Projects 1933 dodge coupe "Baleful"
Discussion in 'The Hokey Ass Message Board' started by oliver westlund, Nov 8, 2021.
  1. oliver westlund
    oliver westlund
    Beautiful
  2. oliver westlund
    oliver westlund
    dwollam and scotts52 like this.
  3. vtwhead
    vtwhead
    way to go Oliver! Merry Xmas!
    loudbang and oliver westlund like this.
  4. oliver westlund
    oliver westlund
    brEad, kidcampbell71, dwollam and 2 others like this.
  5. oliver westlund
    oliver westlund
    Thanks!
  6. Joe Lemay
    Joe Lemay
    Cut my trunk up 2 1/2 inches. You got more car then me when I started..good luck 0414190734_HDR.jpg
  7. oliver westlund
    oliver westlund
  8. oliver westlund
    oliver westlund
    Beautiful car!
  9. oliver westlund
    oliver westlund
    loudbang and kidcampbell71 like this.
  10. trevorsworth
    trevorsworth
    That steering wheel was definitely the right choice. That's gonna be really rad.
    oliver westlund likes this.
  11. oliver westlund
    oliver westlund
    Thanks! I think i even like it better than the 53 olds wheel i was after. Might try my hand at resin casting my own ****on for it
  12. trevorsworth
    trevorsworth
    I think it suits the build as the road less traveled... you probably won't see that combination anywhere else.
  13. oliver westlund
    oliver westlund
    Well...heres the grill im going to run on my 33! 1939 dodge 20211214_121718.jpg
  14. razoo lew
    razoo lew
    from Calgary
    In my mind there are better grilles for your ‘33……
  15. hotrodjack33
    hotrodjack33
  16. oliver westlund
    oliver westlund
    The shell will have to get some metal added, will be roundish when im done, this kind of idea but my own flavor, certainly not just gonna bolt it on as is, thatd look dumb Screenshot_20211214-155147_Google.jpg
  17. oliver westlund
    oliver westlund
    Stogy likes this.
  18. oliver westlund
    oliver westlund
    Nice!! Can i see a pic of your tail lights?? Mines gonna be fairly mild in its first form, i think a lasalle and a rebuild on the 303 will come down the road
    dwollam likes this.
  19. oliver westlund
    oliver westlund
  20. 1934woodie ply
    1934woodie ply
    Oliver what is your plan for you old grill shell ? Would be good for a pattern
  21. oliver westlund
    oliver westlund
    Im going to try to fix my old grill shell and may still use it
    Stogy and kidcampbell71 like this.
  22. oliver westlund
    oliver westlund
    brEad, loudbang and Stogy like this.
  23. Merkonic
    Merkonic
    Good luck with your car,you have a lot of work ahead.My 33 was made into a hot rod in early 70's but never finished & sat in garage for 30 years.Just needed gl***,wireing & paint.I replaced the lowere rear panel with the gas filler. IMG_0044.JPG
    Joe Lemay, Stogy, AHotRod and 3 others like this.
  24. oliver westlund
    oliver westlund
    Looks bad***!! Kind of selling me on rear fenders tbh. Bobbed though
    kidcampbell71 and loudbang like this.
  25. brEad
    brEad
  26. oliver westlund
    oliver westlund
    Has a lot of age, in amazing internal shape
    brEad likes this.
  27. oliver westlund
    oliver westlund
  28. oliver westlund
    oliver westlund
    Starting to tack things together, no judging! Just temporary so i can find body mount holes, take measurements cut and bend new pieces to replace big sections 20220115_150623.jpg 20220115_150754.jpg
  29. oliver westlund
    oliver westlund
    Little progress tonight, patch panel made from a 27 chevy s****. 20220116_171314.jpg 20220116_171307.jpg 20220116_171326.jpg
    Okie Pete, brEad and scotts52 like this.
  30. oliver westlund
    oliver westlund
    Its not perfect but im happy with the results! Stiffened the body up a ton too
    BigRRR, Okie Pete, Marcia and 3 others like this.
