Can you build a real Chevy 302?
Discussion in 'The Hokey Ass Message Board' started by Lucky Strike, Sep 27, 2005.
  1. Taboo56Chevy
    Taboo56Chevy
    Wont post the link as its not a hamb friendly car but on Youtube, search for Ben Wenzel Z/28. Guy is the original owner of a 67 Z/28 and has been racing it since new, currently in C/Stock. There is a in car video and if you can watch on HD on a larger screen you can clearly see the tach needle. Dumps the clutch at 6200rpm and the power shifts it at near 10k rpm. Those little 302s are just nuts.
  2. Roothawg
    Roothawg
    There used to be a guy around here that spent tons of money on his 301 valve train to get it to wind tight. It wasn’t efficient, because it was flat once it nosed over, but he liked people to hear it. It was fun to watch.
    mad mikey, Tickety Boo and Deuces like this.
  3. Brian Penrod
    Brian Penrod
    That a cool story on Ben and his brother and the 67 Z28.
    Deuces likes this.
  4. irunonbeer
    irunonbeer
    I am looking at a set of .060 over 302 pistons and 2 have scuffing on the sides. What would cause that ? Are they still good to use? Thank you B5DAA32A-6A2C-47A9-8FC3-3865E41E56B6.png
  5. GlassThamesDoug
    GlassThamesDoug
    Dont like that, either lube issue, as in insufficient film, or tight. Over heat is usually more of a 4 corner scuff due to material around pin boss. Either way, their ash trays, Wisceo, SRP, JE make new pistons, go that route. Spend money in Pistons, will pay off.
    mad mikey, Deuces and Tickety Boo like this.
  6. GlassThamesDoug
    GlassThamesDoug
    Put this one together in July 2021. Nice street driver.
    mad mikey and Tickety Boo like this.
  7. irunonbeer
    irunonbeer
    Thank you, kinda what I was thinking! Have a great day!
  8. GlassThamesDoug
    GlassThamesDoug
    I bought a digital scale to check piston weights, so I dont have to rebalance crank. 70s TRW 302/327 12:1 are 715g, JE 406 14:1 are 595g. Other advantages can be found.
  9. Tickety Boo
    Tickety Boo
    from Wisconsin
    Any one know the weight of a stock 283 piston to compair to the others :rolleyes:
  10. GlassThamesDoug
    GlassThamesDoug
    I checked 16 LJ 350 rods, Xs and Ks all were same weight, one was 5g off. I wonder how close factory parts were. Someone working there would know.
  11. Fordors
    Fordors
    575.5 grams without the pin.
  12. CNC-Dude
    CNC-Dude
    If there is that much weigh difference between the pistons you certainly will have to rebalance the crank....
    GlassThamesDoug likes this.
  13. CNC-Dude
    CNC-Dude
    Well it depends on how close the rod weights on the X rods are compared to the original rods the crank was balanced to. 5g's between the whole set is closer than what a factory matched set usually is, but if they are 30 or 40g heavier or lighter than the original set you'll have to rebalance the ***embly....
    Deuces and GlassThamesDoug like this.
  14. brigrat
    brigrat
    from Wa.St.
    Out of balance "is" out of balance, your RPM destination will determine how finicky you wanna get on the balancing.........
    mad mikey and Deuces like this.
  15. GlassThamesDoug
    GlassThamesDoug
    Digital scales at Harbor Freight... works for me $39. I checked 70s era 17 TRW 12:1 pistons...302s and 327s... same wt.. with pins. Interesting.
  16. Tickety Boo
    Tickety Boo
    from Wisconsin
    Closest weight I found so far was the Icon hollow dome 302 piston #IC802 at 552 grams without the pin.
    The pin is 132 grams, some things can be done to get close like using thicker wall piston pins. ;)
    A engine builder/engineer ( he shall remain anonymous ) told me that if you are starting out with a balanced ***embly and are only changing pistons/pins and remain within + or -2% of the current piston/pin you will be OK. o_O
    He went on to say that the balancing guys will tell you everything needs to be with in 1/4 gram, but if they told you the truth they would starve :eek:
    I ended up about 6 grams lighter ( 548 grams to 542 ) on my last piston/pin change on a big inch smll block Chevy
    with no ill effects ;)
  17. CNC-Dude
    CNC-Dude
    It's common for race engines to be over balanced by 1-1/2 to 2%. But yeah, trying to weigh components to within 1/4g is simply marketing baloney. Plus or minus 5 or 6 grams you'd never know it.
  18. buick bill
    buick bill
    from yreka;ca
    well someone woke the dead here . been reading it for hours . almost forgot where it all started !! anyway . kinda on topic . seems like i read that gm made the 305 because it was the best all around compromise for bore x stroke.how does that compare to a 302 ? built the same wouldnt they have close to the same hp/ torque / rpm .?ive got a 283 and a 305 horded in one of my garages . is it stupid not to s**** them both . seems in the day of 454 sbc of the shelf , none of it makes much sense ! or is that ot ? i did have a built 283 in my old malibu with a muncie behind it . may not have really been fast . but , sure was fun to hit second in . and with the posi it kept you on your toes !..sure seemed fast 1965 malibu 007.jpg 1965 malibu 017.jpg 1965 malibu 013.jpg
    impala4speed, Tickety Boo and Deuces like this.
  19. i7083
    i7083
    The motor that was in my coupe when we dug it out of the field is a '69 302 block. It appears to have a 350 crank in it. Haven't taken it apart yet...
  20. Budget36
    Budget36
    Regarding the 305 and 302, although displacement is close, two things are different. Bore on the 302 is 4 inch, stroke is 3.25. The 305 is somewhat opposite, 3.48 stroke, 3.78? Bore.
    The 302 allows the bigger valves but the 305 shrouds them. It’s possible that bores are in the way of the valve, but no experience to say one way or the other.
  21. 26 T Ford RPU
    26 T Ford RPU
    Didn't they just use a 350 4 bolt for the 68 and 69 302? JW
  22. 26 T Ford RPU
    26 T Ford RPU
    The 302 has a 3'' stroke not 3.25'', thats a 327-307 stroke. JW
    mad mikey, Deuces and Budget36 like this.
  23. Budget36
    Budget36
    Good catch. I’m aging and forget;)
    Deuces and 26 T Ford RPU like this.
  24. Deuces
    Deuces
    Why not use a small journal 327 block???....o_O:rolleyes::rolleyes::rolleyes:
    mad mikey and GlassThamesDoug like this.
  25. Fordors
    Fordors
    HTF in my neck of the woods, can you find SJ blocks easily in Michigan?
    Deuces likes this.
  26. GlassThamesDoug
    GlassThamesDoug
    My LJ 302 is ready to build, think I'll swap out pink rods & TRW pistons for stronger and lighter modern components. Rebalance and roll... Like to go flat top with smaller cc heads.
  27. 26 T Ford RPU
    26 T Ford RPU
    Going back to the original question,''Can you build a real 302''.. i take it as can you build one with exact parts as used from 67,8,9. Block, heads, crank and rods, intake, in other words ''make an exact copy at the least. JW
    Deuces likes this.
  28. GlassThamesDoug
    GlassThamesDoug
    I got several 327 sj blocks... for sale.... I have another 302 sj spare crank too.. if your looking. My LJ 302 block and crank can go for what I got in them....making room in Ohio...
  29. GlassThamesDoug
    GlassThamesDoug
    Typical heads that can be used on a 302, 462 camel humps... donated to my buddy cuz his kids are building a sbc g***er.. teaching them how to build their first engines tomorrow. 20211218_145148.jpg
  30. GlassThamesDoug
    GlassThamesDoug
    Yes 302 sj cranks were used in some HD 283 applications. How to tell is they have single notch in round flange. 5.7 sj rods can be pink or green code, green (floated) is more rare. The 327 blocks were same 2bolt sj castings used for 302. LJ castings are easy to locate, LJ cranks are available all the time on EBAY. Fundamentally a 3in stroke, 5.7 pink con rods, 4in bore is all it takes. TRW original design with GM part numbers are also available. All parts to build a component correct 302 are available ... its how much you want to spend. Cylinder heads are everywhere...no longer special, 462, 492, 291, 041, 040, 186, ..... MORTEC will give you casting, forging numbers that can be used for 302s. Camaro oil pans, windage trays and studs were available from GM 10yr ago, original intakes and correct carbs are available as well. Cams with correct grinds are available by at least 10 different cam grinders. This should answer.... YES its not difficult.
