Art & Inspiration Acetylene Smoke images
Discussion in 'The Hokey Ass Message Board' started by lothiandon1940, Dec 12, 2021.
  1. Sod Buster
    Sod Buster
  2. Cool story! Thanks.
  3. nrgwizard
    nrgwizard
    from Minn. uSA
    There was a Custom Paint book, only ~1/4" thick, but well illustrated n commented(mine is buried somewhere, or I'd dig out the ***le) out in the 70s(?) that covered these techniques. IIRC, cobwebbing was done w/very thick paint, like almost glue-thick, sometimes using a spl gun called a"veiling gun". Never got to see one close-up, wish I had one. I like the effect, acet painting, too. Also huge 'flake, w/color fading, candies, lace, etc. Can you say "Street Freak", late 60s->mid 70s FunnyCar or "ShowRod" ... I knew you could! :) :D . It seems to me that all this stuff is done on some low-riders, but the goal & effect of each camp is different. Thankfully.
    Marcus...
    Stogy, loudbang, hotrodjack33 and 3 others like this.
  4. lothiandon1940
    lothiandon1940
    .......If you locate that book we would love to see some images from it.:)
  5. Yup, just like necker knobs
  6. alanp561
    alanp561
    The inside looks real good with the smoke but smoking the outside didn't work all that well, in my opinion.;)
  7. alanp561
    alanp561
    Roaches in the ash tray, "Quick, Henry, the Flit!!" That was for those of you old enough to remember.
    Stogy, Joe Blow, Dino 64 and 2 others like this.
  8. You have to bury it in clear. The process is to lay the smoke pattern that you like then hit it with a pretty dry coat of clear maybe two dry coats that will seal it then you can start blowin clear on until you have burried it as deeply as you like.
    Stogy, loudbang, hotrodjack33 and 9 others like this.
  9. jim snow
    jim snow
    Aha. That makes sense. Thanks. Snowman ⛄️
  10. lothiandon1940
    lothiandon1940
  11. Haven't seen that done for 50 years or so.
  12. alchemy
    alchemy
    My Dad's 33 tudor had the dash and window moldings smoked in about 1977. I remember watching the painter do some of it. He used a medium brown for the base, fully dry. He added the soot, and then lightly sprayed clear over all for a quick coat to lock it down. Then came back with heavier coats of clear. All lacquer of course.
    The resulting parts looked like a burled woodgrain sometimes, and others you could tell it was smoked. The car still exists with that paint in Rochester, Minnesota.
  13. aircap
    aircap
    When the van craze was going great guns one of the car mags I was reading did a "how-to" article on the technique. The end result were panels of medium brown streaked with carbon from the torch, making it look vaguely like wood grain. I figured I'd try it someday, but never did.
  14. lothiandon1940
    lothiandon1940
    .........Must be traditional.:D;)
  15. jnaki
    jnaki
    Hello,
    For quite some time, there were a lot of great flame painters. Then it must have been something in the air as the showcase of Mike Lavallee began to be the “flames of the times.” Looking at those flames on any surface and custom hot rod was like looking into a real depth of flames.
    Airbrushing can do some amazing things and even showcase the acetylene black wisps, without the dangers of gas torches. The painting design was very time consuming with the different layers but in the end, it looked as if you could stick your hand in the deep finish on a flat surface. The art of airbrushing at its finest. No need to sit there with the gas torch set on low to create the black wisp by product.
    Jnaki
    Sadly, he p***es away, but those flames and popularity of the artwork still persists a**** the current flame painters and hot rod enthusiasts. No, it was not your typical, fancy curved, claw flame painting we have all been accustomed to seeing on old hot rods. It was a different look to the “flames” culture. YRMV
  16. nrgwizard
    nrgwizard
    from Minn. uSA
    Didn't know Mr. Lavallee p***ed. Called "Real Fire". He put out a how-to kit awhile back. Good instructions. Someone else bootlegged it, both were worth the cost, which wasn't much, to see how it's done. His comment on "Being Careful for What you Wish For" made me laugh - apparently doing *one* semi cured him of wanting to ever do another, as it left him cross-eyed for awhile. :) .
    Marcus...
    lothiandon1940 and loudbang like this.
  17. mgtstumpy
    mgtstumpy
    Wow, I was taught to use acetylene smoke on aluminum when welding it at college. I've never seen this art form!
    Stogy, alanp561, RodStRace and 2 others like this.
  18. partssaloon
    partssaloon
    This is my buddy's 36 that was done about 12 years ago. Still looks good today.
  19. RodStRace
    RodStRace
    That was a process to anneal the aluminum, coat the part with soot, then torch it off.
  20. lothiandon1940
    lothiandon1940
    Great demo. Thanks for posting @RodStRace . I'm thinking that's how this whole art form got started. Someone was annealing aluminum and thought wow, I can make a design with this carbon smoke.:D
    Stogy, loudbang and RodStRace like this.
  21. How the heck did you find a picture of Windfield with no girl on his arm? HHhahahah!!!
  22. theHIGHLANDER
    theHIGHLANDER
    That ol dude has seen more *** than the toilet seat in the ladies room!:D:D
    mohr hp, Stogy, 40ragtopdown and 4 others like this.
  23. B.A.KING
    B.A.KING
    THATS A GREAT LOOK, but there is no doubt in my mind,I would burn my frickin car to the ground..........jus sayin
    Stogy, Tman and lothiandon1940 like this.
  24. lothiandon1940
    lothiandon1940
    ......I feel your pain.:D
    Stogy, Tman and loudbang like this.
  25. indyjps
    indyjps
    loudbang and lothiandon1940 like this.
  26. 56don
    56don
    Well, after reading all of these and seeing the examples, I like the look if its done sparingly. Looks better than the lace work from back in the day.
  27. lostone
    lostone
    from kansas
    Beautiful job, I love the color, if you don't mind me asking what is the base color ?
    @chopolds
    Stogy and lothiandon1940 like this.
  28. swade41
    swade41
    from Buffalo,NY
    My neighbor's cyclone
    And a friend's 56
    BigRRR, slayer, Jim Bouchard and 3 others like this.
  29. Stogy, lothiandon1940 and swade41 like this.
  30. swade41
    swade41
    from Buffalo,NY
    Yes it is, one owner car that was painted in 1971 and also had the vinyl top added, I've known him for 20 yrs and have never seen it at a cruise night, not many photos of it around.
    Stogy, lothiandon1940 and Tman like this.
