Projects Worst Engine Ever. *update on why I dislike Fords*
Discussion in 'The Hokey Ass Message Board' started by Ramblingman, Dec 15, 2021.
  1. Ramblingman
    Ramblingman
    Hello and greetings,
    10+ year lurker here. Own a couple AMC Ramblers recently picked up this gem of a 52 ford customline. As you can read by the ***le, this is by far the worst engine I have ever seen in over 16 years of working on cars.
    Does anyone know if a ford 300 I6 will swap 'easily' into the old car?
  2. The image you posted does,nt show up. Maybe to big . I take it your cusso is a straight 6 then and not a V8.
  3. squirrel
    joel and chryslerfan55 like this.
  4. evintho
    evintho
    302 V8 is a bolt in.
  5. 40FORDPU
    40FORDPU
    Since the image didn't display..is it a 6cyl, or V8?
    If you are referring to the Flathead V8, I'm sure some would say "worst engine ever"..just as I'm sure many would say it's the "best engine ever".
    Isn't traditional Hot Rodding great?
    Like everything else in this world we all have our own opinions, which of course is as it should be.
    chevyfordman likes this.
  6. Ramblingman
    Ramblingman
    I have changed the permissions on the image, I hope it shows up now. It is the old 215 inline 6, by worst engine ever I mean to say its rusty. Owner said it was running 25 years ago and parked in a barn.
    chryslerfan55, loudbang and 5window like this.
  7. RMONTY
    RMONTY
    Blow the rust off, a couple cans of PB Blaster and some ATF and Diesel fuel, soak 'er down and bust 'er off! Should run like a top! (equivalent to "that'll buff out!)
  8. squirrel
    is it stuck? or does it turn?
    (yeah, silly question...but.....)
    hotrodjack33 and Johnny Gee like this.
  9. RmK57
    RmK57
    Looks like brand new carb on it. Hmmmm, putting the cart before the horse on this one.
  10. gimpyshotrods
    gimpyshotrods
    I'd run it.
    The 302, that is.
  11. F-ONE
    F-ONE
    from Alabama
    Not quite. There's just a little more to it.
    A 223 would be a direct bolt in. Sometimes you can find a good 223 almost free. Then again, the cheap running 223s are like cops. You only see one when you don't need one.
  12. F-ONE
    F-ONE
    from Alabama
    Looks can be deceiving. The rocker ***embly may be toast but it could be a viable engine that needs less than you think. It's worth pulling and going through, or at least pulling the head and trying to turn it.
    chryslerfan55 and Elcohaulic like this.
  13. Truck64
    Truck64
    from Ioway
    Yeah, a little Bardahl's will fix that right up. Tell 'em Ed Justice sent ya!
    chryslerfan55 and VANDENPLAS like this.
  14. 56don
    56don
    Looks more like he parked it in a boat house...
    alanp561 likes this.
  15. gimpyshotrods
    gimpyshotrods
    Truth.
    I would vacuum that out, and tear it down. It won't take that long.
    It might be better than it looks.
    chryslerfan55, NoSurf, egads and 3 others like this.
  16. F-ONE
    F-ONE
    from Alabama
    You can have a lot of fun with the first generation Ford OHV Six.
  17. jimmy six
    jimmy six
    Love um or hate um…..no middle ground.
    loudbang and hotrodjack33 like this.
  18. oldsman41
    oldsman41
    289 or 302 would be my first choice but a y block would look great in that compartment.
  19. williebill
    williebill
    Don't know about worst, but it sure is ugly.
    loudbang, LWEL9226 and hotrodjack33 like this.
  20. finn
    finn
    Under the boat house
    alanp561, loudbang and Truck64 like this.
  21. MMM1693
    MMM1693
    I'll take the carb! Seriously!
  22. squirrel
    or it could be worse than it looks.....like this DeSoto a friend picked up 20 years ago. Looked great on the outside.
  23. ekimneirbo
    ekimneirbo
    What do you plan for the car to look like when its done? What do you plan to do with it when its done?
  24. KenC
    KenC
    Engine patina. New carb, but someone had some difficulty with the fuel line?
    chryslerfan55 and Truck64 like this.
  25. Check the oil before you crank it over.
    bobss396 likes this.
  26. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    Yes, sir that is one ugly engine, however it's not a 215. It's a 223 which may have been an option or probably a replacement part. The 215 had half the valves in the block and half in the head. It was only used in '52 and as a "service replacement" for a few years if memory serves. They weren't much good. My neighbor has a '52 F-1 with one of the 215 engines. It will run but it's no good.
    You should make up a display and take it to shows. You would surely win a prize of some kind. Or be kicked out. :eek:
  27. that motor is perfect for a 'patina' build. Do what they do... just cover it with oil and display it proudly. Remember, it's only original once. Any other option won't be considered HAMB friendly.
  28. RMR&C
    RMR&C
    from NW Montana
    Say WHAT????????? I own a '52 215 and it does not have anything like that. Are you thinking of an F head Jeep engine? Please post pics of said engine....
    Xtrom, RICH B, chryslerfan55 and 5 others like this.
  29. Zax
    Zax
    Man, that's pretty rough. How does the rest of the car look? Like has been said a 289 or 302 is a good swap or sometimes you can find a good 215 or 223 someone is pulling out.
    Either way you should be able to part some of that engine out. The carb looks like a newer replacement. The intake and exhaust manifold if not cracked will probably sell.
  30. Rckt98
    Rckt98
    At least someone has gone to the trouble of numbering the plug leads so that will make getting it going a lot easier LOL.
    chryslerfan55 and 61Cruiser like this.
