Projects My Fairlane after sitting 45 (48) years in the garage...
Discussion in 'The Hokey Ass Message Board' started by F-ONE, Oct 8, 2012.
  1. F-ONE
    F-ONE
    from Alabama
    It would not roll off the trailer. I had to chain it to a fence post and slowly ease the trailer forward to unload it.
    From behind, some body work from the only PO. All trim was found in the trunk. The car came original with a white vinyl top.
    The drivers seat is split at few places at the seams. I think I'll try to repair it as is. It's a little sun bleached but I think it will do for a while. They're only original once.
    There was all kinds of receipts and stuff from the 70s and a Aspirin tin from the 60s in the console. The floors are still in shiny factory paint under the carpet, no rust.
    I think those miles may be original. The engine was seized but I now can turn it. I had to remove the heads, clean the bores, loosen the bearings and she finally gave way. It seems to be in good shape but we will see when I get it on the bench.
    Gold 289 V or 2bbl 289. Valve cover has 289 Special on it. The 2bbl 289 was called special because it was not a 260. They did offer a 4bbl and the famous K code. All can share the same block number casting.
    Paint is horrible looks like it was put on with a brush but it has protected it for 3 decades.
    Transmission is a Green Dot Cruiseamatic. Also known as the dual range C-4. The very first. C-4= 1964.
    The original deceased owner's son wanted to give it to me since I was a Ford guy. His new wife did not like it in the garage. I gave him $500 for it. He and his wife were happy and I was fortunate.
    hfh, vtx1800, swade41 and 12 others like this.
  2. B Bay Barn
    B Bay Barn
    Nice, love them '64's.
    Joe Travers and F-ONE like this.
  3. Zerk
    Zerk
    '62-'67 Fairlanes are great cars, and you found a solid one with desireable powertrain and trim. I'd say the price was what a parts car would bring. A fine catch.
    2Blue2, Joe Travers and F-ONE like this.
  4. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    I like Fairlanes!!
    heres mine
    ALLDONE, Deuces, Jeff Norwell and 4 others like this.
  5. seb fontana
    seb fontana
    from ct
    What are your plans for it?
    F-ONE likes this.
  6. Those Fairlaines had style.
    F-ONE likes this.
  7. Jalopy Joker
    Jalopy Joker
    Cool - Congrats
    F-ONE likes this.
  8. Brad54
    Brad54
    from Atl Ga
    You don't even need to bother buying a lottery ticket again... $500 for that was hitting The Big One.
    I like them all, but mainly GMs and early '60s B-Body Mopars... But I'd give select body parts for a '64 Fairlane or early '60s Ford big-body.
    -Brad
    chryslerfan55 and F-ONE like this.
  9. pug man
    pug man
    from louisiana
    Want your $500 back? hahaha Great find and best of luck with it......
    F-ONE likes this.
  10. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    Dearborne cl***ics has new sportscoupe interior kits for around 600 bucks exact reproduction
    VANDENPLAS, Joe Travers and F-ONE like this.
  11. F-ONE
    F-ONE
    from Alabama
    The boxes have been arriving the past 2 months. I'm done gathering parts for right now. The car is up off the wheels.
    The real work started 2 nights ago when I cut the old exhaust pipes out.
    It's on!!
    flynbrian48, Thor1, Algoma56 and 8 others like this.
  12. That is fantastic :)
    I will be sure to check back in another ten years for your next update :D ;)
    SS327, Thor1, Greenblade and 12 others like this.
  13. man i wasnt even out of primary school when you posted about this for the first time.
  14. loveoftiki
    loveoftiki
    from Livonia,Mi
    Love those….friend of friend picked this up last week…really nice start to a 64…
    0F706F09-649D-4B2E-82BF-92309C93D807.jpeg 93EDDBAA-0F02-40E1-A262-424DD4C7996B.jpeg C8F9EFDA-0A4C-4428-BCFF-CF9A9330A316.jpeg 26FB9CDB-CAA8-491D-9C5D-7DDB5A0849DD.jpeg
    Deuces, Thor1, Algoma56 and 10 others like this.
  15. F-ONE
    F-ONE
    from Alabama
  16. loveoftiki
    loveoftiki
    from Livonia,Mi
    He has it all..the trims perfect…fresh 289, rebuilt to stock..gonna get a “Day 2” makeover..some bolt on motor parts, rims and tires, has a T bolt hood and gl*** bumpers…replacing the 3 on the tree with a toploader
    Thor1, Algoma56, ffr1222k and 4 others like this.
  17. deathrowdave
    deathrowdave
    from NKy
    Had one myself , 289 HP nice car
  18. F-ONE
    F-ONE
    from Alabama
    It's up.
    [​IMG]IMG_0047 by Travis Brown, on Flickr
    This may seem basic, but there is a lot to getting a car up where you can safely work under it, especially one of these cars. I had it up on ramps but No...They have their place, but not for this kind of work.
    One of the quirks of a Fairlane is the lift points. There are 4 "Jack Plates" under the car. These are just aft of the firewall "torque box" and forward of the rear spring hangers.
    [​IMG]IMG_0050 by Travis Brown, on Flickr
    The blocks help spread the load and also give a little grip. The shop manual recommends a plate to spread the load here.
    First Surprise....
    [​IMG]IMG_0052 by Travis Brown, on Flickr
    As Scoob would say " Ruh-Roh Raggy"
    It's one of those things I did not notice but became apparent here when I put on Jack-Stands. At first, I put the rear stands on the rail just in front of the bumper. When I lowered the car, it sat hard on 3 points.
    So, either the p***enger side rail is tweaked up or the driver side is tweaked down. I had planned to either rebuild that spring pack or replace the springs. Also, I want a set of Traction Masters.
    I discussed this with my brother. He cautioned me on "Mission Creep". He suggested that I get it together first and see how it drives. If something needs to be "pulled"...get it pulled and then replace the springs and add the traction aids after it's square.
    The car was hit and had the driver quarter replaced in 1976. This could be from that or jacking it up with a bumper jack. These cars are low and with spring load, you have to get them really high to change the rear tire with a bumper jack.
    Anyway, this is another battle for another day.
    [​IMG]IMG_0056 by Travis Brown, on Flickr
    Rear Jacks moved to the "lift points" in front of the rear spring hangers. This is much, much better and now the car is sitting on 4 points. Too, the jacks are not extended. This is just better. It's solid as a rock.
    Deuces, SS327, Thor1 and 4 others like this.
  19. F-ONE
    F-ONE
    from Alabama
    [​IMG]267385694_616505909675239_3561734635214876703_n by Travis Brown, on Flickr
    I've been gathering parts. On New Year's Eve my wife and I traveled to Mississippi to get some Fairlane parts. The guy was parting out the Fairlane sedan picture above. Yes, the car was better than it looks. It's really sad, it was such a nice car.
    You kind of get put on the spot. I've been kicking myself in the **** a little....I should have got more parts but...did not think about it. Dang it....There's my rear springs...I did not know they were that good.
    I got....
    The wiring harness...
    new stainless brake lines (I don't know if I'm going to use them)
    backing plates, front hubs, front drums, rear drums, new wheel cylinders, new shoes, all the new hardware, a brand new power master and booster still in the plastic, a new gas tank, cap, fill hose and sender, two used lower control arms, new stainless fuel lines. I almost got a great front bumper but I did not have the room. I should have made the room.
    Like a said you get put on the spot....If I had more time....more time to think.....but I got a lot of what I needed.
    Deuces, Thor1, chryslerfan55 and 3 others like this.
  20. Malcolm
    Malcolm
    from Nebraska
    I love those '64 Fairlanes... Will be following along!
    loudbang and F-ONE like this.
  21. saltflats
    saltflats
    from Missouri
    Think I would have the block of wood at a 90 degree to the jack stand.
    Randall, Budget36, loudbang and 2 others like this.
  22. junkman8888
    junkman8888
    What saltflats is trying to say is the "fork" on the jack stand is aligned with the grain which tends to split the wood. If you turn the jack stand 90 degrees, the fork will be across the grain which can help prevent the wood from splitting.
    Note to all: Before I get under any vehicle I make sure it is supported by at least two different devices because for me a set of jack stands is not enough, I want more, I want a floor jack or a spare tire or stacked rims or something, anything that will keep that vehicle from becoming one with my face. Jack stands, even the nice American made ones have been known to slip or fail.
  23. F-ONE
    F-ONE
    from Alabama
    I'm using multiple safeties.
    Thor1, chryslerfan55 and loudbang like this.
  24. F-ONE
    F-ONE
    from Alabama
    Whew!
    It's a lot of nasty work. It's lots of slow work too. I'm using Penetrating oil, spraying all the fuel/brake line clips. Then, it's a delicate procedure of wire brushes and screw drivers to loosen those rusted lines from those 58-year-old spring clips.
    Lord have mercy!!!! A 1964 Model being 58 years old!!!
    Punchlist.....
    The seal under the rear axle brake block/axle vent...
    Universal joints...
  25. F-ONE
    F-ONE
    from Alabama
    Engine...
    1968 Ford 302
    Stock Bore, '68 4V heads, Weiand 8011 Intake, Summit 500 CFM 4BBL, Crane Fireball 294 (Crane's duplicate of the 1969 Cobra Kit Cam 2000-5500 RPM) Mallory Unilite distributor
    Transmission...
    Ford C-4 with 2400 stall
    Rear Axle...
    Ford 8" with Eaton Tru-Trac 3.80 gear ratio
    I want to use a set of Traction Masters
    Wheels...
    original 14" steel, black I may just use chrome lugs....If I use caps, it will be 1961 Galaxie dish caps.
    Tires
    BF Goodrich double stripe G-78s rear
    BF Good rich 7.35-14 Silvertown Blackwall front
    [​IMG]IMG_0049 by Travis Brown, on Flickr
    ^^^^ like this but Blackwall
    Deuces, Thor1, Elcohaulic and 5 others like this.
  26. Joe Travers
    Joe Travers
    from Louisiana
    Cool Fairlane & love the plan! Tire cooker :cool:
    IIRC, Ford had recall on '68 302 pistons? Check 'em once, check 'em twice......;)
    Joe
  27. F-ONE
    F-ONE
    from Alabama
    [​IMG]IMG_0053 by Travis Brown, on Flickr
    [​IMG]IMG_0055 by Travis Brown, on Flickr
    Yikes!
    yuck...
    I had to back the adjuster all the way in to get the drum off. There was lots of penetrating oil around the studs and hub, lots of gentle tapping with the ball peen, sever sessions with the rubber dead blow and finally some prying with my two largest flatheads but it come loose. It took about an hour of work to free this drum.
    Both axles pulled out fine, reversing the drums did the trick. Axle bearings and seals look really, really good.
    As said above, lots of dirty and at times delicate work.
  28. F-ONE
    F-ONE
    from Alabama
    Joe,
    I replaced those pistons with....If I remember right, TRW Flattops. It had slightly dished pistons. That engine was "ticking". It turned out the "ticking" was the #1 piston skirt bouncing off the crank up and down in the cylinder. If you heard it, you would have thought it was a lifter.
    It sure surprised me.
  29. Joe Travers
    Joe Travers
    from Louisiana
    I thought the recall was a skirt problem but would never guessed it was this o_O
    Someone's pen slipped on the drafting table?
    Remember this from a '68 289 re-build back in the '70s. Block was stamped 302, crank M1 but pistons were checked for good measure. Yeah, chunk the rail rockers ...
    Joe
    Thor1, loudbang and chryslerfan55 like this.
  30. loveoftiki
    loveoftiki
    from Livonia,Mi
    For what it’s worth…that stall might be a little tight for that cam..might wanna look at a 3K
    I’m running a 2500 stall in my Falcon with a cam that’s got a 1800-6000 RPM power band…it stalls at about 2100 rpm….not high enough imho….I went with what the cam company recommended…2500+ stall..well as you know torque, vehicle weight also impact how it will stall..in a heavy car it might stall at 2500…in a lighter vehicle…2000…in hindsight I should have called and had a converter built for my car versus and off the shelf buy…
