Technical 302 Ford lifters
Discussion in 'The Hokey Ass Message Board' started by Kustom Komet, Dec 8, 2021.
  1. Kustom Komet
    Kustom Komet
    Does anyone have a suggestion for good 289/302 flat tappet hydraulic lifters? I rebuilt a 302 with new Sealed Power lifters, and they do work, they didn't eat the cam, but they are noisy. I'm not hearing encouraging things about good lifters like you used to be able to buy anywhere, but I wonder if something has become available in the last year since I looked.
  2. oldiron 440
    oldiron 440
    Do you have a cam picked out?
  3. RmK57
    RmK57
    I'm running into the same problem. I'm going to be running a fairly aggressive cam in my BBF and had to settle for Comp Cams 833 solid lifters. I had Johnson lifters on my old cam and they were made in the US, but have stopped making them. I think they only make rollers now. I don't know if there are any flat tappets made in the US anymore. Getting to be more of a **** shoot on breaking stuff in for sure.
  4. 55blacktie
    55blacktie
    Hylift Johnson is still making Ford Y-block mushroom lifters in the U.S. The same lifters are also being sold/w other manufacturers' names on the boxes. I would contact Dave at Hylift and inquire.
  5. F-ONE
    F-ONE
    from Alabama
    There's an old Chinese Proverb that I think fits your issue....
    Sum Ting Wong....
    One thing I have learned about a SBF...
    If it's making a clicking, ticking, clanging noise, there's something wrong with it. Major... like a piston skirt bouncing around or Minor...something needs adjustment.
    woodsnwater likes this.
  6. Keep an eye on e bay for a set of NOS lifters from the pre chinese days.
  7. Kustom Komet
    Kustom Komet
    It's a Crane Econopower 272 that I bought new in the '80s. One of my favorite cams, nice idle and good power and economy. And it still looks and works fine, no problems on the break-in.
    I will ask him, that name has come up.
    It's a simple scratch&ring rebuild, standard bore with a little bit of taper in the front 4 cylinders, but it didn't make any noise when it last ran with the stock cam. It's fairly quiet when cold, get louder as it warms up, the opposite of a skirt slap. Also, some of the lifters bleed down fast when the engine is shut off, fast enough that you can watch the rockers go neutral, while a few others hold tight for hours. That ain't right!
    I've thought about that, but trust comes into play there. The new Wuhan wang-dangs look exactly like the originals, so what's to stop a seller from reboxing a set of the real deals and sending me another shanghai surprise?
  8. 55blacktie
    55blacktie
    Check with Ted Eaton (eatonbalancing.com). He builds Y-blocks and FEs. He pretty much buys lifters from 3 different sources, including Hylift. He will either have what you need or tell you where to get it. If not, it doesn't exist. Of course, your problem might not be lifters. How's your oil pressure?
  9. Kustom Komet
    Kustom Komet
    Very good, 55 cold idle, down to low 40s hot at idle.
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Were all the oil galley's cleaned out before re-***embling engine?
  11. Kustom Komet
    Kustom Komet
    Yes. Galley plugs removed, galleys cleaned with galley brushes, sprayed out with a hot water pressure washer. Oil coming out of all rockers, so does not appear to be an oiling problem.
  12. seb fontana
    seb fontana
    from ct
    Are sure they are adjusted right? Some times loose valve guides will allow a ticking sound.
  13. finn
    finn
    Hylift and Johnson were both trade names used by Sealed Power. Sealed power was morphed into a division of SPX, but I think the company was eventually picked up by Mahle as the supplier industry hit troubled times.
    Sealed Power was an OEM supplier, and they provided lifters and cam cores, as well as finished cams to most of the aftermarket cam companies, who sold them under their own label.
    The only other OEM lifter suppliers that I recall were GM’s Rochester Products Division and Eaton.
    I doubt that there is much US production of flat tappets anymore, since I can’t think of any flat tappet engines still being produced. Without production engines, there really isn’t much reason to keep the old lines running, so everything is likely offshore.
  14. Runnin Elgin in mine. Never paid any attention to noise.
    Last set I bought came from these guys
    https://www.johnsonlifters.com/
    Does what they’re supposed to.
    They replaced a set from Lunatti that were too short.
  15. 55blacktie
    55blacktie
    Hylift Johnson and Johnson Lifters are two different manufacturers. Hylift Johnson might sell lifters to Sealed Power, but they are not the same company.
  16. RmK57
    RmK57
    Those are the brand I bought 6-7 years ago. They don't make flat tappets anymore, just rollers.
  17. 55blacktie
    55blacktie
    For Hylift Johnson, see toplineauto.com
  18. Kustom Komet
    Kustom Komet
    Didn't know that. Interesting. I wonder if they work together.
    I adjusted them several different ways, they are currently zero lash plus 1/2 turn. I have also tried zero lash plus 1/4 turn, 3/4 turn, and just zero lash. All sounded the same. Valve guides are OK, not perfect but functional.
    I just asked them for a suggestion on their site, interesting to see what they recommend. This has to be a common problem in the vintage car world, there must be a solution. I could always go with a roller 5.0, but I like the idea of a vintage engine in a vintage car - and it runs nice and strong too.
  19. Elgin or Johnson’s?
  20. sdluck
    sdluck
    Are you sure the noise is lifters? My buddy's 350 chevy had a lifter type noise it ended up being wrist pins?
  21. Kustom Komet
    Kustom Komet
    The wrist pins were very good, no sloppy movement at all. Stock pistons, rods, and pins never dis***embled. Pretty sure it's the lifters as a few don't hold the oil prime and that is reportedly a problem with the new parts.
  22. RmK57
    RmK57
    Johnson's. My engine guy is having a tough time getting anything because of the supply issues.
    I was lucky he had a few Comp Cam masters he could work off to get the grind I needed. As far as lifters all he had was Comp Cams brand, everything else is not available or back ordered.
    anthony myrick likes this.
  23. Dang. I bought lifters for my 500 caddy from CadCo a few months ago. Flat tappet. CadCo guy says Johnson’s makes em.
    I’m saving all my old lifters now, just in case it gets down to cleaning and resurfacing them
  24. 55blacktie
    55blacktie
    Crower and Isky are Johnson Lifter (not Topline Hylift Johnson) distributors. You can find both Isky and Crower hydraulic flat tappet lifters for 302 Ford on Summit's website.
  25. birdman1
    birdman1
    Mellings are made in the USA. I called and asked. But they do rattle in my 430 Lincoln powered 37 coupe
  26. RmK57
    RmK57
    Johnson doesn't make flat tappet lifters anymore and haven't for a few years. Looking at the Summit website their out of stock on both Isky and Crower hydraulics for sbf.
  27. finn
    finn
    Hylift was a division of Sealed Power, and trademarked their lifters as Johnson Products.
    I interviewed for the Chief Engineer position at Sealed Power when they were under the control of SPX Corporation, back in the 90s. (As I recall it, Sealed Power Corp was on a diversification kick and renamed the corporate en***y SPX. That eventually fell apart and Sealed Power essentially disappeared as a corporation, but the name lives on under different ownership, as an aftermarket trade name.)
    Looks like the lifter division in Muskegon Mi was spun off and is now owned by Topline.
    Any search for Johnson Lifters eventually links back to Hylift Johnson. Remember: Hylift division of Sealed Power originally marketed their lifters under the Johnson lifter or Johnson Products moniker.
  28. X38
    X38
    They're in stock on my Summit website.
  29. Starlinerdude
    Starlinerdude
    from Washington
    Something that has been said about lifters in general lately is that some have the oiling band in the wrong spot causing the lifter to not get full pressure making them noisy.The band that is smaller in diameter than the surface that rides in the lifter bore is either too high or too low and isn't properly exposed to the lifter oil galley in the block.
