Unusual engine photos
Discussion in 'Off Topic Hot Rods & Customs' started by William Thompson, Sep 28, 2018.
  1. 75A12009-08F5-4FED-BFF6-2A04EC825AC6.jpeg ADAA1749-27FB-4C31-AC74-74E4763C6FA0.jpeg
    Unknown marine engine that popped up for sale.
    wicarnut, motoklas, Jet96 and 4 others like this.
  2. j hansen
    j hansen
  3. 1952henry
    1952henry
    That is a piece of jewelry. T head, I presume.
    loudbang and Deuces like this.
  4. jimmy six
    jimmy six
    There are a few posts on You Tube on the engines Ardema and Braun have built. Pete will put a overhead cam on anything including a Flathead Ford.
  5. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I've seen Ford Engineering T prototype engines from the era. Anything you can think of was tried back then.
    A few examples
    - OHC cam driven by bevel gears
    - 5-cylinder version
    - the infamous "X" motor; two pairs of 4 cylinders arranged in radial fashion
    motoklas, wicarnut, weps and 9 others like this.
  6. j hansen
    j hansen
    Never heard of a X motor before,advanced technology and design to be from 1935. Skärmavbild 2021-11-25 kl. 13.44.32.png Skärmavbild 2021-11-25 kl. 13.45.35.png Skärmavbild 2021-11-25 kl. 13.46.10.png
    motoklas, wicarnut, KiWinUS and 10 others like this.
  7. j hansen
    j hansen
    Note the year on the drawing! Skärmavbild 2021-11-26 kl. 09.24.36.png Skärmavbild 2021-11-26 kl. 09.24.55.png Skärmavbild 2021-11-26 kl. 09.25.21.png
  8. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Ford was working on the X8 as early as 1920; as seen in the cartoon above some were water cooled designs. None were marketable.
    Deuces, loudbang and j hansen like this.
  9. Truckedup
    Truckedup
    so the Stutz shown above has dual spark plugs...
    weps, Jet96, Deuces and 2 others like this.
  10. Adriatic Machine
    Adriatic Machine
    This is not as unusual compared to the others here, but this is my chrome head Lincoln V12. I got it here on the HAMB a few years ago. I still have to get some things squared away before I can tinker with it. My 39 Zephyr is still in storage as well.
    wicarnut, rod1, 63fdsnr and 5 others like this.
  11. j hansen
    j hansen
    Deserves a bigger pic:) Skärmavbild 2021-11-26 kl. 16.28.39.png
  12. noboD
    noboD
    Were they factory chromed? '39 Zephyr coupe is one good looking car!!
  13. j hansen
    j hansen
  14. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I think Remington rifles were built that way - interchangeable parts.
  15. Adriatic Machine
    Adriatic Machine
    No not from the factory. The previous owner was an avid collector though
  16. moparboy440
    moparboy440
    from Finland
    Packard straight 12. I understand they built only one or two of these as a prototype and decided against it.
  17. THE FRENCHTOWN FLYER
    from FRENCHTOWN
  18. Greenblade
    Greenblade
    Stanley steamer steam engine 2 cylinder 20hp. 20210328_110156.jpg 20210328_110207.jpg 20210328_110219.jpg these next 2 pictures I got from the internet Screenshot_20220115-233732_Gallery.jpg Screenshot_20220115-233728_Gallery.jpg
    ehdubya, Jet96, wicarnut and 11 others like this.
  19. moparboy440
    moparboy440
    from Finland
    That's actually the boiler, not the engine. The engine is located in the rear.
  20. rottenleonard
    rottenleonard
    Have y'all seen the Jay Leno YouTube (might have been a My Cl***ic car) where he is hot rodding a Stanley steemer, they were on their fifth or six rendition of different baffles in the boiler trying to keep the pressure up so they could go faster longer. Hot rodding is universal.
  21. moparboy440
    moparboy440
    from Finland
    The one-piece aluminum crankcase for the Duesenberg straight-12 engine.
    One of the largest aluminum forgings made at the time and weighed 365 lb (166 kg).
  22. stude54ht
    stude54ht
    from Spokane WA
  23. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Is that a V12 or a 4V DOHC V6?
    Either way it is an interesting example of using the engine as a stressed ch***is member.
  24. warhorseracing
    warhorseracing
    from cameron wv
    It is the V12 and yes Jag did use the engine as a stressed member. Very high level of engineering.
  25. stude54ht
    stude54ht
    from Spokane WA
    ehdubya, wicarnut, 63fdsnr and 7 others like this.
  26. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Interesting that one cam turns clockwise and the other cam turns counterclockwise. I wonder if the cams were the same but able to be swapped end-for-end? That would have simplified things.
    FE SOHC
    Deuces, loudbang and saltflats like this.
  27. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    From Mac's Motor City Garage:
    "Drag racers burned midnight oil tackling the Cammer’s issues, including the mile-long timing chain. Working with Harvey Crane of Crane Cams and P&S Machine, the always creative Pete Robinson produced this gear drive system. Note the additional gear on the left bank, allowing a right-hand camshaft to be used on both cylinder heads."
    I'm still trying to wrap my head around the gear train. How do you wind up with 2:1 crank to cam ratio with the different tooth counts left & right?
    egads, loudbang, Thor1 and 2 others like this.
  28. Adriatic Machine
    Adriatic Machine
    How do you wind up with 2:1 crank to cam ratio with the different tooth counts left & right?[/QUOTE]
    The different tooth count cancels out. First it goes 1:2 from big gear to little gear. Then back down 2:1 from little gear to big gear.
    egads, Thor1, Deuces and 1 other person like this.
  29. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    Ahaa! I guessed correctly.
    wicarnut, Thor1, loudbang and 2 others like this.
  30. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    FFF,
    You and Pete Robinson are my heros! :D
