Technical Anyone have experience peening porous holes shut in aluminum?
Discussion in 'The Hokey Ass Message Board' started by HardcoreZ28, Dec 17, 2021.
  1. David Gersic
    David Gersic
    from DeKalb, IL
    That’s a failed casting. Send it back.
  2. I would say casting flaw. The aluminum or the mold was to cool at the time that case was pored.
    Sad to say , that is a warranty issue.
    Vic
  3. 6sally6
    6sally6
    If good old GM tells you "to-pack-sand"(pun intended) on a replacement.......I would clean with acetone/lacquer thinner and smear in the JB Weld.
    Being on a seam I would worry peening would/could make matters worse.
    The 'leak' you described would NOT be hard to live with if all else fails. IMO
    6sally6
    427 sleeper likes this.
  4. HardcoreZ28
    HardcoreZ28
    Yes.....despite the major setback in ***embling the project a replacement is still my top choice. Like I said earlier though....took 2 months to find this one....not sure they'll fine another is a warehouse somewhere.
    loudbang and kidcampbell71 like this.
  5. pitman
    pitman
    Thanks, a most helpful Thread subject.
  6. indyjps
    indyjps
    Push the issue, defective new part and no other replacement inventory, go for a warranty payout and keep the trans. They don't really want to take it back and fix or s**** it. Make it so it's easier for you to go away than find a new trans in their system. Don't release the one you have until a replacement is physically in front of you at a dealer or distribution warehouse.
    Those stating impregnation, the trans would have to be dis***embled to outer casting only, single setups on impregnation are pricey. Had to deal with it thru work.
  7. stanlow69
    stanlow69
    You might have gotten a seconds ******. Or a product not quite good enough. But ship it anyway. Better than nothing. Try a can of stop leak.
    SS327 and loudbang like this.
  8. greybeard360
    greybeard360
    If GM doesn't want to warranty it. you might think of using one of the windshield carck repair kits. It forces a type of plastic into some pretty small cracks and is should handle whatever heat the trans will generate. Just a thought.
  9. Truckedup
    Truckedup
    OP, just curious, why a new NV3500...You mentioned it's a truck so you need the low first gear?
  10. HardcoreZ28
    HardcoreZ28
    When I was fabbing the truck 8 years ago I picked one up cheap....like 200 bucks. Was going to just freshen it up and go...built my trans tunnel around it. When I tried to freshen it up it turned out to be the older HM290 style and wouldn't come apart easily. It was more cost effective to buy a new one rather than potentially break the HM290 case and pay for a rebuild. The newer version also has a single shift rail versus multiple. In retrospect another trans would have been a better choice but not redoing my trans tunnel and driveshaft now that it's all painted.
  11. HardcoreZ28
    HardcoreZ28
    I've called all over the country this morning and this seems to have been the last transmission available from GM anywhere in the US.
  12. gene-koning
    gene-koning
    That ****s!
    Not a good place to be.
    My concern would be that because the pinhole in on a seem, that it might just be the tip of the iceberg.
    You could seal it with epoxy and never have another problem, or the vibration it may face may split the bottom of the case in half.
    Are they talking about any kind of discount for you to keep it?
    What are the chances of finding a new, or a good used case and swapping the new guts into it?
  13. HardcoreZ28
    HardcoreZ28
    I used GMPartsGiant.com for the trans and they are deciding if I could do a return but they are trying to state that it's an electrical part since it has sensors for the speedo output and reverse lights which we all know is BS. If they do authorize a return that still leaves me with no trans.
    I'm hoping GM will discount me in some way. But not sure how to go about actually talking to someone about it. After that if I epoxy it I may try to eventually pick up a good core for cheap and just hold it in case this case let's go.
  14. Mike Lawless
    Mike Lawless
    I had a trans case in my drag racer with nearly the same problem. Drained the oil, cleaned it really good with brake clean, let it sit for a few days, cleaned it again, then jammed JB weld into the area, forcing into the area the best I could. Ran it for several years, until the case was replaced. And, it was not replaced because of the leak, but because the bearing bores had become loose.
    Good luck with it.
    irishsteve and HardcoreZ28 like this.
  15. WOW ... talk about trying their absolute hardest to weasel out of accepting the apparent fact that they sold a flawed product. That is both disgusting and pathetic.
  16. Just a thought if GM blows you off completely.and it dips enough that you cant live with it......Pull the trans,and roll it over. Degrease the leak area then drill over lapping 1/8 inch holes about 3/16 inch deep being careful not to go through.Now you have a groove say 1 inch long. Clean again with brake clean then fill with JB weld.
  17. Jmountainjr
    Jmountainjr
    Yes, kind of ****s. You probably don't have much to loose trying the peen and JB Weld. However, I personally would get a good fix on it sooner rather than later. Both an epoxy repair and a welding repair require pretty much oil free material to work. Aluminium is porous enough that oil impregnation is the biggest issue in both repairs. And the longer you run it the bigger the issue. And as others have mentioned, you may just be seeing the tip of the ice burg. So I personally I would want the peace of mind and would pull the tail housing off, clean it up, and maybe do some minor exploration surgery with a small die grinder. At that point you will know if the flaw is an epoxy or welding repair and just make it go away. Good luck.
  18. HardcoreZ28
    HardcoreZ28
    Unfortunately there is no tail piece on the trans....it's the whole back of the case. I plan to pull the trans next week and flip it so I know there's no more fluid trying to seep out. Then I'll attempt epoxy. Not what I was hoping for with a brand new trans.
    loudbang and ffr1222k like this.
  19. khead47
    khead47
    I've fixed porous Knucklehead cases with epoxy. Easy peasy, done.
    loudbang and HardcoreZ28 like this.
  20. HardcoreZ28
    HardcoreZ28
  21. blowby
    blowby
    from Nicasio Ca
    First thing I would try is draining it, pull the drive shaft, put a shop vac on the tail shaft, **** some brake clean up there followed by wicking loc***e.
  22. Ebbsspeed
    Ebbsspeed
    If GM flakes out on you: Drill a tiny hole, tap it for a short 6-32 screw, smear some sealer on it and screw it in. Or better yet, I'd be real tempted to spend a couple hours dis***embling it enough to where I could drill a hole directly into that pore and all the way through the case. Inspect the hole to see if there is indeed a larger flaw. Tap for an 1/8" or 1/4" magnetic pipe plug, screw it in and run it. Extra drain hole, and a magnet to collect steel "dust" that always shows up in a transmission.
  23. 2OLD2FAST
    2OLD2FAST
    from illinois
    I have had success with both epoxy & low temp aluminum " weld" in non stress situations like this . A little exploring with a small rotary file might shed some light on the problem .
  24. HardcoreZ28
    HardcoreZ28
    Just a quick update on the GM side of things....got the runaround all day yesterday and was basically told because GM Parts Giant isn't a direct distributor for them the factory warranty on the trans doesn't apply...which sounds like BS.
    Still sounds like I may be able to ship the trans back to the supplier for a refund but again that leaves me without a replacement trans. I'm fairly confident I can seal this up but still don't think I should be paying full price for a leaky transmission.
  25. Ebbsspeed
    Ebbsspeed
    Before you ship it back, draw a big black sharpie circle around that pinhole so the next guy that gets the trans might look it over closely to see why that circle is there.
    Truck64 and loudbang like this.
  26. gregsmy
    gregsmy
    from Florida
    I have fixed similar issues with epoxy (JB Weld) as well. Like you know it has to be really clean to bond. One thing I also figured out is if you heat up the case area slightly with a heat gun, the epoxy flows and fills in better.
    HardcoreZ28 and loudbang like this.
  27. If nothing else did you use a credit card? You can always dispute the charge.Sounds like GM deserves it.
    HardcoreZ28 likes this.
  28. HardcoreZ28
    HardcoreZ28
    I did but the vendor isn't a direct GM affiliate
  29. rjordan
    rjordan
    Ebbspeeds idea is the best. I have drilled and tapped many leaks to stop them. It will be permanent and you won't have to remove the trans.
  30. stanlow69
    stanlow69
    I`d just return it and change transmissions. If you have trouble down the road. You are back to square one again. What was the cost of the ******? Just because you have a part, doesn`t mean you should use it. Think long term.
