Hot Rods # 10 Track Roadster Build- Marty Strode
Discussion in 'The Hokey Ass Message Board' started by Marty Strode, Jan 24, 2020.
  1. TerrytheK
    TerrytheK
    alanp561, loudbang and Stogy like this.
  2. AmishMike
    AmishMike
    Gas tank looks good. How many gallons? Looks like bolted along side mounts? Love your builds
  3. Marty Strode
    Marty Strode
    Yeah TA, there was quite a selection, from "T" through V-8" power. The track was a little too soft in places, for me to run Ernie's car. Being it was a gift from him, I did what he would have done, kept it parked.
  4. Marty Strode
    Marty Strode
    Terry, Brent's car is #3 of the series, he did a hell of job finishing it. The orange Tub was my personal ride from a decade ago. It was nice to see them together.
    TerrytheK likes this.
  5. Marty Strode
    Marty Strode
    Thanks Mike, the tank is a little over 10 gallons, and has side rail mounts. I am going to get the brake pedal linkage in, this weekend, and it will be ready to leave for a while. Then I can get back on the Olds powered '29 and my own hanging projects for a while. It will be a busy Winter, stay tuned !
  6. Marty Strode
    Marty Strode
    Roughed in the brake linkage on the Puritan today. Will add the gussets and finish it tomorrow. IMG_7929.JPG IMG_7930.JPG IMG_7931.JPG
  7. Marty Strode
    Marty Strode
    Got the Puritan finished today, now back to regular programing, a couple of 29's, and #10 ! IMG_7932.JPG IMG_7933.JPG IMG_7935.JPG
    bymanr, alanp561, brEad and 7 others like this.
  8. Stogy
    Stogy
    Looks awesome Marty...What a unique, low slung Hotrod...
    You made it's day...
    Please let us know how things progress on it as it happens Thanks for sharing this close up with past greatness...
    Thank the owner for giving it the love it deserves...
    Atwater Mike and loudbang like this.
  9. A Boner
    A Boner
    #10 -#10 -#10 -#10 -#10 -#10 -#10 -#10 -#10 -#10!
  10. AmishMike
    AmishMike
    Gas tank on #10 looks much bigger then 10 gallons. Looking way ahead on my runabout/modified I expect smaller tank. Google says 1 gal gas = 231 cubic inches or 2310 for 10 gallons. 10 x 10 x 23 = 2300 Do not have a t turtle deck at hand, yours just looks big
  11. Marty Strode
    Marty Strode
    Mike, I haven't built the tank for #10 yet, the Puritan tank is a little over 10 gallons. However # 10 will get a tank that has a horseshoe shape and will be 10 as well.
  12. Marty Strode
    Marty Strode
    Thanks Stogy, with the engine ready to go, I am sure the owner will have it on the road this Spring, and I will document it's first spinning of the tires.
    bymanr, SR100, Dick Stevens and 2 others like this.
  13. Marty Strode
    Marty Strode
    Well, it's been over a year since I worked on this one, others got in the way. After vacuuming a years worth of dust off the car, and mopping the floor, it time to spend some time on # 10. I had fitted the roll bar, and bent the side bars, and today I trimmed and fitted the side bars. I have a sample tube that made out of exhaust tubing that fits the RH side, with the needed coping. I use it as a baseline to get started, with ink marks showing where to trim. The bandsaw is handy, but a little awkward to use making the rough cuts, however it works OK. After a quick check, and some more ink marks, I use a mop disc on a 4-1/2" Metabo grinder to finish the joints. The next thing will be pulling body and notching the bottom flange on the body, to clear the front mounting brackets. IMG_8130.JPG IMG_8131.JPG IMG_8132.JPG IMG_8133.JPG IMG_8134.JPG IMG_8135.JPG IMG_8129.JPG IMG_8128.JPG
    Tman, brEad, Shadow Creek and 16 others like this.
  14. As always Marty - looks great
    keep us updated
  15. Marty Strode
    Marty Strode
    Sam, I have been wondering about you !
    Stogy likes this.
  16. Old age and medical problems have slowed me down. Still kicking!
  17. alanp561
    alanp561
    Somewhere in the recesses of what's left of my mind, I had this image of you never having to use a ruler. You just used witness sticks and your micro-metric eyeballs to get the results you want. However you do it, you do it extremely well. Thanks for all the lessons I've learned.
  18. Marty Strode
    Marty Strode
    Alan, you are quite the wordsmith, thanks ! It is nice to be back on this project, these are the stages of the build I like the most, bending tubes and doing the aluminum work.
  19. DDDenny
    Marty has done more pipe fitting than many pipefitters!
    I on the other hand have only a little experience, some of it with good results only after trashing some tubing in the process, but, as they say, failures can be the best teacher.
    I will say that achieving perfectly fishmouthed weld joints have been some of the most satisfying things I've done on my projects.
    Now if I could just weld!
    HemiDeuce, Stogy and alanp561 like this.
  20. alanp561
    alanp561
    Too bad I'm not closer. Only people I've not been able to teach to weld were vision impaired or had a pacemaker. I'd just bet that there's somebody close to you could show you how. Mostly, it's practice and getting muscle memory.
  21. Dave G in Gansevoort
    from Upstate NY
    Thanks for the excellent pictures Marty. I've been holding off doing this step on the Whatever project because I couldn't visualize how to get to the frame, and this shows perfectly.
    Just one question: what thickness is the mounting bracket material?
  22. Marty Strode
    Marty Strode
    Dave, Here are the frame brackets for the side bar mounting, I cut them out of 3/16" wall rectangle tubing. Now I am making some 3/16" diamond shaped plates the weld the bar to. IMG_8137.JPG IMG_8138.JPG
  23. Marty Strode
    Marty Strode
    Doug, you probably remember when I used a cutting torch and a 7" body grinder to fit the joints, much easier now.
  24. Dave G in Gansevoort
    from Upstate NY
    Thanks Marty. Great way to get a finished product. I've even got some of the exact size in the short rack. Now I know what I'll be doing this week...
    Stogy, alanp561 and loudbang like this.
  25. CTaulbert
    CTaulbert
    from Detroit
    Marty - I sure enjoy seeing (and learning from) your methods of fabricating!
    kidcampbell71, Stogy, rod1 and 2 others like this.
  26. Marty Strode
    Marty Strode
    Thanks Cory, it's a pleasure to have you looking over my shoulder. I do things as simple as I can, however I am a blacksmith next to you ! I was showing off your coupe to some old hotrodders just yesterday. Hope to meet you in person someday.
    Dick Stevens, kidcampbell71 and Stogy like this.
  27. Marty Strode
    Marty Strode
    Progress report ; I got the side bars fit and tacked in tonight. It required a slight amount of additional bending to hit the centers on the front mounts. Once that was completed, I laid out the bar that will span the distance across the back, to support the seats. The ends have to be curled to get the offset needed. I lay out the centers, and the amount of offset needed, and using a cardboard template that fits the radius of the die I will will be using. The tube will be 1-1/4" with a 3" centerline radius. I should be able to get that bar, bent, fit, and tacked in place in the morning. Then it will be time to mount the seats. IMG_8183.JPG IMG_8190.JPG IMG_8191.JPG IMG_8185.JPG IMG_8186.JPG IMG_8187.JPG IMG_8189.JPG
    brEad, OFT, dwollam and 12 others like this.
  28. Marty Strode
    Marty Strode
    I coped the ends of the 1-1/4" crossbar, using a 1-3/4" hole saw. In this circumstance I don't cut all the way through for safety sake, and break the unused piece off. With it tacked in place, I can now remove the bar and body, and bolt the bar back on, to mount the seats and finish the welding. IMG_8196.JPG IMG_8197.JPG IMG_8199.JPG IMG_8200.JPG IMG_8201.JPG IMG_8203.JPG IMG_8204.JPG IMG_8206.JPG IMG_8209.JPG IMG_8210.JPG IMG_8211.JPG
    Atwater Mike, bymanr, brEad and 13 others like this.
  29. Genius!
    Stogy likes this.
  30. alchemy
    alchemy
    Marty, I wondered why you used such a large access hole and flat mount for the bottom of the main roll hoop? Did you ever consider a slip-in inside bung welded to the frame, so the body access hole is just a round hole and the bar slides over it and attaches with a bolt or two through the side? Or maybe kick the hoops a bit forward in the bottom foot and have them attach all inside the body?
    Or am I being to street roddy?
    brEad likes this.
