Technical Building a new Winfield...
Discussion in 'The Hokey Ass Message Board' started by Kevin Pharis, Nov 1, 2020.
  1. noboD
    noboD
    So when did your relatives stop using Ferrous and went to Pharis?
    Stogy, tomkelly88 and loudbang like this.
  2. ... on his day off :D
    Stogy and loudbang like this.
  3. fiveohnick2932
    fiveohnick2932
    from Napa, Ca.
  4. Kevin Pharis
    Kevin Pharis
    from Califunny
    Getting closer...
    CF768ED0-833E-4B88-A71C-8BF6F370C623.jpeg B63664CC-0836-4AFF-A2AB-9A868C1CFB50.jpeg
    I hope to have one of these throttle barrels finished and able to run by the end of the weekend...:D
  5. Kevin Pharis
    Kevin Pharis
    from Califunny
  6. Kevin Pharis
    Kevin Pharis
    from Califunny
    Can almost hear it runnin!:D
  7. Kevin Pharis
    Kevin Pharis
    from Califunny
    DD37DAD6-FF8F-4B6B-AF74-45AEA5AB4026.jpeg 21AD4201-BBAF-498A-B304-02BE67C1A9A9.jpeg
    Running good! Will finish the linkage and do some road testing later this weekend...:D:D:D
    James D, SS327, flathead 37 and 25 others like this.
  8. elgringo71
    elgringo71
    Congratulations, that’s when you know that you did a good job
    41 GMC K-18, Stogy and loudbang like this.
  9. slim38
    slim38
    from Sudan TX
    Heck yeah! Really nice work
  10. tubman
    tubman
    Congratulations! There are times when I cannot believe what I see on this board.
    This is one of them.
    41 GMC K-18, Stogy, RodStRace and 2 others like this.
  11. Kevin Pharis
    Kevin Pharis
    from Califunny
    This was the best Christmas present ever!!!!
    It took a few tries to get the cold motor warmed up and idling, then a few more tries to ensure that I was idling on the idle circuit. Then after a bit of intermediate circuit adjustment, the motor was responsive and smooth. The spray bars were distributing fuel across their full length, and the accelerator wells were obviously dumping fuel as designed.
    I am one happy grinch!!
  12. j hansen
    j hansen
  13. Kevin Pharis
    Kevin Pharis
    from Califunny
    Looking back at some ol pics tonite... looks like it was about 3 years ago that I started trying to piece together a pair of Winfield S-B downdraft carbs... and bout a year and a half since I realized that I would need to go “all in” to get exactly what I wanted.
  14. brading
    brading
    Superb work there.
    Stogy, fauj and loudbang like this.
  15. loudbang
    It's great to see all your excellent work came to fruition. Congratulations. :)
  16. TFoch
    TFoch
    Congrats! Great accomplishment!
  17. nrgwizard
    nrgwizard
    from Minn. uSA
    Kevin;
    That rocks. Very nice job.
    Marcus...
  18. Buckster
    Buckster
    The way I understand the manufacturing of the parts you had to build a CAD file of each part & do an ***embly of those files to ensure each piece fit-right?
  19. Kevin Pharis
    Kevin Pharis
    from Califunny
    Oooooooh yeah.... many many hours of design, and countless fit checks prior to starting any machine work
  20. elgringo71
    elgringo71
    You really did a fantastic job
    Stogy, loudbang and fauj like this.
  21. noboD
    noboD
    Amen to that.
  22. Kevin Pharis
    Kevin Pharis
    from Califunny
    A few laps around the block and a few adjustments to the high speed needle, and the Fronty T is runnin just fine!
    Now it’s time to make the flow bench adapter and get some real data...:D
    Outback, 41 GMC K-18, TFoch and 10 others like this.
  23. Kevin Pharis
    Kevin Pharis
    from Califunny
    Flow bench adapter... DUN!!!
  24. grumpy gaby 2
    grumpy gaby 2
    Kevin you are at a level of excellence that very very few men can obtain!
  25. Stogy
    Stogy
    Machinists are incredible...this is a big salute to your incredible training coupled with your mechanical sense...genius
    I know how happy you are with the achievements made here...we share in that enthusiasm...its almost as if you were back in the Winfield design room pumping out prototypes...
    It certainly gives one an appreciation for the knowledge that was involved in creating these limit pushers of the Yesteryear...Congratulations @Kevin Pharis
  26. Kevin Pharis
    Kevin Pharis
    from Califunny
    153 cfm!!!
    Bout the same size as a Stromberg 97
  27. elgringo71
    elgringo71
    That’s quite a bit. Congratulations
  28. Kevin Pharis
    Kevin Pharis
    from Califunny
    In all honesty... I was expecting bout 100 cfm. Now I’m beginning to wonder if my T can handle 2 of em...?! Oh well, I can always keep em from opening all the way;)
  29. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    nice
    Did you flow it at 3 in. hg. depression?
    loudbang and Carter like this.
  30. Kevin Pharis
    Kevin Pharis
    from Califunny
    Sure did! Well I didn’t... Bob at CC did;)
