Projects New Project
Discussion in 'Traditional Hot Rods' started by Jim Casey, Dec 14, 2021.
  1. AHotRod
    AHotRod
    Hot Rod Coupes RULE
    Lil32 and Jim Casey like this.
  2. alchemy
    alchemy
    I'm building a T touring and have the car registered with the number on the side of the original block. That car won't use that block, but I'm going to stick the bare block in the corner of the garage forever so nobody else will use the number. If I ever get called on it I can at least show them that I have the original engine in my possession.
  3. Lil32
    Lil32
    welcome from Aussie
    Jim Casey likes this.
  4. NashRodMan
    NashRodMan
    Cool car and welcome to the HAMB. Read that book and keep the original frame, just modify as it says in the book.. It'll save yo a ton of headaches. Tardel has other good book too including a step by step, with pics, for putting a V8 in one.
  5. Bill Rinaldi
    Bill Rinaldi
    Welcome to the HAMB-- Don't let everyones opinion scare you, we're actually a pretty good bunch. That is solid advice about the books. It appears you've got a few followers of your build, my self included, out of curiosity, what are you intending to do to that very pretty coupe? It could be built any number of ways and if the body is as solid as it appears, you've got a good advantage. Good luck and please keep us posted. Bill Rinaldi
    Jim Casey and pprather like this.
  6. Jim Casey
    Jim Casey
    Thanks Bill for the welcome. The body is really very solid. Just needs a couple old repairs redone. I am definitely going to keep the body stock with full fenders and running boards. After reading all the great suggestions from all. I’ve decided to purchase a new ch***is. I had a person make me a very nice offer for the original ch***is and complete drive train. It made the decision much easier. Jim
  7. Jacksmith
    Jacksmith
    from Aridzona
    Hmmm... '40 steel wheels, bigs 'n' littles, dropped axle, souped flat V-8, black fenders, full tank of fuel... you're set! Welcome aboard!
  8. Jim Casey
    Jim Casey
    Sounds good. Thanks for the welcome
