Projects All in a day's work..
Discussion in 'The Hokey Ass Message Board' started by J.Fishbeck, Nov 8, 2021.
  1. Wasn't worth restoring
  2. Things I did today..
    Worked on a 27'T rdstr pick up
    Gapped the front sheetmetal on a 61 Bubbletop (thats the 59 coupe under the blue tarp)
    Reinstalled the rebuilt alternator on a 250K$ LS powered 57 Convertible. Look at the wonky angle on that steering shaft.
    And welding holes closed, on 69 Camaro.
    20211221_112005.jpg 20211221_114445.jpg 20211221_123440.jpg 20211221_123454.jpg 20211221_130946.jpg 20211221_135430.jpg 20211221_153139.jpg
    TFoch, chryslerfan55, Stogy and 2 others like this.
  3. It's sprrrring again..
    I never would've guessed this works..
    fauj, juan motime, brEad and 10 others like this.
  4. I didn't take the engine and trans out, so I don't know how many gaskets it's going to take, to get the right clearances. Drilled out the broken bolts and tapped the 50 Cheevy 2dr sedan's man-well trans, output shaft, housing. Waiting on parts. Should be here, tomorrow.
    Finally sold the 57 150, as well.. finally!
    20211228_174041.jpg 20211227_141551.jpg 20211228_135216.jpg 20211228_134106.jpg Screenshot_20211228-134654_Samsung Internet.jpg Screenshot_20211228-134720_Samsung Internet.jpg
  5. First time dealing with a 6cyl an enclosed driveline. I have a better idea now, why the design was s****ped. The T5 / G Body 3rd member swap, makes a lot of sense, for sure. You can keep that "all original" garbage
    50 Chevy 2dr sdn ..
    brEad, Rolleiflex, Stan Back and 4 others like this.
  6. Pictures of pictures, at Norm's
    20220110_110939.jpg 20220110_110946.jpg 20220110_111001.jpg 20220110_111014.jpg 20220110_113716.jpg 20220110_113642.jpg 20220110_111021.jpg
  7. Fortunateson
    Fortunateson
    “Wasn’t worth restoring” is an interesting comment. The key word being “worth” which can be calculated in a variety of ways. If you just want to restore and then flip a vehicle than that may be true. But not everything in this world is measured in dollars and sense. I have the last car my dad had ordered. It’s a four door ‘69 LTD with a 390 c6 combo. To me it’s is worth it because it was my dad’s and we did a lot of trailering with it when I was young. I also have my wife’s grandfathers ‘46 Chev Fleetmaster four door which he bought new after the war which was a bit of a feat around here. A couple of others that some may not think are worth it but that’s always debatable.
    Now I do have four very desirable cars that will definitely be worth it in terms of dollars. Everything is relative I suppose...
  8. chryslerfan55, Algoma56 and loudbang like this.
  9. Where I come from, 4drs are parts cars. Long beds, are work trucks.
    But to each their own. I get that
  10. 57JoeFoMoPar
    57JoeFoMoPar
    Same. Eventhough I've always preferred the look of a long bed truck. Long and low. The fact that they're also more functional was jut a bonus.
    Big mike 1968 and guthriesmith like this.
  11. I've always thought long beds, look better raised up, and short beds look better in the weeds..
    rattlecanrods, Carter and loudbang like this.
  12. Fortunateson
    Fortunateson
    Didn’t you pay for the optional splines?
  13. I need to learn mandarin, I guess
  14. My sister is mandarin, what do you mean by that?
    i7083, chryslerfan55 and J.Fishbeck like this.
  15. up here, most old cars are treated as cl***ics, even if its the most undesirable rotted out piece of garbage, even 4 doors.
  16. HOTRODPRIMER
    HOTRODPRIMER
  17. chryslerfan55 and loudbang like this.
  18. Let's see if this works, for me..
  19. My back was killing me, this day. I needed to stay seated. The video ends, because I couldn't hold the camera and plug my ears, at the same time. IT WAS LOUD, to say the least..
  20. 210superair
    210superair
    from Michigan
    Sweet Jay-sus! That thing is LOUD. Love it...
  21. Today, was one of those days, when you get to see your ideas set in motion.
    Norm Porter's 27 Rdstr PU
    Made a pushrod, to replace the bent one
    Radiused the 4 support brackets, on the radius rod.
    And while the outside temperature, is warmer than 65°, I permanently attached the aluminum bracket, to the lower rear panel of the rdstrs pu body.
  22. With that rear panel, now being removable, it's a lot easier to take the body on & off.
    Going to the Winternationals, today. The winds have died down, so it should be quite thee adventure.
  23. The one run, I was able to capture.
    juan motime, loudbang and Stan Back like this.
  24. The trunk floor is in.
    Gas tank reinforcement braces, are on.
    Repaired the rust on the wheel well an inner reinforcement panel.
    Then installed the qtr pnl.
    20220301_133313.jpg 20220301_145144.jpg 20220302_154026.jpg 20220303_160831.jpg 20220304_135555.jpg
    Started on the psngr side..
    20220308_132351.jpg 20220308_132357.jpg 20220308_132400.jpg 20220308_132400.jpg 20220308_141220.jpg 20220308_145352.jpg
    brEad, guthriesmith and loudbang like this.
  25. I am able to work on the roadster, a little less than 2hrs a day. Today I was able to get back on the floor patterns. Still have some figurin' to do. Norm mentioned he thought the tunnel be made in 3 different pieces. I think it looks better, this way.
    Edit: that piece laying on the driveline tunnel, fits into the tunnel, up to trans hump..
    27 T rdstr pick up
    brEad and guthriesmith like this.
  26. A little tape, an it looks like I know what Im doing, again.
    brEad likes this.
  27. Pictures 1 & 2 are my of my first attempt, fumbling around trying not blow holes in the 3003 .063 aluminium sheet.
    3 & 4 are of my second humble attempt at stacking dimes, while GAS WELDING aluminium.(they'll say it can't be done) Jocko taught Doug Kruze, Kruze taught Norm Porter. Norm taught me. My smile is from ear to ear, right now
    Carter and brEad like this.
  28. So this showed up today.
    Some jobs are funner than others
    brEad and LOST ANGEL like this.
  29. This 50Merc was wrecked in the rear. So Al had Marcel Deley make a whole new rear section, and he welded it on. I finished up any welding it needed and m***aged the quarters, to fit the trunk lid. Which you couldn't open, because 'whomever' had slathered gallons of bondo on both, to smooooth things out. The cat walk, it'll be going back to its original design instead, of the wonky no-flow jobby on there, now. I'll be shaving the gas lid door and frenching the taillights. I just finished the buckets to use the stock taillights.
    The day it showed up.
    I've repaired the driver qtr and C pillar. I have to finish the rounded corners on the decklid..
