Projects Blown 4 Banger (210 inch grenade)
Discussion in 'Traditional Hot Rods' started by nutrocker, Feb 7, 2021.
  1. Jet96
    Jet96
    from WY
    @nutrocker -Your engine sounds really good. It was nice to have good sound in those videos, no wind buffeting the mic.
    Stogy, nutrocker and loudbang like this.
  2. drtrcrV-8
    drtrcrV-8
  3. roddering
    roddering
    from Arizona
    Way cool. Amazing what can be done with the correct tools!
    Stogy and loudbang like this.
  4. drtrcrV-8
    drtrcrV-8
  5. drtrcrV-8
    drtrcrV-8
  6. Stogy
    Stogy
    HNY @nutrocker...always exciting to see this Thread back up...how's the envelope pushing over Yonder?...crazy times I know but here we are...
    May this year bring back more normalcy and get you up where your targeting...ever faster...
  7. nutrocker
    nutrocker
    Hey Stogy, thank you for your kind words.
    The motor hasn’t changed, it ran fine so it’s been left as is. What I have been doing is rebuilding the rest of the car and going through all the running gear.
    One of the things that needed work was the brakes. I’d spent so much time on the motor I didn’t get around to setting them up properly.
    This time around I’ve decided to go for hydraulic fronts but keep the rods on the rear. Should be a fun job balancing them!
    lots of other stuff being done, bits it’s being kept quiet for now.
    Have a great new year.
    Pete.
    Deutscher, Outback, Stogy and 3 others like this.
  8. Budget36
    Budget36
    Ala Ford Pilot. Seemed to work fine then:)
    Outback, Stogy and loudbang like this.
  9. nutrocker
    nutrocker
    Similar to Pilot, although Pilot was cable operated at the rear I think.
    What I’ve done is use the original A crossover shaft to operate the rears as per normal, but also added another lever to the bar that operates the single circuit master cylinder for the fronts. It looks like I’ll work ok once balanced.
  10. drtrcrV-8
    drtrcrV-8
    BTTT : What's new?
    Stogy likes this.
  11. I really have enjoyed this thread. Outstanding workmanship and dedication by you but also brilliant detail in your posts.
    very cool car and engine!
    Outback and Stogy like this.
  12. Some people do good work. But not you. You do fantastic work.
    Deutscher and Stogy like this.
  13. nutrocker
    nutrocker
    Thank you for the interest in my car, very much appreciated.
    the last post I said that I was working on the rest of the car as it had been neglected by myself in order to get the motor sorted.
    I have not only gone through the car sorting all the bits that needed attention, but I’ve changed up the style a bit too.
    One of the things I wanted to do was move the motor back as it was too close to the front crossmember due to the blower pulley. This meant having to jack the motor up at the front if I wanted to change the belts. Not ideal.
    While at it I also wanted to move the body and turtle deck backwards too, just for the looks. The easiest way to do this was to cut the front and rear crossmembers off, add 8” to the front and remove 8” from the rear. So that’s what I did. I replaced the front crossmember with a large tube and suicide spring perch so I could lower the front a bit, plus it makes it easier to lower it further at a later date if I want.
    All that was pretty easy and went without issues, and sadly I didn’t stop to take photos.
    The next bit wasn’t so easy though. I like the look of the Cooper/Hayes and the Navarro roadsters with the front cowl removed and long side and hood top. Will it work with a 25 T? Who knows, but I’ll give it a go. Maybe centre seat and steering too.
    First bit was to cut the cowl off from the door hinge forward.
    23AC944E-A5C5-48DD-9598-825B612C0CFC.jpeg A5109832-A559-4DF5-8062-5929BC2DCD32.jpeg
    I mocked up a repop 32 shell and grill. Plan is to build it with the shell then if I have time before Pendine I’ll make one akin to the Navarro one.
    Simple hood sides. Will be louvred later.
    42D16EC6-8348-4603-B3C9-DD5E752903F1.jpeg E9606E25-2F19-4083-8C48-1B9ECF513F37.jpeg
    New full width dash and small amount of cowl.
    BCA9B657-FADD-4734-A38E-6AD27CB8BD8F.jpeg C2533025-CDB6-4C40-B0CA-5D3992BF9ECC.jpeg 86E0D809-217C-46AA-AF85-4DA7A973D910.jpeg 4BDFE601-26FC-421A-B348-9088077F71E7.jpeg
  14. nutrocker
    nutrocker
    With the seat mocked up in the central position and liking the idea, I made a sub structure to mount the original model A steering box. I didn’t want to go down the route of cowl steering and the bump steer that comes with it, so I mounted the box as low as possible on top of the gear box. I positioned the split wishbones in the centre of the ch***is and with the drop of the pitman arm it all pretty much lines up with minimal bump steer.
    Got the throttle pedal mounted on the fire wall via a long rod on bearings
    17B2CB5B-DD84-4C19-8E45-583BC19E978A.jpeg 24F57AFC-F85F-4EDC-BD32-94532B782606.jpeg
    I modified my Louvre tool to press the old style louvres.
    BA360858-5EFE-456A-B20A-5AED08B578E1.jpeg 55EBD3F8-8B69-45BF-9BB0-4C0B71675652.jpeg 7A1AC507-5D4D-4656-B877-150B13CA8A1B.jpeg
    I cut the dash panel for a rear mounted gauge panel. The reason for mounting it behind the dash is that with an ‘L’ shaped panel I can fix all the electrical components in one place and it can all be removed easily.
    I also made a box for the switches that fits alongside the seat. This is because I can’t reach the dash when Im strapped in with the harnesses.
    Start on the hood top. A one piece construction that’ll just have some simple catches to hold it down. Cut out was made for the twin 97’s with a lip around for strength.
    I used the Rev counter from the old dash, found an old aircraft ( maybe) vacuum/boost gauge, but sadly due to lack of funds the other gauges are just cheap Chinese ****e. I’ll replace them when funds allow.
    253EC4C8-599C-435C-967D-B09E02CBEE29.jpeg ADBD5D99-5431-44FA-A322-0F35167D12D8.jpeg 5828D799-47AF-4D90-938E-DAB0EEB0DE5D.jpeg A03D2573-F99B-4C2D-A900-EDFD9D3B277B.jpeg C261D308-C82A-45AA-9C0B-80291321C87D.jpeg B1C16FDE-EDB6-4B37-A115-5FA7F887CEF1.jpeg D1413E5C-CCDA-4DF4-A685-3588F3789AD7.jpeg
  15. nutrocker
    nutrocker
    With most of the bodywork roughed out it was time to sort some of the details and get it off to paint.
    I could paint it myself but time was against me, so I sent it out to a friend who owns a powder coat company.
    My brief to him was not to overdo it. I didn’t want all the imperfections in the metal work to be filled, but left as they were. What I wanted was for it to look like it had been painted by an amateur in a garage. And that’s what I got. It’s got 30% matting agent in the paint, so it doesn’t have that modern paint gloss to it, but it still shines. Perfect. C70BAA04-83F8-4256-A8A8-F9DD64A52519.jpeg
    57B0CA72-7132-41D6-8118-692F78CFEAFC.jpeg 37219BBD-F79E-483D-AAB7-63F6EC493F6B.jpeg
  16. Fabber McGee
    Fabber McGee
    Wow! Thanks for the show. Lots of ideas there that I probably would not have come up with on my own. As construction of my modified roadster comes closer to reality I'm sure I'll be back to this thread for many hours of pondering.
    Great job and I'm impressed with your shop too.
    Stogy likes this.
  17. Fabber McGee
    Fabber McGee
    Will your frame and suspension also get powder coated?
    Stogy likes this.
  18. nutrocker
    nutrocker
    No, just just rattle can. The ch***is is going to evolve over time and powder coat will make it harder to clean off for welding.
    Stogy likes this.
  19. nutrocker
    nutrocker
    Getting the car back together.
    I bought a cheap alloy radiator from ebay, cut off the tanks and fabricated new ones. The rad now sits on its side in the trunk.
    I had a roll hoop rolled.
    7EA28344-9EF3-42A6-BF8F-C12CE579C394.jpeg 1D8FADF6-7B6A-45BA-A6B2-7886F49AD922.jpeg 3E8EC3E7-9214-42FC-9041-05AA7A525B70.jpeg D609B67F-9FD5-4B44-B9D9-7283AE071C3C.jpeg 9C28EB0D-8673-4F6A-8A7C-D7CF52818BCC.jpeg C01339B4-4D00-408C-B6D2-E3E7E88874EB.jpeg CFFD24D6-5C41-4A5E-A170-6473E0DA9EBC.jpeg
    Simple seat hung from the roll hoop. High turn up on the front to stop me sliding forward.
    Alloy fuel tank fits in the rear section of the turtle deck.
    Radiator filler neck mounted to the motor.
    6571896F-4C4B-40E7-AA92-FBCBC84D64C2.jpeg 733EFDE5-9DC5-45D6-B0C1-BC1B4E53AA0E.jpeg A5FAE3A5-1817-4882-8048-56F7C41D3A54.jpeg 2E57B42D-20FD-4FD8-9C71-728ECB854AD1.jpeg
    woodz, Tat2Neil, Deutscher and 4 others like this.
  20. nutrocker
    nutrocker
    That’s it up to date.
    Pendine is in 4 weeks so we’ll see how it runs.
    Thanks for taking the time to read the thread.
    Pete.
    woodz, Tat2Neil, Deutscher and 15 others like this.
  21. 282doorUK
    282doorUK
    Wow what a change from last year, it looks all together now! You made some good choices there and you must be very chuffed with the results, really looking forward to seeing you run at Pendine.
    Stogy likes this.
  22. raaf
    raaf
    One of my favorite builds ever - and it just keeps getting better.
    Good luck at Pendine!
  23. drtrcrV-8
    drtrcrV-8
    What an INSANE F**## BUILD"!! I LOVE IT!!!
    Stogy likes this.
  24. j hansen
    j hansen
  25. Stogy
    Stogy
    Great stuff @nutrocker...when I say Across the Pond Excellence this is exactly what I'm referencing...
    Taking Vintage Hotrod, modern regulation, your own twists on things and voila!!...we're screaming along with you...I love you're pushing the envelopes at every level while keeping 1940 something as the core of it all...
    Thank you for taking the time to share...Always...what an update with a Bang...er...;)
    v8flat44 likes this.
  26. v8flat44
    v8flat44
    Unbelievable!!! In a good way. We will need a video with .........
    Dustyp489 likes this.
  27. hotrodA
    hotrodA
    That’s an amazing build! You’ve really transformed that little roadster.
    Hope to get a Pendine report.
  28. 282doorUK
    282doorUK
    I really enjoyed meeting you on the sand Pete, and the car is perfect!
    I got some video of a couple of your runs, unfortunately the best vid of your last run taken from the top of the dunes which showed just how spectacularly squirrely it was, got corrupted due to a dodgy card.
    I had the best weekend for years, must try and get mine down there soon!
    woodz, Deutscher, Jet96 and 2 others like this.
  29. nutrocker
    nutrocker
    Brilliant, thank you for the videos. Shame about the other video, but that’s life.
    It was good to meet up with you too. Always nice to put faces to names.
    The car ran great. Never missed a beat and other than the usual spanner checks over night didn’t have to do a thing.
  30. j hansen
    j hansen
    Thank you,, @282doorUK Looks good,,,,Sound fantastic!!
    282doorUK likes this.
