Customs winch and tree body work on my 1948 Oldsmobile futuramic 98 today
Discussion in 'The Hokey Ass Message Board' started by flyin flattie, Dec 15, 2021.
  1. flyin flattie
    flyin flattie
    from Redmond OR
    Wench and a tree man auto correct is killin me! Parked the olds by the ol juniper tree today attached the rear frame rail to the duramax put some chalks down and got to wenchin! And dolly hammer snd maybe a 4x6 smack or two and shizam.
  2. bjinx
    bjinx
    To Cool
    LWEL9226, AVater and loudbang like this.
  3. 41rodderz
    41rodderz
    from Oregon
    Well let me shake your hand . You are the first person I have seen that gives “shade tree mechanic “ a good name . :D
  4. Black Panther
    Black Panther
    from SoCal
    That's a great result....good job!
  5. choptop40
    choptop40
  6. loudbang
    The good old fashioned way still works. Did you check your door gap while you were working? Most times a hit like that will moved the fender back into the door gap.
  7. mgtstumpy
    mgtstumpy
    I used a movable 'pulldozer' in the trade years ago to do the same thing. Necessity is the mother of invention. Kudos to you. Damage needs to be repaired in the reverse order to how is occurred.
    chryslerfan55, Hnstray, X-cpe and 7 others like this.
  8. lothiandon1940
    lothiandon1940
    Old School body work. It doesn't get any better. :D
    Hnstray, alanp561, mgtstumpy and 6 others like this.
  9. brading
    brading
    Nice work there going back to old school ways
    kidcampbell71, loudbang and AVater like this.
  10. AVater
    AVater
    Nice work there! Stands to be a very nice project.
  11. vtwhead
    vtwhead
    Great job! Haven't seen that done in years.
  12. j hansen
    j hansen
    Perfect!! Have not done it myself since the early 80`s,but I had a tractor.
  13. catdad49
    catdad49
    Who said ya can't do it at home? Bravo!
  14. chargin03
    chargin03
    I need one of those trees!
  15. catdad49
    catdad49
    My story also involves and an Olds ('58) and a tree. Pulling the V-8 with a chain around a branch and that attached to a chain fall. Every time we came close to clearing the rad. support, the branch would sag and we would have to repeat the process. What to do? We finally Lowered the car by letting air out of the tires! I think we were 15 at time and the Olds made it to the Henry J frame, but it was never completed. Probably a Good thing!
  16. lothiandon1940
    lothiandon1940
    I know how my luck works. The tree would fall and crush the whole car!:eek:
  17. NashRodMan
    NashRodMan
    Pretty darn cool. I did that once with an off topic caddy in the late 80's. I used a tree, put car in reverse and hit the pedal. It worked.
  18. Petejoe
    Petejoe
    from Zoar, Ohio
    Wow that turned out nice. Never seen it done like that. Great work.
  19. 1971BB427
    1971BB427
    from Oregon
    You can't do that! You need a big fancy shop, and all sorts of expensive tools to do that! You're gonna make all those with that stuff irritated, and they'll push everything out of their shop and go find a big tree!
    Really nice work!
    chryslerfan55, alanp561 and loudbang like this.
  20. guthriesmith
    guthriesmith
    Yep, I have done that trick a few times too. Looks good!
    mgtstumpy and loudbang like this.
  21. Max Gearhead
    Max Gearhead
    from Wisconsin
  22. flyin flattie
    flyin flattie
    from Redmond OR
    Yup the core support up front needed a yank as well and the door wasn’t opening before and now it has a better gap than the other side! Also hanker on the hood hinge too but I think I just need to adjust the hood.
  23. flyin flattie
    flyin flattie
    from Redmond OR
    Exactly! How it was hit is how it gets fixed just slower and account for some spring tension from the metal!
  24. kidcampbell71
    kidcampbell71
    Whatever you do .. don't loan the tree out to friends. You'll never see it again.
    Nice job !! :)
  25. Trees are our friends. When I was 16 I used a big old cottonwood to pull the motor out of my '55 Ford and drop in a 289. :cool:
  26. 50Fraud
    50Fraud
    That's such a pretty body style. I hope you're able to get it back to pristine condition.
  27. Fortunateson
    Fortunateson
    You’re the New Shadetree Bodyman Champion!
  28. bigdog
    bigdog
    That's how I used to straighten out the stock car. Except I'd just chain it to the tree and then floor it. Of course, it didn't have to be real straight either.
    X-cpe, loudbang and mgtstumpy like this.
  29. Hotrodderman
    Hotrodderman
    When I was 16 my Dad had a 74 Ford pickup with West coast mirrors that stuck way out and I was in a hurry backing out of this pole shed and I caught one of the poles by the edge of door opening and bent the right had bumper half damn near 45 degrees out the front. I got out and looked at the bumper and knew I was in trouble.
    Thinking quick I slowly drove the truck bent bumper into a big tree in the yard and put enough pressure on it to bend it back. After a few pushes it looked pretty good. Only problem in the middle of the bumper there was about a two inch tent from bending the bumper back. Couldn't figure out how to remove that.
    A few weeks later Dad noticed it and asked me how that could have happened? I fessed up. Did not get into trouble. Dad was pretty cool and still is.
    Trees can come in handy.
  30. Budget36
    Budget36
    Better than mine turned out!
    Then again I didn’t have a Duramax and a tree, just a forklift and a telephone pole.
    rusty valley and loudbang like this.
