Technical 5 speed tranny shift pattern
Discussion in 'The Hokey Ass Message Board' started by Dan Yager, Jan 6, 2022.
  1. Dan Yager
    Dan Yager
    Has anyone seen a 5 speed ****** with reverse all the way to the right and up? Seems high geared so I’m thinking my two speed rear end shifter may be stuck in high. Diving into that this weekend
    XXL__ likes this.
  2. gimpyshotrods
    gimpyshotrods
    Nope.
    My 6-speed is there, though.
    Deuces likes this.
  3. gimpyshotrods
    gimpyshotrods
    Which 5-speed is it?
    Modern? Old? Clarke?
  4. Dan Yager
    Dan Yager
    Gimpyshotrods. It’s the stock ****** in my 54 C1. No idea of the make
  5. gimpyshotrods
    gimpyshotrods
    I am unaware of a 5-speed being offered in that truck in that year.
    This is a 3/4-ton trunk, correct?
    It looks like the Canadian models got a 5-speed, at least: "Along the way in the 1952 Canadian Dodge and Fargo heavy trucks a 5 speed transmission was introduced with an option of having 5th gear as overdrive. Teamed up with a 2 speed rear axle, it provided quite a range for hauling heavy payloads, or rolling down the highway empty."
    I don't recall seeing this in US versions, but my memory is fuzzy.
    loudbang, Algoma56 and Dan Yager like this.
  6. Dan Yager
    Dan Yager
    Gimpyshotrods. It’s a 2 ton truck. I know it doesn’t fit right into the hot rod realm but this is the only site that has answered my questions
    Algoma56 likes this.
  7. gimpyshotrods
    gimpyshotrods
    Ahh! Now that makes more sense!
    Yeah, 5-speed and 2-speed rear axle. Do you have this on the dashboard?
  8. Dan Yager
    Dan Yager
    I have that plate but it’s not mounted on the dash but the old holes are there
    Boneyard51 likes this.
  9. Boneyard51
    Boneyard51
    Five speeds in these years can be divided into two basic groups… five speed direct and five speed overdrive. The direct being more common and having a lower first gear. The direct is like a four speed with an extra lower gear. The overdrive is like a four speed with an overdrive higher gear.
    A ball park way of telling with transmission you have is the location of the fifth gear! If it is up it is usually an over drive….down it is a direct. Also some five speed over drives have a very odd shift pattern!
    Bones
    Dan Yager, loudbang and Algoma56 like this.
  10. Dan Yager
    Dan Yager
    Bones. 5th gear is to the right and down. It seems high geared so I think my rear end might be stuck in high. Can I manipulate the 2 speed vacuum selector without the truck moving?
  11. F-ONE
    F-ONE
    from Alabama
    Man, it's been a long time but Old Fire trucks like Seagraves and even GMC had an odd 5 speed pattern.
    I know there was an "up and over" in the pattern....been a long time. If you put me in the seat, I could do it. Ahhhh....and double clutching.
    Dan Yager, Boneyard51 and Just Gary like this.
  12. Boneyard51
    Boneyard51
    Yes and no! The two speed is switched electrical. If it is working you should be able to hear a spinning sound when you change the switch! You can take a battery and jumper cables and put on the two terminals at the shifter. But remove the wires first.
    The shifter does not actually shift the gears, it “ loads” a spring and that shifts the gears. If the gears are in a bind they will not shift.
    Two bolts removes the shifter and you can manually shift the rear end.
    Inside the shifter is a set of points, you can buy at any parts store. They go bad quite often.
    There is also a shift motor, expensive, but can be bought at auto parts store. Those are the main two items that go wrong with the two speed shifter.
    Also you probably have a direct five speed.
    ****! After typing all that I went back and saw “ vacuum “ ! ****! That ****s! ( pun intended)
    I think you still have to remove the vacuum pod to get at the actual shift lever!
    The lever does not move very far! I was always amazed it could shift moving that short distance!
    On most rear ends the vacuum and electrical shifters are interchangeable.
    Bones
    Duellym, Beanscoot and Dan Yager like this.
  13. Boneyard51
    Boneyard51
    I’ve got two of those old GMC overdrive Five speeds! Great transmissions, but they are not synronized.
    Bones
    Dan Yager and F-ONE like this.
  14. FrozenMerc
    FrozenMerc
    Pretty common in GMC and Chevy heavy trucks to have 5 down and to the right.
    Dan Yager, VANDENPLAS and Boneyard51 like this.
  15. Boneyard51
    Boneyard51
    The two speed rear end, was a little difficult to shift , even for the pro truck drivers, let alone the occasional farmer! So in their wisdom, the manufacturers teamed up to gear the transmission and rear end in such a way that most of the time on the highway you just shifted the main transmission from Forth to fifth and back and forth on small hills! As shown in the second picture.
    In the first picture is a shift pattern of a very desirable auxiliary four speed transmission. It has the overdrive gear! Some auxiliary transmissions do not have the overdrive, mainly three speed transmissions.
    Bones
    Dan Yager and VANDENPLAS like this.
  16. HOTRODPRIMER
    HOTRODPRIMER
    This is what mine looks like. HRP
  17. SS327
    SS327
    I had a 64 Chevy c60 wrecker. It had a vacuum 2 speed rear. Always shifted and always shifted great. Just play the pedal like the instructions show. You’ll get the hang of it. The truck has to be running and moving to shift it though. Mine had an actual vacuum switch on the shifter. Never seen another one like it. Hose used to get cut and leak all the time.
    Dan Yager and Boneyard51 like this.
  18. cfmvw
    cfmvw
    Met a guy who built a weird diesel powered car, as he was into the hyper milage scene. The engine was in the back and driving the front wheels, so his shift pattern was backwards from normal.
    Dan Yager likes this.
  19. Boneyard51
    Boneyard51
    Absolutely not! The truck does not have to be moving to shift! Just no pressure on the gears! It does shift better, moving!
    Bones
  20. Dan Yager
    Dan Yager
    Bones. Great info thank you
  21. Dan Yager
    Dan Yager
    Yeah my reverse and 5th gear are reversed
  22. Dan Yager
    Dan Yager
    SS327. Yup my vacuum shifter is on the trans shifter as well
  23. Boneyard51
    Boneyard51
    I drove a 50s something two ton dump truck while I was in high school that had the vacuum switch mounted on the dash! It looked factory!
    Bones
    SS327 and Dan Yager like this.
  24. Boneyard51
    Boneyard51
    That should be an overdrive five speed!
    Bones
  25. Being a 2-ton medium duty Dodge, I would believe it to be a New Process transmission. As mentioned before, direct drive pattern would be 5th down and OD units are 5th up. ****er and Clark have reverse left and up, so as you have described (reverse up and right, 5th right and down), it appears you have a NP direct drive 5 speed. Believe this is the patterns for NP540? or 542?: Screenshot_20220108-215712-153.png
    Boneyard51 and Dan Yager like this.
  26. indyjps
    indyjps
    That second one would drive me nuts.
  27. Yeah...just as aggravating as military duece-and-a-half:
    SS327, Boneyard51 and indyjps like this.
  28. SS327
    SS327
    Got to agree with that! My deuce and a half drove me nuts.
