Snow is fun. Got a new motor coming. Scared to death about taking apart a running car. May be years before I drive it again....LOL
    Jet96, Old Dawg, winduptoy and 2 others like this.
  12. BlacktopScraper
    BlacktopScraper
    Seasons Greeting from Glendale, CA.
    Jet96, Old Dawg, winduptoy and 4 others like this.
  13. Dustyp489
    Dustyp489
    Love the pickup
  14. Gerald Sleater
    Gerald Sleater
    Hey guys, I'm gathering parts for my 30 coupes engine build. I should be getting my Burtz block within the month, I've already have my stipe cam in a 340 grind along with modern valves with oversized intake valves. I also have a Charlie Yapp rocket 428 head coming. My question is carbs. I have 2 holley 94's ones a 1939 the other a 40. With this combo can I run dual carbs if jetted correctly and set up with the correct power valve. Trying to spend my limited funds wisely. Thanks
  15. burl
    burl
    from Minnesota
    i talk to very few guys that seem to get two carbs to run right .I run one 97 on mine it it goes pretty good for not doing to much tuning. I like to keep things simple. Using two 81s seem to be the best set up. single stromberg.jpg
  16. Gerald Sleater
    Gerald Sleater
    Yeah, I'd love to run some stromberg 81's on it. I found both holleys when I was picking up parts that my grandfather had for the car, he had another car with a built b engine until my grandmother made him get rid of it. I'm building this in tribute
    Jet96 and Old Dawg like this.
  17. Stovebolt
    Stovebolt
    @burl just wondering what size jets and power valve you are running on the 97?
    My setup runs too rich - 0.040" up B, Winfield head and cam, headers, 97 on a burns intake, Not that dissimilar to your setup
    Dannerr likes this.
  18. panheadguy
    panheadguy
    from S.E. WI
    I'm new to the banger phenom... Who supplies oversize intake valves for the model A?
    Thanks
  19. winduptoy
    winduptoy
    With that cam/head combo I suspect that you will have way more carb than the engine can handle. Keep in mind that the larger the bore, the lower the air velocity thru the carburetors. That has a real effect on the performance of the carbs thru the RPM range.
    I was running an engine with a Stipe 340 cam, and it was way fat(AFR didn't read below 10:00/1 and it stuck there) with one Holley 94 and had the power valve blocked it did better and that was one 94
    I changed to a Stromberg 97 and the engine is lots happier and performs better all around.
    Heads up, the Stipe 340 cam doesn't start pulling until about 1500 RPM so unless you are running something other than a stock 3 speed the 2nd-3rd shift and off the line....unless you run okie overdrive
  20. winduptoy
    winduptoy
    I just did a dyno session with a single 97 with a Stipe 340 cam and the head is a Riley cast iron flathead with a 170 CC chamber and with the fly cut, head gasket and bore of .040 over it is just under 5.5/1 Compression Ratio
    Started with a 42 main jets and a 67 power valve. This was at 5500' elevation It did the highest, rear wheel, horse power pull, 54.28 HP@ 3430 rpm and 88.83 ft/lb torque@ 3110 rpm (it's the cam) but was between 10.5 and 11 air fuel ratio.
    Did some jet changing and leaned it out and the last run was with 40 main jets and stayed with the 67 pv
    It ran between 14 and 14.5 afr but lost 5 hp and 4 ft/lb of torque. I guess a difference between an economy tune and a 'power' tune
    Hope this helps and I may go a size larger (smaller number) on the power valve and stay with the 40 main jet
    I suggest a dyno session for real feedback
    This set up is probably suffering from a higher rise cam and a lower compression head combination but I am also running a 3 speed with a Mitchell OD so that is some rear wheel horsepower loss along with bias tires.
    It is a real drivable car though...
    Jet96, Old Dawg and Dustyp489 like this.
  21. Gerald Sleater
    Gerald Sleater
    I bought mine from Bert's model A store, but I know Snyders has them too.
  22. Gerald Sleater
    Gerald Sleater
    Thanks for the info, I'm actually planning on running a 36 ford box in my car. Just picked it up last week.
  23. winduptoy
    winduptoy
    Antique Engine Rebuilding has a 'kit' that has modern SS valves, guides, keepers, springs and the intakes are 1.730"
    https://www.antiqueenginerebuilding.com/
    I believe that Yapp has a similar kit but has spacers to use with stock springs
    https://www.secretsofspeed.com/
    Dennis Pariano has large intakes but he is currently out of them. I believe that they are 1.8++
    I bought AER's last kit earlier in the week but Missy said that she had more on order.
    You can use GM valves, I believe 472/500 caddy but they have a different stem size and length
    Jet96 likes this.
  24. jim1932
    jim1932
    Piranio's www.modelaparts.net
  25. trikejunkie
    trikejunkie
    from Scotland
    not long before the new variant appears ...............get fun in while you can
    Midnight Rider likes this.
  26. burl
    burl
    from Minnesota
    I think the main was .041 or .043 cant remember. Its all changed since then and I haven't had much time to get things tuned. Different head ,and distributor . The head has a completely different combustion chamber and should be able to flow the new large 97.I had a new large 97 on it but it was running to rich and I didn't spend the time to get that to work. Will get back to it eventually after I get my roadster project together.
    G_Don, Jet96, Old Dawg and 6 others like this.
  27. Stovebolt
    Stovebolt
    Thanks @burl and @winduptoy for your suggestions - I'll be getting into it over the xmas break, and using your advice as the starting point.
  28. panheadguy
    panheadguy
    from S.E. WI
    Thanks for the help with o/s valves. Didn't see anything on Snyders.
  29. panheadguy
    panheadguy
    from S.E. WI
    I wrote to them 2 weeks ago and got no reply.
  30. winduptoy
    winduptoy
    Beth takes care of the parts
    She answers the phone but they leave at noon for an hour lunch
    I just talked to her, this past week, and they are out of the large intake valves. She has them on back order with no ETA from the supplier
    https://modelastore.com/index.php?route=product/product&product_id=3598
