Projects '30 Chevy 3-window Coupe project. Some assembly required...
Discussion in 'Traditional Hot Rods' started by jamesl, Jan 3, 2022.
  1. jamesl
    jamesl
    from Tulsa, OK
    Just picked up a trailer full of parts alleged to be a 1930 3-window Chevy coupe. Has a good Oklahoma ***le to that effect, at least. Lots of rotten wood but some surprisingly good metal. I'm not sure how it's going to end up, but I would like to keep it fairly original on the outside while modern underneath.
    I haven't settled on anything yet. I'm really fond of turbo 4-cylinders but I know LS v8's are the current hot trend. It came with a straight six originally, and the late-model Chevy straight sixes look interesting.
    I work slow and figure this should keep me occupied for a couple of years. It's a huge puzzle and will take a while to figure out which piece goes where and what pieces are missing...
    Shitbox, 2Blue2, Okie Pete and 9 others like this.
  2. chopped
    chopped
    The hoods a 30 for sure.
  3. simplestone
    simplestone
    Thanks for the eye candy - looks to be in good shape! Good luck with the build.
    Stogy likes this.
  4. sloppy jalopies
    sloppy jalopies
    not to be a kill joy, but i don't see the rear quarters... hope they are there somewhere...
  5. jamesl
    jamesl
    from Tulsa, OK
    Both are in front of the roof section in the center of the pile.
    Stogy likes this.
  6. sloppy jalopies
    sloppy jalopies
    bad one on me... you got a hotrod in the pile...
    kidcampbell71 and Stogy like this.
  7. Ghost28
    Ghost28
  8. Max Gearhead
    Max Gearhead
    from Wisconsin
  9. tb33anda3rd
    tb33anda3rd
    love it
    tab A into slot B:D
  10. Guy Patterson
    Guy Patterson
    Nice kit car. The metal looks quite good for a 30 so starting from a good base. Have fun
    VANDENPLAS, vic van leeuewn and Stogy like this.
  11. gary macdonald
    gary macdonald
    At least its got shape . When I received my 30 chevy 3 window, it was all rolled up andin 50 gal drums . No piece , except doors , were any larger than what could be rolled up and shoved in the oil drum . This is it on a 34 ford frame . Ive been driving it for almost 20 yrs . ED9F9AE9-1D19-472A-AB46-C045DFD882D9.jpeg DEA34E7B-1E92-4AAD-A263-75B7DA52C246.jpeg
  12. jamesl
    jamesl
    from Tulsa, OK
    Sharp looking ride! Did you replace the wood or build a metal skeleton? My plan right now is to go with metal since I'm not much of a wood guy.
  13. Wanderlust
    Wanderlust
    Oooh big boy model kit! I love it!
  14. gary macdonald
    gary macdonald
    Metal , no wood . Its one of the most solid riding 30 era cars I have . I was going to install on a custom ( home made ) until the running 1934 ford frame rolled into the shop .
    I can see now where some rusted pieces I had should have gone . I had to use the English wheel and bead roller to fill in the empty pieces of my puzzle . I didnt have a computer then and the only pics I had were in the library . Come to think of it , it was closer to 30 yrs ago .
    One of these days I want to install the body on the frame I made and get a 34 fibergl*** body on the ford frame . But ....too many projects
    Okie Pete likes this.
  15. wheeldog57
    wheeldog57
    Way cool project right there, I look forward to the updates.
    TFoch likes this.
  16. Pete
    Pete
    I’m kind of partial to the Chevys of the 30’s
    I bought mine in the same condition as yours.
    Strange that these don’t really rot like tge fords,,,rather the wood rots and falls out
    Jet96, Stogy, Okie Pete and 3 others like this.
  17. jamesl
    jamesl
    from Tulsa, OK
    Started cleaning up the frame. Sadly quite a bit of pitting along the top of the frame on both sides. Otherwise very solid. My first thought is to cut out the worst sections and weld in new material, then add some reinforcement elsewhere. I'm not planning a high horsepower car, but certainly more than the original.
  18. gary macdonald
    gary macdonald
    Just box it . It’ll be much stronger. Once cutting the original channel, it can get out of square easy with just the heat of welding . Make a jig to keep things square , even when boxing .
    Stan Back, 2Blue2, Jet96 and 2 others like this.
  19. TFoch
    TFoch
    Another cool Chevy project to watch! Looking forward to it :)
    vic van leeuewn, Stogy and wheeldog57 like this.
  20. Okie Pete
    Okie Pete
    Looks like a great pile of pieces to build a hot Rod from
    Stogy likes this.
  21. Rusted Junk Garage
    Rusted Junk Garage
    from Lacey Wa.
    Very nice, have fun with the build, sure wish it was in my shop.
    RJG
    gary macdonald and Stogy like this.
  22. 2Blue2
    2Blue2
    Really Neat-o
    Fun to See.
    Stogy likes this.
  23. deathrowdave
    deathrowdave
    from NKy
    GMs normally from where I see them have lots of rust in this part of the frame . The wood stayed wet and felt water against the frame rails . A great rust promoter
    Stogy likes this.
  24. synchro7
    synchro7
    In 1969 I tried my damdest to buy a complete 29 Chevy 3 window coupe. But the old guy wanted to keep it, (Going to fix it up someday!)
    gary macdonald likes this.
  25. Shitbox
    Shitbox
    from Nor Cal
    If you need any help on what goes where I just blew my 31 apart so I’ve got a ton of pics.
  26. jamesl
    jamesl
    from Tulsa, OK
    That would be great! One major piece of the puzzle I'm missing is the floor. If you have pics of the floor with the cowl and quarters removed, that would help. Also the outside dimensions of the floor pan. I understand it angles outward toward the middle and then back in after the B pillars.
    I'd also like to see a picture of the bottom edge of the windshield where it meets the cowl. I don't have an obvious piece of channel where it would rest.
    I'm moving pretty slow. The metal was in generally good shape for it's age, but it is 90+ years old. So, I'm busy replacing some rusty edges and rehabbing the doors. The door wood is in fair shape and may keep some if it. Amazing how much stuff can be crammed inside a door when left out in the wild for a few years...
    Jet96 and 2Blue2 like this.
  27. Shitbox
    Shitbox
    from Nor Cal
    I don’t have any pics of the wood stringers or floor that the steel nailed to(aside from when it was together). But I’m sure I’ve got screenshots of some others projects. Is this what you’re wanting for the cowl/windshield?
    [​IMG] I’ll get some shots of the sheets for the flooring later. I’ve got a guy coming to buy a bike so it won’t be until later tonight. This may help also.
  28. jamesl
    jamesl
    from Tulsa, OK
    Thanks for the pic and diagram. Sadly most of the wood is gone. If possible, I'd like a measurement from the outside edge of the outer pieces 35 & 36, at the widest point. It's a huge puzzle with about half the pieces missing... ;)
  29. Shitbox
    Shitbox
    from Nor Cal
    All my wood is gone since it was infested with drywood termites. Lower quarter measurement from bottom of b pillar/b pillar is 46”. [​IMG]
  30. jamesl
    jamesl
    from Tulsa, OK
    Great, thanks for taking the time to measure. My basket case didn't come with a floor. no doubt it rotted away long ago. Looking through the do***entation that came with the car, I found these hand drawn sketches. body dimensions.jpg
    nunattax, Jet96 and loudbang like this.
