Projects Bonneville XF/GMR Build
Discussion in 'The Hokey Ass Message Board' started by cornfieldcustoms, Sep 14, 2021.
  1. Looks great! Hard to get much lower. I hate seeing cages stickin up in the breeze! And do I see some skinny 17s for the front?
    Stogy and loudbang like this.
  2. cornfieldcustoms
    cornfieldcustoms
    Yes they are 17 x 2.5
    Stogy, loudbang and Tman like this.
  3. Progress?!
    Stogy and chryslerfan55 like this.
  4. cornfieldcustoms
    cornfieldcustoms
    Tons of progress being made on the car. Just havent posted much on here. Steering, fuel system, engine, trans, ****tershields, driveshaft cover, shifter, clutch, water tank, hand brake, seat, and more all mocked up. I will post up a bunch of pics since they are better than talking about it DFDFB6CF-CBA4-4E27-9AF2-A95D99E1FB35.jpeg B83CF825-2092-4ADA-A79C-E7B2B41BE532.jpeg 84EA018A-3559-4562-897E-541402FE8989.jpeg 9BC59EB2-E6A6-4981-A882-01B1CE2F28D7.jpeg EE51A514-B88E-4793-851A-83C6D60D4A40.jpeg 32BB37DB-2AA5-4C45-A8B9-B5002BF20CAA.jpeg CE829875-85CB-4D89-8CC0-061381B3E157.jpeg 0FDFD39F-3751-4A70-9227-A3EF4447DCC3.jpeg E53C07F9-22EF-4E32-A899-09A08CFA2A8C.jpeg 8E24D8D0-77F2-4BE7-A73E-3E2D1AEF4634.jpeg A555935C-2488-41B4-81A4-4E9CB6E1BE74.jpeg 98EBBF1C-DB5A-4626-90F6-B57A09371930.jpeg FB450C63-B1AB-460E-AA61-49933665A9F5.jpeg 59A4C458-6209-46AF-A134-B7D331D89873.jpeg
    enloe, grumpy32, brianf31 and 15 others like this.
  5. saltflats
    saltflats
    from Missouri
  6. lookin good
  7. AmishMike
    AmishMike
    Looks great. Lots of welding to do
  8. cornfieldcustoms
    cornfieldcustoms
    thanks, lots of welding is nothing i am not used to.
    Stogy, Tman, loudbang and 3 others like this.
  9. AmishMike
    AmishMike
    Even on frame table will u weld continuous or tack & jump around many to avoid putting any twists in frame. I have light weight body frame tacked & to finish without a frame table
  10. cornfieldcustoms
    cornfieldcustoms
    i still move around all over
  11. Stogy
    Stogy
    Thanks for the festive update...fast times are coming together in style @cornfieldcustoms...always a joy to witness...
  12. SEAAIRE354
    SEAAIRE354
    Amazing work. Thanks for the updates.
  13. cornfieldcustoms
    cornfieldcustoms
    thanks man
  14. cornfieldcustoms
    cornfieldcustoms
    Big progress. Gauge pod made, water lines going in, reverse lock out made, switch panel made, chute mount and push bar made. Front suspension all mocked up, steering mocked up, and car on all 4 wheels E4D29ACA-4900-4D5D-8F6C-58275A6643D4.jpeg CC887693-D5AD-47CA-97AF-31B2E8001156.jpeg D9079B03-4252-4DAF-BB72-ACAD7CB5AD9E.jpeg 0302DF65-FF29-45CA-B3AA-853CDC47F7CE.jpeg 2EE3D677-138A-4067-B61D-D6B08B32EAA3.jpeg D2C38339-E8B1-4AB7-A4BC-D877DADCCF81.jpeg 81DC9496-63E9-4403-8AB2-11FFD40DA6BC.jpeg 99EB40BB-39E2-4D0E-8CFE-D1499506FD10.jpeg 63621AC9-987B-4ECC-BB2D-366F9CCB26E8.jpeg F6816341-04B5-45D4-B736-B6277C105516.jpeg 12550C91-6F1E-4934-BD72-38D1BC3091CC.jpeg
  15. Nice engineering. I like the dead perch
    Just Gary, Stogy and loudbang like this.
  16. patsurf
    patsurf
    have you read the old hot rod articles on the summers bros and their golden rod-they would maybe be jealous of your work!--beauty!!
  17. cornfieldcustoms
    cornfieldcustoms
    thanks guys
    loudbang and Stogy like this.
  18. Stogy
    Stogy
    The Art of Engineering and execution of...truly magnificent...Happy New Year Mike...
    The 39 guy and loudbang like this.
  19. cornfieldcustoms
    cornfieldcustoms
    Little update. Got the bump stop mount plate fit up and bump stops in, switches in, and 3 of the 5 gauges in the cluster 97A73C80-E079-41D1-BC93-5A357BEAB774.jpeg 65FFB12E-8BDE-4CC6-90D1-6114DC6157C1.jpeg CB6B22E8-40C1-4B40-A5E7-D1562927BF35.jpeg 932EE21A-588B-4584-A497-059AEB143AB7.jpeg
  20. Your driver restraining panels are mounted to the roll cage very clean and sanitary. Did you make the flat scalloped pieces or are they commercially available? Very nice build, and if the car goes as fast as you’re building it, some people might want to reconsider your cl***!
  21. cornfieldcustoms
    cornfieldcustoms
    I made the ribbon strips to mount the **** pit panels
  22. Dedsoto
    Dedsoto
    from Australia
    following, why'd the perch change it's name?
  23. cornfieldcustoms
    cornfieldcustoms
    a bunch of keyboard warriors on IG told me it would never work. So it is now a Itll Never Work perch
  24. krusty40
    krusty40
    I can"t find my pics right now, but I did this on the 1429 RMR in 2013 when I revised the original cage and steering and added fairings to the front axle. I saw this method used on my favorite 5 window (Jim Busby's). His was like a tuning fork; I just made it a closed "racetrack" for a sealed bearing. Works great, with numerous records to show for it. The only thing was some wear over the seasons, which was corrected by making the racetrack a removeable hardened insert that could be replaced when necessary. Those folks who told you it won't work don't understand how the front suspension works.
    vic
    chryslerfan55, Dedsoto, Stogy and 4 others like this.
  25. Those are the same folks that have no idea how much history that type of locator has.
  26. Malcolm
    Malcolm
    from Nebraska
    Super nice work, Mike! You are moving right along. I also like your dead perch design.
    chryslerfan55, Stogy, Tman and 2 others like this.
  27. DDDenny
    My brain defaults to Busbys' car every time this comes up.
    Stogy and Tman like this.
  28. Same here!
    chryslerfan55, Stogy and loudbang like this.
  29. brianf31
    brianf31
    Amazing engineering and fabrication.
  30. cornfieldcustoms
    cornfieldcustoms
    thanks everyone. the people who keep telling me it wont work are the same ones who forget to breath between bites of their of hot pockets in their moms ba*****t lol
