1930 Ford Coupe
Discussion in 'Cars For Sale' started by BenLeBlanc, Nov 20, 2021.
  1. BenLeBlanc
    BenLeBlanc
    City: Ortonville
    State: Michigan
    Price: 17500
    47D66EF0-C929-4865-84AD-8511759598BA.jpeg B1A88A2D-6D0E-49D0-BAE1-C62D4CDC666C.jpeg 2043CDB8-A43D-4C83-9E66-3652A908A8FD.jpeg AE53C3D6-19AA-4AB0-83C6-260A1CF0ED2F.jpeg 11C9F876-78B7-4F9F-BBB5-CFCA58EE1132.jpeg 4BAA9488-2003-4D25-9295-67FA83AE109A.jpeg EE18D40C-F576-4DFF-A930-B269F2A3223D.jpeg 258587A9-66CC-43B9-8CDE-599CE4028AF5.jpeg
    Hi all,
    I am deciding to list my car for sale here, after some consideration. It is pretty complete, but needs body work and finish details to be a show car. The good thing is that it runs and drives great, all the parts are here, and everything is rebuilt and rust free. Got it up past 70mph and it tracks super straight (one hand on the wheel). On my side, the reason for sale is that I am looking to just move onto the next build.
    1940 Flathead V8
    1937 transmission (worn 2nd synchro, have to hold in gear)
    Model A rear end
    Reverse eye main rear spring, leaves received Vern tardel treatment
    Rear stack Z
    Front posie super slide reverse eye pack
    38-40 front juice brakes
    46-48 rear juice brakes; backing plates flipped 180 degrees
    Model A pedals
    Boxed frame with 1/8 inch drilled plate
    Crossmembers added to frame for stiffness
    Jegs universal 2-pot master
    Odyssey Battery
    WWII oxygen tanks converted to gas tanks and mounted in custom floor in trunk- with rollover valve/ vent
    Ni-cu brake lines
    Brookeville grille
    Smoothed gas tank
    46 ford dash (speedo, oil pressure work)
    F1 steering box
    New wood coated with 2x minwax helmsman spar varnish prior to ***embly
    ****on-down removable canvas top
    Windows are lexan; non permanent (finalize chop and get gl*** after)
    Dodge caravan seat recovered with vinyl
    WWII bomber seatbelts for both driver and p***enger
    New stromberg 97 carb
    Crab distributor
    Two pulley setup for fan
    Single Pontiac tail light (need a new brake light switch; I may tackle this soon)
    Body is fully patched, epoxy primer sealed with southern polyurethane
    Louvered deck lid (needs inner structure). Was media blasted prior to paint
    4.50 in front, 7.00 in rear on 35 wires
    I would suggest a new p***enger door if you want a show car; it is the roughest part.
    Reach out with questions!
  2. BenLeBlanc
    BenLeBlanc
  3. BenLeBlanc
    BenLeBlanc
  4. BenLeBlanc
    BenLeBlanc
