Projects 1930 Oliver Roadster Build
Discussion in 'The Hokey Ass Message Board' started by oliver westlund, Dec 22, 2021.
  1. 41 GMC K-18
    41 GMC K-18
    Just a bit of " MOPAR " roadsters, to give you a bit of inspiration !
    Your project is definitely going to be very cool, when completed.
  2. oliver westlund
    oliver westlund
    chryslerfan55 and 41 GMC K-18 like this.
  3. oliver westlund
    oliver westlund
    Well i did pretty well today, got a full set of wide 5 wheels, a 36 ford rear and a model a front axle, full set of wide 5 hubcaps, some dented headlights that will probably just be temporary, a windshield frame, an aaaooga horn, a 39 trans and a handful of parts for my 33 5 window as well as some sub structure for the roadster and the cowl
    chryslerfan55 and Squablow like this.
  4. oliver westlund
    oliver westlund
  5. oliver westlund
    oliver westlund
    41 GMC K-18 likes this.
  6. oliver westlund
    oliver westlund
    Wrong cowl...headed to swap it out for the 28 chev capitol roadster cowl in a few min Screenshot_20211231-113105_Gallery.jpg
    out plowing and chryslerfan55 like this.
  7. oliver westlund
    oliver westlund
    Kind of thinking about doing something like this...not sure til i get all the parts in one place though 20211227_161545.jpg
    EVL401, Tim, Just Gary and 6 others like this.
  8. oliver westlund
    oliver westlund
  9. scotts52
    scotts52
    That's a great book. Be sure to look here on the HAMB for the few discrepancies that made it into print.
    oliver westlund likes this.
  10. oliver westlund
    oliver westlund
    Well....after laying everything out, i now have the hood that matches as well... i am thinking of doing this. Keepimg the dodge tub but adding the chev bodyline to the cowl and doors so it matches the hood and rear quarters. I like the swoop on the dodge cowl where it meets the doors better than the chev cowl. The hood fits right on either cowl. Thoughts? Which design jumps out more, a or b? I recognize the images are crude haha work with me! Screenshot_20211231-165143_Photo Editor.jpg 20211227_161545.jpg
    chryslerfan55 and kidcampbell71 like this.
  11. oliver westlund
    oliver westlund
  12. rusty valley
    rusty valley
    #1 for my vote
  13. oliver westlund
    oliver westlund
    Got a cpl goodies for the roadster today! 20220101_125556.jpg 20220101_125604.jpg
  14. oliver westlund
    oliver westlund
    Got some (i believe) ford guages in a ks distometer bezel i will be using on this today as well! 20220101_190623.jpg
  15. oliver westlund
    oliver westlund
    I should call this car the triple crest roadster, dodge bros tub with chevy skins on a ford frame
  16. ratfink56
    ratfink56
    Your buddy sure has a lot of sh...tuff.
  17. oliver westlund
    oliver westlund
    Another score for the roadster! 46 front and rear. Will use the juice brakes and spindles, possibly the rear 20220102_114206.jpg
  18. oliver westlund
    oliver westlund
    Oh yeah... seems like every part i need just presented itself to me...besides a drop axle
  19. oliver westlund
    oliver westlund
    Thoughts on these? Splitting front bones, the angles would kind of make sense if i attatch the bones between the frame rails, just outside the ****** mounts....am i on the right track? Screenshot_20220103-140900_eBay.jpg
  20. oliver westlund
    oliver westlund
    Or just use these and mount em outside the frame? Screenshot_20220103-141535_eBay.jpg
  21. oliver westlund
    oliver westlund
    Early ford store package arrived! No im not running a front tank, yes i like the spreader bar look! Sue me 20220103_153829.jpg
  22. oliver westlund
    oliver westlund
    Picked up wheels and caps today also! Screenshot_20220102-222057_Chrome.jpg Screenshot_20220102-222113_Chrome.jpg
    Greenblade, Squablow, brEad and 2 others like this.
  23. oliver westlund
    oliver westlund
  24. stanlow69
    stanlow69
    How many projects do you have going on.
  25. oliver westlund
    oliver westlund
    .....ummmm 5ish...6? Goal for the 5 window and the roadster is to get the bodies set and bracing in then pull em and set em both aside while i finish my dads 53 and our local snap on dealers ot rock crawler...side note, hammered on the hood a bit, spacer bar and grill set in for looks and daydreaming 20220103_202459.jpg
    Tim, Squablow, brEad and 1 other person like this.
  26. oliver westlund
    oliver westlund
    Did some extensive holding up of parts and measuring. For starters, thank god i have a 46 banjo because the booty on this custom is 46 inches right now and i have to widen it an inch or two still and inside to inside the backing plates the 46 banjo is 53" Now im left pondering spring tension....panhard bars....rear sway.... i want to leave the diff exposed (t or a spring) in case i can ever find someone kind enough to sell me a cheap quick change! A spring (1st pic) is eye to eye exactly where the 46 spring is...t is obviously longer 20220105_105029.jpg 20220105_105054.jpg
    Just Gary and chryslerfan55 like this.
  27. i wonder how all this stuff survives for as long as it does with no one s****ping it.
  28. oliver westlund
    oliver westlund
    Little progress, used bead roller to step a line matching the body on the rear quarter, cut and tacked it in. Turned out decent, will still be wrapping the seat over the top so idk how much will be visible but it gives me more room 20220107_195015.jpg
    Squablow and chryslerfan55 like this.
  29. oliver westlund
    oliver westlund
    Old hot rod loving hoarders...but then they p*** and it spreads out to other hoarders.
  30. burl
    burl
    from Minnesota
    ive been using simple ford parts for mounting my bones just a chunk of angle with a tapered hole for steering arm ball
    Lil'Alb, Tim, cactus1 and 3 others like this.
