Hot Rods Radiator in the rear
Discussion in 'The Hokey Ass Message Board' started by Frames, Dec 26, 2021.
  1. Jack E/NJ
    Jack E/NJ
    from NJ
    Dunno. But it'd seem to be as bad as an idea. Not cool. Especially w/o louvers.
    chevy57dude likes this.
  2. belair
    belair
    FABULOUS sillhouette.
  3. 19Fordy
    19Fordy
    But, will it cool the engine sufficiently?
    dearjose likes this.
  4. 34Phil
    34Phil
    Intake is GM Winters foundry for Chris Craft boats, 4 bbl also. OSCO also made [​IMG]them. Carb tilt is wrong direction and they took water out back as high point in boat. Front is oil fill as was for 283 and 327.
    turboroadster likes this.
  5. MAD MIKE
    MAD MIKE
    from 94577
    Pretty sure the br*** balls in the cabin are taking up the majority of room.
    I would think they are pullers. Most likely some ducting or 'scoop' under the car to pull air up. Looks like the decklid has louvers. Up and out I would think.
    Looks like there is a filler between the heat exchangers and seats.
    Note the exhaust.
    Don't think you are gonna hear much over that :p
    Those curved fan blades can be surprisingly quiet, if the motors are not junk there may be a light hum when activated.
    Looks like late 70's F150 wheels with the squared star grooves, I'm guessing 5-5.5".
    With correct ducting for heat extraction, you can mount a radiator in all sorts of ridiculous areas and it will cool sufficiently enough.
  6. Budget36
    Budget36
    Well, @Frames bumped his first post a minute after it was posted, would be nice if he’d check back in;)
    mad mikey and Chucky like this.
  7. willys36
    willys36
    Similar to how Ed Roth cooled Mysterion!
    AHotRod and turboroadster like this.
  8. Frames
    Frames
    Who has time to golf?
  9. Frames
    Frames
    ****ers
    mad mikey and gimpyshotrods like this.
  10. Bandit Billy
    Bandit Billy
    That's like asking who has time for *** or bourbon or other such nonsense.
    Blue One and mad mikey like this.
  11. DDDenny
    Yeh, what's up with that?
    Just Gary, mad mikey and X38 like this.
  12. It's his M.O.
  13. twenty8
    twenty8
    Comparing your *** life with golf (zzzzzzz...........) may not be a good idea. Paints you in a bad light.....:D:D:D
    2OLD2FAST and Bandit Billy like this.
  14. Bandit Billy
    Bandit Billy
    You never played golf in Vegas with a "par buddy" :cool:
    6sally6 and twenty8 like this.
  15. twenty8
    twenty8
    It did cross my mind that it may not necessarily be an indication of a boring *** life, but rather that you play a wicked version of golf............
    Bandit Billy likes this.
  16. 2OLD2FAST
    2OLD2FAST
    from illinois
    Only for people who like chasing their balls o_O
  17. Dave G in Gansevoort
    from Upstate NY
    OT car but engine in back, radiator in front, stock gm water pump, Fiero v6. Electric fan puller if I remember correctly... got rid of it in 95, so it's been a while since I worked on that. Never overheated, one of the few things gm got right on it.
  18. gimpyshotrods
    gimpyshotrods
    My current build will have two radiators. One on each side, ahead of the rear wheels.
    It will have a third one in the nose, for the intercooler.
  19. X38
    X38
    Fiat X1/9 same. Actually, all those mid engine cars are like that. Ferrari, Lambo, GT40...
  20. Dave G in Gansevoort
    from Upstate NY
    Never had any of those, only the Fiero. Fix it again Tony vs more $$$ than I could afford! Good to dream about however, and the Italian model riding in it with me!
    Hey I can dream, can't I?
  21. Frames
    Frames
    ****ers
  22. Frames
    Frames
    The gas tank is just in front of the radiator. See the 5th picture.
  23. Frames
    Frames
    No name on the manifold but Interceptor Marine made the Y-Block intake so maybe they made this one for the S BC. The Y-Block. Two side draft carbs. Now that's LOW. 1-25-13- 020.jpg
    jimmy six likes this.
  24. Frames
    Frames
    5x5.5. 49-50 Merc. front. And a west coast wheel company was kind enough to use 50 Merc centers when making the rear wheels for me.
  25. Frames
    Frames
    Just rely on the fans only. No thermostat.
  26. Frames
    Frames
    The one Rochester 2GC gets the job done for me. It's the larger one with the fuel inlet in the front. Most most 3 carb set ups use the smaller 2GC with the fuel inlet on the side.
  27. Frames
    Frames
    I am using a high flow pump. Forgot the name. Hard on the pump? In back pumping from down LOW to the up HIGH radiator . Working just fine.
  28. Frames
    Frames
    I think bubbling the stainless steel tubing would require heat and there are an awful lot of connections . I have re-tightened all the connections several times.
  29. Frames
    Frames
    That chrome thing is the oil filler cap.
  30. Frames
    Frames
    What's the question?
