Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. mgtstumpy
    mgtstumpy
    The painter is making progress
    Joe Blow, 40two, Lil32 and 11 others like this.
  2. mgtstumpy
    mgtstumpy
    Only needs a clear coat now 263976951_618606429464695_9113360121630531296_n.jpg 264687015_958713405061978_7515333162683085793_n.jpg
  3. vtwhead
    vtwhead
    Always great to see color going on. Looks like it laid down nice and smooth.
    Lil32 and mgtstumpy like this.
  4. mgtstumpy
    mgtstumpy
    Final installment, very happy with outcome Resized_20211221_195234.jpeg Resized_20211221_195222.jpeg Resized_20211221_195214.jpeg Resized_20211221_195253.jpeg
    Dave Mc, 31Dodger, Joe Blow and 17 others like this.
  5. j hansen
    j hansen
  6. lothiandon1940 likes this.
  7. j hansen
    j hansen
    Just some square tubes,40x40x4mm Skärmavbild 2021-12-22 kl. 08.28.02.png IMG_9161.jpeg IMG_9163.jpeg
    phelan9251, Joe Blow, Blues4U and 9 others like this.
  8. 1930artdeco
    1930artdeco
    from Lynden, Wa
    I torqued the heads down on my 312 and put tape all around in prep for paint. Hung the tank yesterday.
    Lil32 and chryslerfan55 like this.
  9. chryslerfan55 likes this.
  10. j hansen
    j hansen
    Some pics would be nice:)
    TA DAD and chryslerfan55 like this.
  11. 1930artdeco
    1930artdeco
    from Lynden, Wa
    here you go. Slowly working the engine over-very slowly. It is cold out in that garage. With the door open for light.
  12. Hamtown Al
    Hamtown Al
    I'm pleased to report that I got the oldest member of the fleet out of the garage and took it for a drive and a drink!!
    It won it's first Best Engineered award at the Nats South in 1980 right after Mike Wiley, the owner and builder, got it on the road.
    It has been around for a long time and I still get a thrill out of driving the car!
    Just so special... not many are chopped 5" and SHORTENED 4"! That, coupled with the big block with a chromed tunnel ram; along with the big quick change that my pal, Bobby Built, and I added make it truly one of a kind. Somehow it got on the cover of Rod Action and Popular Hot Rodding at the same time! It had to be special to do that.
    Mike had a heck of an eye! Tis perfect in my view.;):)
    I still feel honored to be the current caretaker of Mike's car.:)
  13. blowby
    blowby
    from Nicasio Ca
    That's neat, let's see a side shot
    Hamtown Al likes this.
  14. Hamtown Al
    Hamtown Al
    ^^Thanks but Mike gets the credit.
    Wheels not so hamb friendly so here's an older picture with some moons... not the best picture but better than none.;):D
  15. fastcar1953
    fastcar1953
    Dropped the top and went for a cruise. 270032636_5011425602215019_1919293756812099753_n.jpg
    Dave Mc, Joe Blow, Blues4U and 7 others like this.
  16. saltflats
    saltflats
    from Missouri
    Did some dis***emble. :)
    Dave Mc, Joe Blow, lumpy 63 and 8 others like this.
  17. Shitbox
    Shitbox
    from Nor Cal
    Termite abatement.
  18. High test 63
    High test 63
    That's bad***!
    chryslerfan55 and impala4speed like this.
  19. TA DAD
    TA DAD
    from NC
    I pulled my truck out of the shop after 5 years and almost ready to go down the road in it. IMG_0096 (2).JPG IMG_0097 (2).JPG
  20. 1930artdeco
    1930artdeco
    from Lynden, Wa
    While working on the heater and f cutting the fuel line out I discovered 6 more bullet holes. How the hell did people do these things……The big holes are for AC.
    TA DAD and Lil32 like this.
  21. j hansen
    j hansen
    TA DAD likes this.
  22. 64Belvedere
    64Belvedere
    from Alabama
    Not super technical but I fixed a transmission cooler problem I was having. I had originally mounted the cooler with the ports facing down and had a problem with trapped air. The fluid was just running thru the first one or two rows of the cooler and back to the transmission without much cooling. So I flipped the cooler around to put the ports on top, and bent up a set of hard lines that run around the side of the radiator and connect up to the original factory lines underneath. The trans temps are now much better and I even managed to get the hard lines bent correctly on the first try (which never happens for me).
    Joe Blow, 61Cruiser, Blues4U and 6 others like this.
  23. jeepster
    jeepster
    from wisconsin
    Modified the shifter detent on a GM floor shifter, to replace the Lokar shifter in my Willys coupe project.
    Joe Blow, mgtstumpy, loudbang and 5 others like this.
  24. Bjorn Wilsson
    Bjorn Wilsson
    Splitting the roof takes time. I'm using a small grinder with a 75x1mm cutting disc, and a.... I dont know what they are called in English , but in Sweden we call them Multimaster (multi purpose machine ??). Anyway I had a new blade from Bosch with Carbide that work on metal and spotwelds. 017.jpg
    RICH B, Joe Blow, mgtstumpy and 6 others like this.
  25. 65pacecar
    65pacecar
    from KY, AZ
    Emblem installation. 20210928_183015.jpg 20210928_182946.jpg 20210928_182952.jpg
    Joe Blow, TA DAD, loudbang and 9 others like this.
  26. j hansen
    j hansen
    Why are you splitting the roof?
  27. X38
    X38
    To replace rain gutters?
  28. Bjorn Wilsson
    Bjorn Wilsson
    Yes Iforgot to tell you the rain .gutters are rusty. Got new ones from Dennis Carpenter.
  29. mgtstumpy
    mgtstumpy
    Body is finally back home after paint and about ready to be dropped onto the frame. I still need to finish the brakes on the 35 and get it off the hoist so I can do the header gasket on the Fairlane. 270119721_661215671920001_1676781046466682201_n.jpg
    40two, Joe Blow, 210superair and 13 others like this.
  30. SEAAIRE354
    SEAAIRE354
    Finally got back in the garage for a while to continue in my firewall flip and me being me decided that I needed to then reverse the stamping so it was going in the original direction. I still have a ways to go and it’s not perfect yet but I’m moving forward finally. Went to the fortune teller and she said there’s a lot of high build primer in my future. 14051B56-44A9-4A47-8D29-350457A665B4.jpeg 14051B56-44A9-4A47-8D29-350457A665B4.jpeg A9898A5B-0F9E-4EC0-95F3-F8BDBFC2BC01.jpeg
    phelan9251, Joe Blow, LAROKE and 8 others like this.
