Projects FORD VEDETTE '53 Kustom from FRANCE
Discussion in 'Traditional Customs' started by VEDETTE, Oct 17, 2010.
  1. VEDETTE
    VEDETTE
    from FRANCE
    Soon the filler...
    For my Pontiac 59 trim, I can’t find a welder who can weld.. I’ll try an invisible binding system..
  2. chrisp
    chrisp
    Is it stainless steel?
    Stogy likes this.
  3. VEDETTE
    VEDETTE
    from FRANCE
    Inox oui..
    Stogy likes this.
  4. Stogy
    Stogy
    It's really taking shape @VEDETTE...what other doors...:p
    chryslerfan55 and VEDETTE like this.
  5. chrisp
    chrisp
    So what is the problem with welding 0.5mm stainless steel? You didn't talk to the right welder.
  6. VEDETTE
    VEDETTE
    from FRANCE
    Faut trouver un soudeur super experimenté alors!! moi j'en connais pas.
    Déja quand je lis le commentaire d'un gars sur un autre forum : :confused:
    "- I have welded many thin stainless trims and its not easy besides the fact they are usually lower grade stainless (magnetic) , they still dont rust if kept clean but more modern stainless have different higher grade alloys and that usually result in a slightly different “color” of the polished stainless in the weld . This means the added welding-rod needs to be same grade stainless as the sidetrims . I have both tried MIG and TIG welding and I have to discourage MIG-welding , partly because it splatter molten metal that can stick to the trim and its very hard to not melt thru = the trim needs to be protected on both sides of the weld for this reason even for TIG welding . On the other hand TIG-welding also needs to be cranked down to not melt thru and the weld puddle oxidize on the back side where the melted puddle is exposed to air . When the pros weld stainless pipe they use a secondary argon source which protect the back side but I never tried that … "
    Stogy and chryslerfan55 like this.
  7. chrisp
    chrisp
    Quand on soude de l'inox, il faut systématiquement protéger l'arrière de la soudure avec de l'argon pour éviter le rochage, il y aura obligatoirement une différence de teinte puisque tu ne peux pas avoir un métal d'apport identique aux baguettes. Ensuite il faut p***ivé la soudure pour pas que ça rouille. Les soudeurs pro en général font du tuyautage, de la rambarde et du portail : c'est pas eux qu'il faut aller voir, faut trouver un qui fait de l'alimentaire, de l'échappement inox ou de la restauration de voitures mais qui connaît la soudure sur inox très fin (moins facile à trouver que les 2 autres)
    Alternativement comme tu dis, insérer un clip long pour maintenir l'alignement avec une ou deux vis à cet endroit si les baguettes sont parfaitement coupées ça se ne verra quasiment pas. Ce sera beaucoup moins cher aussi.
    chryslerfan55, FlatJan and VEDETTE like this.
  8. VEDETTE
    VEDETTE
    from FRANCE
    C'est ce que je vais faire! ;)
  9. VEDETTE
    VEDETTE
    from FRANCE
    Finally once out I don’t like it! the door is too short :(
    I go back to work and pull back the pillar by 7 cm !
    It’s much better this way! :cool:
  10. James D
    James D
    Ah man....that's not ideal. Well, at least you only did one door, not both. :(
    VEDETTE and Stogy like this.
  11. choptop40
    choptop40
    tres bien mon amis....
  12. Stogy
    Stogy
    If it was easy anyone could do it...we are our own most serious critic so yeah Vedette was talking to you...and you responded as difficult as the hill is to climb...still looks wonderful...
    I just thought of something you may have or already have thought through...
    Does the front seat tilt / hinge forward for p***engers to access?
  13. VEDETTE
    VEDETTE
    from FRANCE
    No stogy.. I’ll change the seat so that it can tilt or install another one.. but it’s not a problem I have all the time to think about it! ;)
    Peanut 1959, chryslerfan55 and Stogy like this.
  14. Stogy
    Stogy
    Awesome @VEDETTE...Happy Holidays to you and yours...;)
  15. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    Amazing craftsmanship! The Vedette was built by Simca and the V8 engines they used originally were the French Ford V8 60. The V8 60 was known for it's lack of power in the US but the French Vedettes that used their version of it were scary enough to make me need to change my shorts. My neighbor had one in the '50s. The kid would only drive that poor thing wide open. I only rode with him once in that thing. :eek:
  16. Great photos, the custom is nice too.
    Gambler 1962, Stogy and VEDETTE like this.
  17. VEDETTE
    VEDETTE
    from FRANCE
    :p First version!
  18. VEDETTE
    VEDETTE
    from FRANCE
    Moving forward! Slowly but surely..
    Dean Lowe, Hombre, James D and 6 others like this.
  19. gsnort
    gsnort
    Going forward is the way to go; sometimes I find myself going in reverse or remaining static. However, I prefer forward even though I am 82 years old.
    Outback, James D, Stogy and 3 others like this.
  20. James D
    James D
    Looks perfect!
    Stogy, chryslerfan55 and VEDETTE like this.
  21. VEDETTE
    VEDETTE
    from FRANCE
    Painted interior
    soon spring to paint all this!
    Outback, Dean Lowe, Stogy and 3 others like this.
  22. James D
    James D
    Fantastic!
  23. VEDETTE
    VEDETTE
    from FRANCE
    Successful cutting and connection trim..
  24. j hansen
    j hansen
  25. krusty40
    krusty40
    Excellent!
    vic
  26. Peanut 1959
    Peanut 1959
    Tres magnifique!
  27. VEDETTE
    VEDETTE
    from FRANCE
    I’m running late!
    Stogy, James D, chrisp and 4 others like this.
  28. gsnort
    gsnort
    As I have come to expect from your work: Beautiful!!!
  29. Beautiful work @VEDETTE . And you’re not late, you’re just early for the next project. lol
  30. Outback
    Outback
    from NE Vic, Oz
    Wow! have had a good read back, as I missed this thread.
    I was impressed with the first version & all the changes have left this car getting better & better! Well done!
    chryslerfan55, Stogy and VEDETTE like this.
