Trying to find out what oil pan I have. 350 Chevy engine. The dip stick has 8qt mark on it. The dip stick does look new, so it not original. The engine is a crate motor. Is there a way to measure the oil pan for quart capacity? The oil drain is on the drivers side, located right on the corner of the deep hump.
My thinking is if the oil pan is made for larger oil containment then 5 qts. would not be enough. I’m going to drain the pan, measure the old oil, to see how many qts. are in it. Then put a mark on the stick.
A 8 qt. pan would really wide or really deep. That looks to be a stock pan. But what do I know Iam a olds motor in a Oldsmobile kinda guy.
