Hot Rods The 'General Mischief Coupe' Model A build
Discussion in 'The Hokey Ass Message Board' started by Jethro, Jan 3, 2020.
  1. Jethro
    Jethro
    Yeah , I'm leaning toward the black.....that looks a little aluminummy , aluminumish , looks not right
    chryslerfan55, loudbang and Stogy like this.
  2. Jethro
    Jethro
  3. Jethro
    Jethro
    Made these yesterday. Machined the ends and used 1/2 in black braided hose for the conduit. 20211108_115501.jpg 20211108_115512.jpg 20211108_115525.jpg
  4. loudbang
    brady1929 and Stogy like this.
  5. 2Blue2
    2Blue2
    I'm enjoying this build.
    Carry on!
  6. Marty Strode
    Marty Strode
    Very sanitary workmanship all the way !
    Junk yard, chryslerfan55 and Stogy like this.
  7. Jethro
    Jethro
    I've been reading the "paint prison" thread and I don't really feel like a prisoner because I can get up and walk away at any time.....which I already have for several different reasons . I guess my situation is more like self admission paint insane asylum . I have been trying to do as close to flawless as I can but my hands keep making flaws. I have sanded and primed , sanded and primed , sanded and primed and sanded to get to this point. I think things are getting straight , my eyes seem to think so but my hand finds a bump or dip every once in a while that need attention. I also wanted to try my new Iwata gun so I painted the dash and dash rail and put a few things together.....jumping the gun a bit I know , just got a wild hair and went with it. 20211111_123634.jpg 20211111_123651.jpg 20211111_123703.jpg 20211111_123717.jpg
  8. Tremendous work! This is fun to follow, keep it going! Thanks for posting.
    Stogy and loudbang like this.
  9. Duke
    Duke
    Looks good! Time to spray it!
  10. Jethro
    Jethro
    Not quite , but soon......maybe
    Stogy, 2Blue2 and loudbang like this.
  11. 2Blue2
    2Blue2
    Dat Dash!
    Wow! Really Nice!
  12. Jethro
    Jethro
    I spent a couple of days straightening and polishing and painting the hubcaps. I have 3 - 39 standard caps and one 36 (I think) I need to find another 39 to complete the set but driving down the road nobody will know the difference.....I hope.
    I like the way they look!
    20211117_125115.jpg 20211117_125248.jpg 20211117_125300.jpg 20211117_125310.jpg
  13. Duke
    Duke
    Looks really good!
  14. brett4christ
    brett4christ
    Or you could find another '36 cap and run matching on each side....
    Stogy, brEad and loudbang like this.
  15. Jethro
    Jethro
    I finally got the 12v generator that the mail had lost during the great flood. The original gennie was 24 volt and waterproof making it really heavy and not suitable. The original pulleys are 7/8 inch wide . Instead of changing all the other pulleys to match the generator I machined the 24 volt pulley to fit the 12v. The shaft size is the same but the pulley is deeper so I had to counterbore it about 3/8 inch to get the nut and washer on. The military pulley is cast iron so it was no problem. The military block uses heavy duty cast iron side motor mounts and the generator mount is attached to the right one. I had to move the generator up and in to clear the shock. I machined the mount so I can adjust the pulley alignment.
    One more little project completed many more to go.
  16. v8flat44
    v8flat44
    That thing is awsome, & it's gonna sound sooo good. Wowza !
    oliver westlund, loudbang and Stogy like this.
  17. Motorwrxs
    Motorwrxs
    Have really enjoyed your build and your high quality work…starting to like those undropped axles more than the dropped! Thanks for sharing.
  18. Stogy
    Stogy
    Such a cool Hotrod...
    brady1929 and loudbang like this.
  19. Stogy
    Stogy
    If I was Jethro I would run them as is and buy a bag of caramels and anyone who picks out the odd duck gets a caramel award...:p...I would of came up dry...:oops:
    @Jethro have you thought of painting in the V8 on the caps a complimentary General Mischievous color?...
  20. Jethro
    Jethro
    Actually Stogy I was thinking red to match the block and a single red pinstripe to follow the reveal on the body.
    I'm thinking black for the body colour. I like the idea of single stage cut and buffed but I've only sprayed BCC . still a few months away before topcoat....I can change my mind
    chryslerfan55, Stogy and loudbang like this.
  21. Stogy
    Stogy
    Jethro I was talking the painting in the V8 Logo on the wheelcovers and on this round I spotted the Caramel popper...:D...I'd paint them anyway but keep your eye out for a match to the set...
  22. dalesnyder
    dalesnyder
    Did you use single stage on your dash?
  23. panhead_pete
    panhead_pete
    If you are worried about imperfections in your paint prep would laying down a guide coat and sanding on that help?
  24. Jethro
    Jethro
    I used Shop line single stage just to try it out. It lays down nice and smooth but I was painting on the horizontal , spraying vertical will be my next challenge
    I always use a guide coat when blocking out my panels. My problem is dirt , I get nibs and bugs so I am working on a few ideas to make my spray area more surgical.
    I'll make sure I have some caramels if I see you around
  25. Jethro
    Jethro
    So it finally warmed up enough outside that I could get my shop warm enough to spray a little more primer. I have already primed and blocked once. I have to do some little fiddly m***aging and filling pinholes and tiny gaps that should keep me busy for a little while. I'm going to let it sit a few weeks before the second block sanding.....that's really hard for an impatient instant gratification type of guy like me but we'll see how it goes.
    20220104_111358.jpg 20220104_111410.jpg 20220104_111421.jpg 20220104_111435.jpg
  26. Looking good!
  27. Malcolm
    Malcolm
    from Nebraska
    Great progress!
  28. Jethro
    Jethro
    Primed and blocked three times , ready to wet sand with 400 then paint.....it's gotta warm up quite a bit before that happens 20220202_141703.jpg 20220202_141724.jpg 20220202_141738.jpg
  29. RMR&C
    RMR&C
    from NW Montana
    Looking good Jeff! Waiting is tough....I've got some painting to do also.
  30. Bandit Billy
    Bandit Billy
    You got skills! I missed the thread until today and enjoyed catching up, kinda like binge watching a couple seasons of baywatch...I need to get out more. Great work, looking forward to the paint so post away.
    Stogy, chryslerfan55 and loudbang like this.
