Technical Y Block
Discussion in 'Traditional Hot Rods' started by sickiee32, Jan 3, 2022.
  1. sickiee32
    sickiee32
    Can anyone tell me a good Y Block builder located in Southern California ??
  2. Tim
    Tim
    from KCMO
    mctim64 likes this.
  3. 51504bat
    51504bat
    @mctim64
    He is located in Hanford in the Central Valley. Well worth the drive from SoCal by all accounts. There is also a guy in the San Diego area who advertises on Hemmings but I know nothing about him or his work.
    mctim64 and USMercUte like this.
  4. sickiee32
    sickiee32
    Thanks guys was hoping for Southern California … not
    Northern
  5. 51504bat
    51504bat
    You may find someone closer but not better. IMO.
    Truck64, badshifter, ottoman and 3 others like this.
  6. sickiee32
    sickiee32
    Ok that’s good to know … I will hit him up forsure
    Boneyard51 likes this.
  7. Dave's32insocal
    Dave's32insocal
    L & R Engines
    13731 Bora Dr
    Santa Fe Springs Ca 90670
    Really happy with the work on mine, they do work on the y blocks that Prestige Thunderbird sends over to them so I felt comfortable they knew that engine, they know what they’re doing here! BDBCD661-60C9-4C5D-B3CB-92CEE4508E48.jpeg B8220304-B0E5-4550-B029-0B669837E96E.jpeg
  8. sickiee32
    sickiee32
    Wow looks nice !! Can you tell me specs and how
    Much they charged ??
  9. egads
    egads
    ^^^^^^^^^^^^^^^ That's PRETTY !!!!
  10. sickiee32
    sickiee32
    Where did ya get that Fenton intake ??
  11. Dave's32insocal
    Dave's32insocal
    Call and they will walk you through everything you want to know, every engine will be different depending on what you want and what you have to start with,292 or 312 or 292 with a 312 crank stroker?
    Good luck keep me posted!
  12. sickiee32
    sickiee32
    What is yours ?? How much HP ?? What trans you running ? Is it going in your 32 ??
  13. Dave's32insocal
    Dave's32insocal
    E bay is my best friend
    egads likes this.
  14. Dave's32insocal
    Dave's32insocal
    312 56 thunderbird , if horsepower is a requirement there are better engines, but none cooler!
    Irish Mike, williebill and egads like this.
  15. sickiee32
    sickiee32
    No I agree , just wondering what your getting out of it ? Are those Mumford heads ??
  16. Dave's32insocal
    Dave's32insocal
    John Mummert Machine
    Heads, valley pan, thermostat housing and alternator bracket. I’m addicted to cast aluminum and there’s no hope!
    y'sguy likes this.
  17. Dave's32insocal
    Dave's32insocal
    Maybe 300 hp but it’s going to sound like a million! F15F5236-469C-422C-B5A2-474FFAF31B16.jpeg A1600962-8F92-4586-9C03-81DE65DA0263.jpeg 0F2A9D74-7F83-4399-9808-35AE376018FE.jpeg
  18. nosford
    nosford
    When I lived in SoCal (I left in 92 after the Rodney King thing) there were many really great machine shops that would have been okay but as Dave's 32 says you need to know what you are starting with. Everything changes on these blocks and heads as far as what to look for, example, cracked webbing on main bearings on 312 blocks, Posted heads, etc. You really need to find someone that knows what they are looking at before dumping a bunch of money into a 65 year old hunk of cast iron. Mummert
    http://ford-y-block.com/ and Tim McMaster yblockguy.com have a lot of information and a lot of dyno tests and real world racing experience. I have been to several machine shops here in Oregon that claim to know what they are doing with Y Blocks then in the conversation ask me if I am going to run solid or hydraulic lifters in a 292 (no kidding) then proceed to tell me "well in a small block Chevy" as I am heading for the door. You will find a bunch of people that can talk SBC or even Toyota 20X whatever but very few Y Block people left. (our current Y Block project) 227400837_4284126211644524_1101645741377411507_n.jpg
  19. sickiee32
    sickiee32
  20. 55blacktie
    55blacktie
    If you have Mummert heads, you should be looking north of 300.
    is John Mummert (El Cajon) still building engines, or is he just selling parts? Now that the Mummert aluminum heads are available, he is no longer porting iron heads.
  21. Dave's32insocal
    Dave's32insocal
    C42E9EF2-7FF5-4692-820C-218515B18469.jpeg 172F2447-72D5-4669-8E4F-A72EFEDDC2FD.jpeg Every frame is different, mine was stretched 3” pinched and rails reworked to get the car lower, you’re starting new, I had a SBC and a 350 turbo to take out and matching the existing frame mounts to new engine and transmission 2004r sorry but it is the smallest od and direct replacement for the one coming out. The 3” stretch helped but the pinched nose made it a little harder for the sides, used every 1/4” C42E9EF2-7FF5-4692-820C-218515B18469.jpeg
    Desoto291Hemi, Irish Mike and Fordors like this.
  22. Dave's32insocal
    Dave's32insocal
    When enough orders are in, then they cast a number of sets, limited edition. But call John for sure with any questions? Maybe a little north? 56D40CB6-A10F-4E03-9732-6BB66D4CBC16.jpeg
  23. Dave's32insocal
    Dave's32insocal
    Had to rework transmission tunnel
  24. sickiee32
    sickiee32
    I emailed Mummert, not building engines
  25. sickiee32
    sickiee32
    Is your y-block a roller ?? Or solid lifters ?
  26. Dave's32insocal
    Dave's32insocal
    Only solid are available I believe, we used a 57 stock grind performance cam and 9.5 compression
  27. sickiee32
    sickiee32
  28. y'sguy
    y'sguy
    from Tulsa, OK
  29. Dave's32insocal
    Dave's32insocal
    Engine mount and remote filter 6E7DAC06-8006-496F-ACB9-CD5B8C4B8A0B.jpeg 6E7DAC06-8006-496F-ACB9-CD5B8C4B8A0B.jpeg
    Desoto291Hemi, egads and y'sguy like this.
  30. jimmy six
    jimmy six
    Are you looking for a complete engine builder and ***embler or a shop that do the machine work and you ***emble?
