Wife says I created a monster. Willys Jeep build
Discussion in 'The Antiquated' started by anthony myrick, Apr 22, 2021.
  1. Pulled out parts axle apart. Needed a better spindle but found out it had been updated to u-joint axles. (top)
    Our axle we are building had the Bendix type axle. (Bottom)
    The donor set up also had these locking hubs in great condition
    the u-joint style requires a c-clip on the hub, this c-clip is removed to run the locking hubs
    The Bendix style axles do not need c-clips.
    Anyone with any experience on these?
    The spindle with the u-joint axles has a dinged up bushing
    the side with the Bendix style does not
    these bushings are being replaced.
    Didn’t have a pipe deep enough so we turned the axle around
  3. oldiron 440
    oldiron 440
    I'd like to have a early Jeep for a project, think T bucket with a Jeep body...
    Deuces and anthony myrick like this.
  4. I’ve kicked that around with the leftovers. But not really a t bucket style.
    Use a transverse style from axle moved slightly forward. Low with a rake. Keeps the fenders.
    I have a DJ windshield frame that is shorter than the CJ.
    Deuces and oldiron 440 like this.
    this is a factory 2wd DJ
    Bob the rails, move the front axle slightly forward, lose the step, dropped with a rake.
    Similar style top but lowered about 3-4 inches
  6. 20220118_105705_HDR~2.jpg Something like this.. Ww-2 body sitting on a 2wd (70s) Dj-5 (postal) ch***is.. N-50s on 10" rims & a 4:10 posi .
    Soon to get a 231 V6 & fenderwell headers . (maybe chop the windshield 4-5" to)
  7. 60 year old chiltons
    nice to have spares for reference
    It donated a missing blocking ring
  8. Dave G in Gansevoort
    from Upstate NY
    More pictures! This takes me back to the summer of 72, a CJ5, and a 327...
    But I'm much better now!
    anthony myrick and tractorguy like this.
  9. Anthony- I am to far away from Somewherin Al to be practical, but we have an orchard sprayer in the shed with what I was always told was a jeep engine- maybe a hurricane? Might also have seen them running water pumps for irrigation. Might be an affordable source of an engine. Give me some notice if you are making a pilgrimage to Detroit.
  10. He’s been doing some work on the the jeep.
    Crank turned, engine block ready for the machine shop
    Axles cleaned and new seals.
    His frame had a push bar welded on that they removed about an inch of the frame. We had a donor frame and he swapped over the frame horns.
    2CB61429-E6DA-4DB2-BCF7-301FC1261A8D.jpeg 62EC0786-8477-4140-AEDE-8B9ADCE83EA5.jpeg 278FB731-AEE2-4EDD-BA47-2D1ECA7F92B5.jpeg 570F4564-5D33-44B3-B288-C4CCAAC4B560.jpeg 95134F00-9330-42D6-B121-E5C284D236DE.jpeg
    now removing some homemade engine mount
  11. We’ve also rebuilt the trans and working in the T-case.
    Waiting on some spring shackles and we will ***emble the ch***is.
  12. Just seen this today.
    thanks. We located a rebuildable core.
    I’d love to visit the ford museum one day.
    daylatedollarshort likes this.
  13. Installed the new shackle mounts and replaced the butchered engine mount with a donor piece.
    The frame we are using was 2wd. We’re adding the hitch brace the 2wds didn’t get
    1F86F9C6-775A-4D4E-B069-C98833698453.jpeg CAC6713C-2487-41A9-8A15-EB35299D0A73.jpeg 9F77BF06-BE7B-4C99-9431-4E75B66197FB.jpeg
    alanp561 and Okie Pete like this.
  14. Kids been busy.
    Front axle ***embled. Ch***is sprayed.
    We’ll ***emble the ch***is, give it a scuff-n-clean and shoot it all together.
  15. woodbutcher
    woodbutcher
    :D Looking good there Anthony.As my Grandfather used to say"Slow and sure beats the hell outa quick and dead".
    Good luck.Have fun.Be safe.
    Leo
    Okie Pete and anthony myrick like this.
  16. He’s full time college. Works full time during the summer and does online cl***es. So we work on it as he has time.
  17. verde742
    verde742
  18. Using and extra engine and trans to fit things up.
    making a tab to help a 2a engine plate fit a 3a ch***is.
  19. Got some serious thinking go on
  20. Truckedup
    Truckedup
    8119399530_5e319ec915_c.jpg I always checked the blocker ring gap..The NOS forged have the proper gap
  21. Kerrynzl
    Kerrynzl
    You'd be better off starting with a re-body of a Samurai frame with a flat fender Jeep body.[MB]
    The wheelbase is within 1/2"
    The engine and trans will need moving rearward [the transfer box is stand alone].
    If you were into serious off roading the Sammy frame would out perform most Jeeps even with a 1300 to 1600 engine.
    A stock Sammy hardtop weighs 1900 lbs but with a stripped down Jeep Body it would lose about 400 lbs
  22. You guys are moving right along! I just picked up a ‘44 GPW on an MB ch***is. Such neat little machines!
    Speedy Canuck and anthony myrick like this.
  23. 5D906A8C-888C-4272-B05D-EA0D6CFAF7E7.jpeg B1DA7FAB-C8E6-49DC-A686-8EADCC302441.jpeg D44659A3-1E6B-4FFE-A8D6-BA9BBE9DD1C4.jpeg 1793870E-055B-48D9-B4FB-16BF3A31FE09.jpeg
    Okie Pete and OahuEli like this.
  24. D72ECCD8-8677-48B3-8524-B0F31A157551.jpeg Kid fabricated his first piece by himself.
  25. noboD
    noboD
    If that's his first piece he's headed down the right path.
    OahuEli and anthony myrick like this.
  26. woodbutcher
    woodbutcher
    :D:eek:For a first try that is great.Keep up the good work.
    Leo
