Technical Blast cabinet help
Discussion in 'The Hokey Ass Message Board' started by MoeG, Jan 8, 2022.
  1. MoeG
    MoeG
    20220108_182455.jpg 20220108_182518.jpg 20220108_182538.jpg 20220108_182611.jpg 20220108_182638.jpg Hi need some help. I have an older cabinet it's a ****blast. I turned it into a gravity feed. It has all new parts. Using a new pedal controlled gun. Have no kinks in the lines, sand is new and dry. Air is dry. You can see the sand come up the tube to the bottom of the gun then it stops. Any help would be greatly appreciated. Thanks for your time
  2. HOTRODPRIMER
    HOTRODPRIMER
    Did you replace the ceramic nozzle in the gun, there are different sizes for different grits of sand,
    My gun just has one hose. HRP
    Budget36 likes this.
  3. MoeG
    MoeG
    It has the nozzle it came with. I am using black beauty sand through the gun.
  4. vtx1800
    vtx1800
    I've worn out the br*** fitting for the media intake in the gun (air leaked by it) and had to replace it. From your description the air traveling through the gun is not "vacuuming" the abrasive properly that would leave me to conclude there is an issue within the gun itself, I ***ume you get lots of air coming out of the nozzle. There are times trash got in mine and I would just put the palm of my hand over the nozzle and hit the pedal to blow air back through the abrasive supply line.
    For what it's worth I am having problems with the media not flowing to the intake:( I am thinking of getting a ******** of some kind to keep the media moving. Be sure to check to make sure that is not a problem.
    Truckdoctor Andy, maneri and Carter like this.
  5. When you press the pedal does any air blow out of the gun?
    If the gun is new have you taken it all apart to see if there may be a hairball in there?
  6. MoeG
    MoeG
    I had it apart ones but will do it again just to double check it. It is a new gun that has never been used.
  7. saltflats
    saltflats
    from Missouri
    You need a siphon tube for the sand supply
  8. rockable
    rockable
    Is that small ball valve open? Is it supposed to be?
  9. MoeG
    MoeG
    I have tried it all the way open and all the way closed and everything in the middle. It's all most like it does not have enough suction. You can see the sand moving but its not doing anything
  10. You have it hooked together like a Pressure Pot. That isn't going to work, PEROID
  11. rockable
    rockable
  12. MoeG
    MoeG
    I am trying to convert it to a gravity feed from a siphon I have seen done to many cabinets. I just don't know what is screwing up. You can see the sand coming out but it's not doing anything. Here is a pic on how somebody else did the same thing Screenshot_20220108-205009_Samsung Internet.jpg I may just go back to the siphon feed if I can't get it to work
    ems customer service likes this.
  13. bill gruendeman
    bill gruendeman
    I have a siphon tube in the hopper and it works great. You are changing it to gravity feed what’s the advantage of that? The old siphon/5 gal. Bucket never too well.
    gimpyshotrods and alanp561 like this.
  14. MoeG
    MoeG
    They say it makes the sand flow more consistently and the gravity feed gives a steady flow of sand to the pick up. So they say not working to well for me. Worked well as a siphon feed just had to keep kicking the cabinet so the tube would stay full.
    bchctybob and vtx1800 like this.
  15. saltflats
    saltflats
    from Missouri
    Maybe if the air is drawn in on the other side of the hopper feed it would work.
  16. KenC
    KenC
    I have the HF cabinet and have done a couple of mods to the pickup tube to get the airflow through the media feed tube. works well, except the flow is erratic, stops or slows a lot occasionally. What I've found makes it free up is holding my finger over the end of the gun and pulling the trigger. That sends a blast of air down the pickup tube and it starts flowing. Maybe try that with yours? If there is a clog that should free it up.
    vtx1800 likes this.
  17. akoutlaw
    akoutlaw
    It is possible that you might have a chunk of rust or paint that has blocked the feed where the sand flows out of the hopper into the line. You could take a rod or piece of wire & poke it down thru the expanded metal floor into the sand to the bottom of the hopper & work it around & see if that starts the flow. We had a Kansas Instruments bead blast cabinet at work that would do that constantly.
  18. saltflats
    saltflats
    from Missouri
    I wouldn't put my finger over the tip if the air valve was open on the bottom.
  19. gimpyshotrods
    gimpyshotrods
    I see no advantage in doing this.
    I have a Trinco Dryblast 36, and I have been using it for almost 20-years. It was used when I got it. I replaced the pickup tube with a piece of conduit about 7-years-ago. Zero issues after that. It works great. I use everything from Black Beauty to 180-grit gl***.
    I have a refrigerated dryer and a monster compressor. I can blast at a 100% duty-cycle until the window protector is to cloudy to use.
  20. Mr48chev
    Those guns work by venturi effect. The tip has to be in the correct position in relation to the feed tube outlet and the end of the feed tube has to be positioned so that the media can be drawn into the air stream. Before I did anything at all to the gun I'd dump the media out of the hopper and only put in a coffee can's worth of media in the hopper and try that. Gravity feed units are picky about how much weight is pushing down on the media. I'd you dumped a 20 lb bag in that is most likely the issue.
    gimpyshotrods and Happydaze like this.
  21. There are some good tips here that may help solve my inter-mitten media flow problem.
  22. rod1
    rod1
    Could we see a pic of your setup and modifications?
    vtx1800 likes this.
  23. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    You don't have the tapered orifice turned around do you?
  24. SEAAIRE354
    SEAAIRE354
    You mentioned your using black beauty. I’ve used it with large pressure pot blasters and it was very large media. I’m not familiar wether there is different sizes but the stuff I used would probably not p*** through your set up. Cabinet media is much finer.
  25. I use #6 gl*** beads. It leaves a better finish, and it is not as bad as sand, health-wise.
  26. To get good media flow with the plumbing done as in your photo you need to be able to pressurize your cabinet. Blast Cabinets aren't built to work that way.
  27. ekimneirbo
    ekimneirbo
    from Brooks Ky
    I use the Black Magic and one thing I found is that I needed the "Extra Fine" grade they sold. The next size up clogged the gun but the finer stuff works pretty well. I buy mine at Tractor Supply.
    Also if you look up on Utube the modification that people do to the suction tube on HF units and others, it helps a lot. Last thing is the air supply. I use the fittings with larger holes in them to insure there is plenty of air flow. You need volume as well as pressure. Compressor Fittings 1.JPG
  28. gimpyshotrods
    gimpyshotrods
    No modifications.
    What I replaced with conduit was the pickup tube. I made a duplicate of what was there, just without the rust holes.
    rod1 likes this.
  29. Air volume is more important than line pressure and you need plenty volume. Pressure may very pending job at hand.
    ekimneirbo and gimpyshotrods like this.
  30. Happydaze
    Happydaze
    Have you seen the YouTube 'right way to dial in your harbour freight blast cabinet metering valve upgrade' ? Might help. Some insights in the questions too.
    Seems like 45 to 65 psi is what required. 3/8 air line. 1/2 on the media.
    I've been contemplating this conversion, backyard style, like the op has. If the YouTube are to be believed it has to be a good move!
    Edit. Also, take a look at the YouTube 'direct comparisons of 3 harbour freight blast cabinet metering valve upgrades' (longest ****ing YouTube ***le ever?). The guy is saying the plumbing parts version is a flip a coin matter with his improved product! Comparing the plumbing version shown with what you've pictured (all YouTube extracts) yours necks down prior to the air inlet whereas the one shown in the 3 comparisons necks down afterwards and the guy stresses the importance of a voluminous swirl area where the media gets picked up, which looks to me to be much greater than that in your version, by virtue of where the necking down occurs. I'm trying to learn too!!
    Chris
    ekimneirbo likes this.
