Anyone have pictures of a c-notch on a 56 f-100?
Discussion in 'The Hokey Ass Message Board' started by Slick mo fo, Aug 14, 2006.
  1. Slick mo fo
    Slick mo fo
    from San Diego
    Going to be c-notching the truck in the next few days and trying to make a plan.
    Should I buy some pre-fabb'ed or fab it up?
    If anybody has pix of this it be cool.
  2. Slick mo fo
    Slick mo fo
    from San Diego
    Sorry, gotta bump this back to the top 'cause I know one of you has some pictures. And or some tips.
    One of the question i have is- will the frame need any extra support over the top of the notch?
  3. bcarlson
    bcarlson
    I can give you pictures of the stock frame where the c-notch will go... ;)
    bttt for a fellow F-100-er.
    Ben
  4. Killer
    Killer
  5. Killer
    Killer
    not if you box the inside of the frame around the c and use somethng substantial for your notch... I use schedule 40 pipe...
  6. Slick mo fo
    Slick mo fo
    from San Diego
    I was planning on boxing the inside. Do you have a picture of the inside part of your notch?
    I noticed you angled your shocks forward. I've seen so many variations and angles. How does it ride?
    I was planning on straight over the axle but angled in a few degrees on the top mounts, and the bottom mounted to the U-bolt plate.
  7. Slick mo fo
    Slick mo fo
    from San Diego
    Here's how it ended up.
    Thanks for all the tips.
  8. bcarlson
    bcarlson
    Looks good to me... so, what does the rest of your truck look like?
    Ben
