Projects 1917/1928/1938 American Lafrance Plymouth V12 Speedster
Discussion in 'The Hokey Ass Message Board' started by animal8324, Nov 17, 2020.
  1. animal8324
    animal8324
    from nj
    Im having troubles sleeping because currently I refer to this a 1938 American Lafrance but feel as though It should be labeled earlier. Would it be wrong of me to refer to it as a 1917 Speedseter with a 1938 AlF V12?
    Or what would you call it?
  2. warhorseracing
    warhorseracing
    from cameron wv
    With your name (animal)and what I have seen in your posts, "The Beast".:D
  3. animal8324
    animal8324
    from nj
    It's nickname is The Beast of the Valley lol
    Boneyard51, Hamtown Al, Stogy and 3 others like this.
  4. j hansen
    j hansen
    It have a sibling, called The Beast of Turin! Skärmavbild 2021-12-27 kl. 18.57.19.png
    VANDENPLAS, spot, Boneyard51 and 13 others like this.
  5. animal8324
    animal8324
    from nj
    Got the front brakes in order tonight. Rebuilt both wheel cylinders. New hoses. New copper single flare brake lines!!! ****ing gorgeousness
  6. warhorseracing
    warhorseracing
    from cameron wv
    Are they plain soft copper or Nicop? I would not trust copper tubing and on any vehicle copper will not p*** a safety inspection. I do not want to see any one hurt due to a brake failure when the copper blows out from pressure and brake pressures can be in excess of 1200 Lbs. Per Square Inch.
  7. 51504bat
    51504bat
    Single flare??
    Boneyard51, loudbang and LWEL9226 like this.
  8. animal8324
    animal8324
    from nj
    They are real copper. The copper nickle didnt look right.
    If i was planning on having this car see any real road service and not have a back up braking system. I wouldnt sacrifice funtion for form.
  9. animal8324
    animal8324
    from nj
    Yup single flare
  10. warhorseracing
    warhorseracing
    from cameron wv
    Thank you Sir. I just wanted to make sure that you were aware of the serious safety issues of using copper. I agree that it will and does look great especially when polished but is and never was designed to hold the kind of pressure that a hydraulic brake system can generate.
  11. noboD
    noboD
    Cunifer tubing looks close to copper but has a higher burst pressure then steel. All early Chrysler Products with hydraulic brakes used copper. Copper is illegal for inspection in PA.
  12. dalesnyder
    dalesnyder
    I just wanted to thank you for doing this thread. Reminds me of another speedster thread by yonharr. Not sure of spelling. It was a great read also..
    Question, the 999 racer back on the first page has no steering wheel, how did that work?
  13. animal8324
    animal8324
    from nj
    Finished the front lines and master resivoir plumbing. She holds the front wheels by hand. I capped the rear line for now. Ill attack them after retro rewind.
    Cunnifer is much lighter in color than copper. If this master cylinder is ever pushed hard enough to build enough pressure to burst this tubing than something else is terribly wrong.
    The 999 had a tiller steering set up. It pointed wright at the drivers chest lol 20211229_195244.jpg
  14. warhorseracing
    warhorseracing
    from cameron wv
    Thank you @animal18324. There is a very big difference between "copper" and "https://cunifer.com/". When you stated "They are real copper." it immediately threw up a safety hazard that I would not want to see you make. Cunifer on the other hand is safe for brake systems and you should be OK as far as your brake system is concerned.
    chryslerfan55 and Thor1 like this.
  15. 51504bat
    51504bat
    Still would be concerned about the single flares for anything but light use/display. but that's JMO.
  16. animal8324
    animal8324
    from nj
    The lines are xopper not cunnifer. The look is more important than reliability to me.
    It's not going to be a daily driver and if I ever attempted something like the great race I would probably make some reliability enhancements such as an all metal fluid resivoir and steel lines.
    That said I will be doing top speed runs and some vintage racing with it.
  17. animal8324
    animal8324
    from nj
    I played around with it running yesterday. She is an absolute beast! I ran it in gear as well to check how much vibration the trans to diff adapter will cause and it seems pretty stable.
  18. animal8324
    animal8324
    from nj
  19. choptop40
    choptop40
    thanks for sharing...a real hot rod...
  20. animal8324
    animal8324
    from nj
    Tank straps are finished
  21. noboD
    noboD
    That thing is really rude. I like it!
    brEad, Boneyard51, Stogy and 2 others like this.
  22. warhorseracing
    warhorseracing
    from cameron wv
    Will those springs on the straps keep the tank secure?
    Overall. It looks marvelous!
    VANDENPLAS, Boneyard51, Stogy and 3 others like this.
  23. animal8324
    animal8324
    from nj
    I hope they hold it securely
  24. 41 GMC K-18
    41 GMC K-18
    That project is really coming along nicely, a cool name painted on it, in a very cool font would be,
    " CHAINED LIGHTNING " I am sure that @Stogy ,could do a really nice mock up via his computer skills, on the back of the cool gas tank !
    Boneyard51 and Stogy like this.
  25. Stogy
    Stogy
    Lookout 911...:confused:...oops I think its 999...:D
  26. Stogy
    Stogy
    If someone else doesn't beat me to it...I'm not at my creative station at the moment...the name is fitting...
    41 GMC K-18 likes this.
  27. 62pan
    62pan
    Love the look but I would suggest taking a little more slack out of that chain. Looks loose enough to jump the teeth.
    Boneyard51 and loudbang like this.
  28. Stogy
    Stogy
    :rolleyes:...;)
    VANDENPLAS, 40two, brEad and 9 others like this.
  29. animal8324
    animal8324
    from nj
    Nice edit!
    It's name is "The Beast of the Valley? Though
    VANDENPLAS, Boneyard51, Thor1 and 2 others like this.
  30. Stogy
    Stogy
