Technical Fuel Pump to Carb Picture Request
Discussion in 'Traditional Hot Rods' started by Deyomatic, Dec 30, 2021.
  1. Deyomatic
    Deyomatic
    from CT
    I just flipped through about 12 old TRJs and haven't found much online...including with the search here.
    I am swapping to a larger carb on the Y block in my '30 Coupe and this is the first exposed engine I've ever had. I've always just run rubber fuel injection hose from the pump to the carb but feel like that'll look like ****.
    Also, any recommendations on a filter that won't look terrible- unless having one between the regulator and carb isn't necessary? It's got one back by the tank. I would think it should have something else.
    Anyway- any good photos out there? Thanks in advance.
  2. Almostdone
    Almostdone
    I used a bit of rubber line from the steel fuel line along the frame to the section of steel line from there to the fuel block that feeds 3 carbs. The filters are out of sight along the frame. A bit different from what you might have as far as carbs, but you could do something similar from your fuel pump to the carbs(s) and get a nice, clean look I think.
    John
  3. HOTRODPRIMER
    HOTRODPRIMER
  4. Mike VV
    Mike VV
    from SoCal
    Yeah...I'd never run any rubber fuel line over about 1-1/2" long, anywhere on my car (truck).
    It's just too easy to do what the above owner in post/picture #3 above did. Full steel line is the simplest and cheapest of the many ways to go. Should last nearly for ever, (unless you grab it and pull !).
    Keep it away from anything that would cause a rubbing action. Keep it away from heat.
    Put a quality filter between the pump and carburetor. There are MANY...to choose from.
    Stay away from the 3 dollar plastic filters !
    Mike
  5. PotvinV8
    PotvinV8
    Here's one example that I've done on a fuel injected 383. Dummy fuel pump and filter, but you get the idea. Line is 3/8-inch stainless with AN fittings at either end.
    If you must use hose, they make some very nice Kevlar braided hose that looks good or you could always use the typical stainless braided hose and cover it with heat shrink tubing to keep things looking "correct" but still retain the benefits over the usual rubber hose.
    Here's another example with a tri-power setup. Stainless line, welded together and ran from the regulator to each carb. Motor is filthy and needs a resto, don't mind that...LOL
    alanp561, Deuces, Deyomatic and 3 others like this.
  6. Deyomatic
    Deyomatic
    from CT
    Thanks for the inspiration. Some noce workmanship there. My flaring skills are garbage…
    I may run the hard line about 10” from the carb and run hose and clamp filter from there.
    alanp561 likes this.
  7. oj
    oj
    I ran copper from the pump (not shown) up to the GM/Corvette filter that take inverted flare fittings, from the filter to a regulator that acts like a 'Tee' to feed both carbs.
  8. Bandit Billy
    Bandit Billy
    I ran SS AN-6 to from the tank to the firewall mounted filter,
    then -6 braided nylon to the regulator mounted on the rear of the blower, then more SS hard lines to the fuel block and carbs. Liberal amounts of polishing.
    i.rant, Joe Blow, alanp561 and 5 others like this.
  9. GordonC
    GordonC
    Billy just curious what fuel pressure you are running with the 3 carb set up? Beautiful set up by the way!
    Deuces and Bandit Billy like this.
  10. Bandit Billy
    Bandit Billy
    2. -2.5 seems to be the best. I had to install that **** ugly white fuel pressure gauge as it was the only one I could find locally that read 0-10 PSI, the other larger sweeps don't even read 2 PSI. And thanks for the compliment!
    GordonC likes this.
  11. Just Gary
    Just Gary
    AN -6 hoses & 3/8" stainless steel fuel lines.
    85-micron filter back between the tank & pump. Edelbrock 40-micron filter just before the carb.
    IMG_20211231_204554.jpg IMG_20211231_204559.jpg IMG_20211231_204606.jpg IMG_20211231_204610.jpg
    Joe Blow, Deuces, Deyomatic and 2 others like this.
  12. PotvinV8
    PotvinV8
    Both are simple p*** through items meant to look the part.
  13. Larry T
    Larry T
  14. oj
    oj
    Just Gary likes this.
  15. jimmy six
    jimmy six
    All metal. Flexible with fittings from the tank line to the pump.. EBC34B4E-E27E-4C5F-9E99-2B1746659FD2.jpeg
    Bandit Billy, Just Gary and alanp561 like this.
  16. Use Ni-cop or whatever it is called. It is much softer so it is easier to bend and much easier to flare (with a good quality flare tool) and supposedly will never rust. I have used it myself for gas and brake lines and will never use anything else. More expensive but, in my opinion, worth every penny.
    Fabulous50's likes this.
  17. X-cpe
    X-cpe
    Inverted flare T fitting. Drilled and tapped the backside for 1/8 pipe thread. Screwed in the fitting and soldered because there was very little thread engagement, then ran a drill bit through the horizontal outlets to cut out the excess protrusion of the fitting. Excuse the 20 plus years of 'patina' from sitting in the shop.
    Bandit Billy and Just Gary like this.
  18. Blown35
    Blown35
    GordonC and Just Gary like this.
  19. Model A Gomez
    Model A Gomez
    Plumbed my flathead with hard line except the short piece of fuel line below the fuel pump
    IMG_0416.jpg .
  20. dirt car
    dirt car
    from nebraska
    Give me the steel line..... none of that bull **** cheap filters, plastic/poly, rubber hose **** no matter the quality ! If you have ever seen raw fuel boiling in the intake manifold runners from failures it will make you a believer.
    Just Gary and 427 sleeper like this.
  21. Just Gary
    Just Gary
    Some more from my *****in inspiration folder.
    First one is by Danny @hot rod pro & second by @CTaulbert . They do awesome work.:cool:
    The others are from all over.
    Hope this helps.
    hotrod pro 103.JPG CTalberts 5w 01.jpg bent 03.jpg bent Pinkees_32_02.jpg fuel lines.jpg hard lines 50.jpg ImageUploadedByH.A.M.B.1464737338.097577.jpg turquoise A 02.jpg
    dana barlow, Joe Blow and X-cpe like this.
  22. Larry T
    Larry T
    I hooked this one up for a customer. It was all pre bent and bolt on which is nice sometimes. crane engine.jpg
  23. Joe Blow
    Joe Blow
    Billy, ****ster27 here sells a 0-5psi black gauge. Comes with a bright orange indicator....I took mine apart and painted it white.
    http://www.****shotrodcarbs.com
    https://www.jalopyjournal.com/forum...-are-now-back-in-stock.1203963/#post-14025340
    GordonC, Just Gary and Bandit Billy like this.
  24. Bandit Billy
    Bandit Billy
    GordonC, Joe Blow and Just Gary like this.
  25. Joe Blow
    Joe Blow
    Solid (Nicopp) and steel Wix fuel filter along the inside of the frame rail.
  26. Almostdone
    Almostdone
    @Mike VV : I agree with only a sparing use of rubber fuel line. The rubber lines from the fuel block to the carbs on mine is more of a period look than a best practices choice and one I may change someday.. What I was trying to suggest was to use a short piece of rubber from the main metal fuel line to the fuel pump, then metal from there to the carb to get a nice, clean look. Hiding the fuel filter somewhere out of sight is also sorta nice.
    The OP probably has the job done by now.
    John
  27. Dominick Hide
    Dominick Hide
    For me it's hard lines only, with AC style gl*** bowl filter. Remember a steadying brace near the filter.
  28. dirt car
    dirt car
    from nebraska
    Like the copper looks, haven't used it since a kid but still prefer steel !
  29. dirt car
    dirt car
    from nebraska
  30. Fabulous50's
    Fabulous50's
    from Maine
    Electric pump at the tank.
    Used NiCopp 5/16" line, ran it up around the brake booster along the firewall to keep it away from heat. The rubber line is Gates Barrior green stripe, it is fantastic stuff.
