Technical Lincoln Door Button- Install How To!
Discussion in 'The Hokey Ass Message Board' started by Asphalt Angel, Jul 2, 2014.
  1. Thank you for your kind comments-I have learned a ton here on the HAMB..it is a tremendous resource-
    I am honoured to be able to give a little back!
    fauj and The 39 guy like this.
  2. I'm glad this popped up again in another thread. I'd forgotten about it, but since I'm actually working on my '41 now this will come in handy.
  3. Kan Kustom
    Kan Kustom
  4. pat59
    pat59
  5. Doctor Detroit
    Doctor Detroit
    Nice job on this. I'll be installing my Lincoln door ****ons this year and this will be a good reference when I'm working through it. Thanks for sharing.
  6. brady1929
    brady1929
  7. flynbrian48
    flynbrian48
    IMG_4770.JPG I lucked out with my T'bird. I just drilled a hole in the door skin over the stock "paddle" that operated the latch, put the Lincoln ****on in, tightened the lock nut down, and done. Like they were made for it.
    lowrd and Asphalt Angel like this.
  8. X38
    X38
    Just finished plan B for the top bell cranks...I'll post the result when it's all done and I'm happy with it.
    Asphalt Angel likes this.
  9. Helloosination
    Helloosination
  10. okiedokie
    okiedokie
    from Ok
    Great tech, thanks.
  11. X38
    X38
    Yeah, the pics are in my album. Nearly the last pics I put there 3 years ago. I'm using genuine ****ons which are operationally the same but inside the door are different from the repro ones.
  12. lowrd
    lowrd
    Used the LI door ****ons on my 53 Chev. Slight mods to the internal mechanism. Used the original hole in the door and the retainer clips! Just had to file grooves in the threaded portion of the ****on for the clips to fit.
    LAROKE likes this.
  13. pprather
    pprather
    Back to the top, for those who haven't seen it.
  14. Russ B
    Russ B
    on my 51 ford we used the stock latches plus we kept the stock locking mechanism. We needed some modifications to the Lincoln latch ****on to get the lock working properly, but Ryan, of Logic, helped get us through the process.
    brEad and CoolHand like this.
  15. CoolHand
    CoolHand
    Alliance Vendor
    I dig that striping around the ****on & lock cover.
    Very slick.
