Hot Rods Radiator in the rear
Discussion in 'The Hokey Ass Message Board' started by Frames, Dec 26, 2021.
  1. Frames
    Frames
    454 radiator. 2 fans. S/S tubes inside the frame rails. Runs cool. All cooling tube conn 2014-07-14 09.41.20.jpg 2014-07-14 09.41.22-1.jpg 2014-07-14 09.41.22-2.jpg 2014-07-17 15.32.22-1.jpg 2014-07-21 10.20.18.jpg 2014-07-21 10.20.22.jpg 2014-07-21 10.20.26.jpg 2014-10-09 17.17.58.jpg ections double clamped and re tightened after 1st trip. 350/350. LOW marine intake. Sectioned oil pan. Custom rails with 1 " radius on the bottom. Dropped floor. 201 Halibrand.
    kasselyn29, GuyW, jimgoetz and 23 others like this.
  2. Frames
    Frames
  3. drtrcrV-8
    drtrcrV-8
    VERY SLICK!!! Car looks great, mostly because you didn't have to "cobble-up" the front "flow" just to get the radiator to fit in & work at the same time... "Outside the box" thinking : Just love it!!!!
    Greenblade, mad mikey and seb fontana like this.
  4. Fogger
    Fogger
    Very well done and a great solution to maintain cooling and not sacrifice the nose design. Back in the early '80s a friend was installing small blocks into 911 Porsches, radiator in the front, engine in the back. Never overheated and he set the record for a 911 at Riverside Raceway before the Porsche Club had him banned. Good times!!!
  5. Bandit Billy
    Bandit Billy
    Looks very cool and all but it begs the question "Where the hell are you going to put golf clubs in that thing?"
    mrspeedyt, ClarkH, GordonC and 4 others like this.
  6. pitman
    pitman
    Bellisimo! Love the attention to detail..
  7. Budget36
    Budget36
    Fine looking ride!
    Do the fans push or pull?
  8. indyjps
    indyjps
    Sounds like you got it figured out. Looks great.
    We're you able to put a bubble flare on the cooling tubes, I've seen a few different ways to do it.
    Cooling tubes thru the frame rails is a new one to me, usually see them run on inside of frame to help shed heat as you're driving.
    Also interested if the fans push or pull, if pulling, does it vent out behind the radiator box
    mad mikey likes this.
  9. mad mikey
    mad mikey
    Very nice! I am thinking of moving to a rear radiator in the future .
    chevy57dude likes this.
  10. kabinenroller
    kabinenroller
    Check with @racer-x , he has run a system similar to this for quite a while.
  11. evintho
    evintho
    Excellent engineering! Very clean. As asked above.....push or pull fans? Also, where's the gas tank?
    Budget36 likes this.
  12. Stainless. Cool. We used to run copper tubing. Guess the price would be compairable today.
    dana barlow and mad mikey like this.
  13. 6sally6
    6sally6
    NICE!
    Lotsa folks' like it in the rear better'!
    Sleek install.
    Work good in a Charlotte traffic jam?! They can be brutal.
    6sally6
    HOTRODNORSKIE and mad mikey like this.
  14. Jack E/NJ
    Jack E/NJ
    from NJ
    >>>S/S tubes inside the frame rails.>>>
    How about using dual-purpose tubular frame rails instead?
  15. oldiron 440
    oldiron 440
    I don't think radiator fans running so close to your head would be cool. A lot of noise and heat on a slow cruise.
  16. larry k
    larry k
    What is the traditional car that had cooling in the rear ? ? ?
  17. Jack E/NJ
    Jack E/NJ
    from NJ
    No problem. After the rear lid covers the fans, no heat can escape. 8^)
  18. Jack E/NJ
    Jack E/NJ
    from NJ
    >>>What is the traditional car that had cooling in the rear ? ? ?>>>
    Hmmmm? I guess a corvair. Did I guess right?
  19. pitman
    pitman
  20. Tim
    Tim
    from KCMO
    Cool, dig the double dip front axle
  21. AHotRod
    AHotRod
  22. PotvinV8
    PotvinV8
    I like it!
    I'm doing the same on my '29 roadster, but I'll be using an electric water pump (no way to run a mechanical with the Potvin blower). Are you running a thermostat? I can't tell what that chrome thing is where the thermostat would be located and you're obviously pulling the coolant out the side of the intake/heads. I imagine it holds a few quarts more coolant and the lines going back and forth probably help in keeping things cool. I'd like to see the decklid as that's one of the things I'm hesitant on (louvering the decklid) and it looks like you've done just that. Did you do anything under the radiator to promote air flow or are you just relying on the fans?
    gimpyshotrods and mad mikey like this.
  23. Marty Strode
    Marty Strode
    GuyW, AHotRod, Stan Back and 5 others like this.
  24. RmK57
    RmK57
    I wonder in long-term use it would be hard on the water pump? Or if there would be any issues pumping coolant that long of a distance.
  25. 34Phil
    34Phil
    any maker name on that intake?
  26. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I'm diggin' the Rochester 2G two barrel. I run one on my tub (with two dummies for a faux tri-power) and the 302 will absolutely rip the treads off the rear tires (4-spd w/ 9" 4.11 posi).
    Does the 2V do it for you too?
  27. dirt car
    dirt car
    from nebraska
    Jack E/NJ, I believe the Corvair was air cooled was it not ?
  28. Jack E/NJ
    Jack E/NJ
    from NJ
  29. chevy57dude
    chevy57dude
    ^Well then, those radiators would be in the front...
    Johnny Gee, dana barlow, X38 and 3 others like this.
  30. twenty8
    twenty8
