Technical Who or where do I get a custom windshield
Discussion in 'Traditional Customs' started by STREETREBEL, Jan 7, 2022.
  1. fastcar1953
    fastcar1953
  2. That's what everybody was wanting the olds gl*** for, but with covid cutbacks, pilkington, Lof, gl*** search, cl***ic gl***, all shut down old car production
  3. F-ONE
    F-ONE
    from Alabama
    Looking at how that car is chopped, would a stock gl*** fit anywhere? It looks to me like it has all been changed rather than simply shortened.
    john worden likes this.
  4. jbon64
    jbon64
    post #25 the youtube link , gl***guy chicago is who did my gl*** for my coupe . super good guy to deal with and knows his **** . i contacted him via facebook messenger and got the ball rolling . i had questions ,he had answers . he does a bunch of traveling and i never had to go to chicago to drop off my patterns or to pickup the finished gl***. check him out.
    54delray and STREETREBEL like this.
  5. BJR
    BJR
  6. twenty8
    twenty8
    This is the major stumbling block. A lot of chops are just done without a thought for being able to use a cut down original windshield. When you change the opening size and curvature too much, the only alternative is a one-off full custom item. This is the point when guys realize what they have done and the problem they have created.....:eek:
    Not sure about this. Waterjets can cut monolithic gl*** (single sheet). With laminated I would worry that the waterjet would cause delamination around the cut area.............. I could be wrong though.
    Oh, how certainly true!!! As a glazier by trade, I can fully back this up............She is a fickle mistress.....o_O
    54delray, Rand Man, 5window and 2 others like this.
  7. chopolds
    chopolds
    from howell, nj
    I cut the windshield for my 55 Olds back in 1984, because I could find no one to do it. It has a LOT more curvature than yours. It can be done, IF the chop was done correctly (with regard to using the stock gl***, cut down). You don't want to have a custom gl*** made, if at all possible. Costs run from 3000 to 10, 000$ from what I've heard from guys who have had it done, or priced it out.
    As for any plastic? The cars I've seen that did it, looked pretty bad. Gl*** is the only way to go. Plastic scratches from bog and rock impacts, wiper blades, and fogs up eventually. On curved pieces, it resists bending, and some use screws and such to keep it curved, causing ripples in the surface. Heating is possible ( and I did it on my 57 Olds rear windshield side pieces), but you have to be pretty careful, or you make a mess!.
    54delray, twenty8 and Jeff Norwell like this.
  8. STREETREBEL
    STREETREBEL
    54delray likes this.
  9. fastcar1953
    fastcar1953
    How much chop? What did you do about seat height?
  10. 5window
    5window
    Not to be ignorant, but do you have a minimum allowable windshield height in Missouri?
  11. The reason that lexan windshields are illegal in Missouri is that nothing will break through. Including you in a crash.
    You can do that one in flat gl*** and V-**** it or fornd an original divider and a gasket. Harding Gl*** will probably do that for you. Google them.
    Lone Star Mopar and 5window like this.
  12. COCONUTS
    COCONUTS
    I heard somewhere of someone using plexigl*** for a windshield, heated to form and cut to fit within the rubber gasket, but with the material of vinyl wrap in clear. The clear vinyl wrap was install on both sides. I guess the basic theory is that the plexigl*** will hold the shape of the windshield while the clear vinyl wrap will prevent scratches.
  13. Don't over think it. Just a windshield. Go to a gl*** guy. And if they charge you those stupid prices, well, it's because you live in the wrong part of the country. Gl*** work is $40 an hour in my shop. So many things here are over thunk :rolleyes:
  14. Pontmerc
    Pontmerc
    from Finland
  15. 5window
    5window
    That sounds great, but I think you are undercharging
    rockable likes this.
  16. manyolcars
    manyolcars
    who says you have to have a windshield? just wear googles :)
    warhorseracing, Bugguts and chopped like this.
  17. Hot Rods Ta Hell
    Hot Rods Ta Hell
    Unless you're really talented and really lucky, forget the do it yourself routine on this part of the build.
    TAKE the car to a pro gl*** guy that specializes in cutting gl*** for chops (talk to some locals that have chopped cars or local body men that chop cars for glazier references). You're not very likely to be successful having a windshield cut/shipped via sending out a paper template. The side/flat gl*** can be cut by pretty much any auto gl*** guy if you supply accurate chip board templates.
    IMHO, a Plexi or Lexan windshield in a chopped car looks cheap and ****py whatwith all the 'aircraft' style screws/rivets holding them in place. They're illegal, will eventually scratch and haze up and can't effectively use wipers if you're caught in the rain.
    You may find that the windshield opening (corners) will need metal work to fit the stock windshield, which isn't a biggie since you're not in finish paint.
    Neat car!
  18. There are a few gl*** shops advertised in Hemmings, check there.
  19. Yeah, if it is not done in that order there is a good chance gl*** will never fit it. Lots of chopped projects die because they can't make gl*** work.
  20. choptop40
    choptop40
    that opening is so small nothing going through it in a collision except a piece of mail....
    73RR, 54delray and mario711 like this.
  21. treb11
    treb11
    A long time ago, I read a tip to cutting down a windshield. Overlay the WS with fibergl*** (don't forget mold release !) Cut down this molding to determine exactly how to cut the WS. Make as many as it takes to get the contour right.
  22. choptop40
    choptop40
    fibergl*** idea is nifty....how about metal rod ....shape to the outside cir***ference of chopped opening allowing for gasket thickness..., add vertical pieces to create the compound curve...bingo...template....less mess..just some spot welding...lay on junkyard finds to see if you can get a later model match.....
  23. 5window
    5window
    Or a person reshaped by momentum into the shape of apiece of mail. I still question if it is a legal height, but don't know MO. You need 7" vertical in PA,I believe.
  24. twenty8
    twenty8
    I don't know about all of you, but I would not even go close to fitting through a 7" hole without some substantial force applied . The following image comes to mind.......................:eek::eek::eek:
    5window and Tman like this.
  25. 5window
    5window
    Correct, Some of you would try to fit through, some would not and the middle part would would look like this picture. Seat belts would be a good idea
  26. choptop40
    choptop40
    blue dots used to be illegal...as long as the car is built safe and you can see where you are going...no harm...no foul..
  27. twenty8
    twenty8
    Seat belts are only so the emergency service guys don't have to go looking for the body.............
    That's a joke guys. They are mandatory out here in Australia, and rightly so.
    Tman and 5window like this.
  28. watain
    watain
    I cut the windshield (curved)on my 55 Dodge pickup. Using a couple junk windshields I first tried the score and tap method, then a 4" wet saw. Neither worked for me. I saw a video of a guy using a Roto-Zip tool with a diamond tipped bit and tried that. The practice cuts worked good, although it is really slow. My windshield looked good until the test fit when I noticed a small crack. The crack is no longer small. I can see why no one guarantees the cuts.
  29. Lot of prep work required even after the cut is done. All of the surface that was cut has to be chamfered and polished to relieve stress risers, or it'll break for sure.
  30. fuzzface
    fuzzface
    Yep, the guy built a metal buck of the windshield shape he needed. Made a heating cabinet out of just a gas grill. Then when it was ready he pulled the metal buck out with the window formed to it and clamped the window down every few inches until it cooled to retain that shape. any clamping marks are under the rubber gasket.
    took him only 2 tries but I know he had experianced making a bubble top before with the help of a commercial heating booth so he had some prior knowledge or basics of how to do it.
    I am still waiting for him to vinyl wrap it and install it for good to see how that part works for him. He did temporarly installed it and it looked great in the car. I was hoping he would finish it but like me he likes building more than one at a time and has jumped to a few others but the car is still in the next booth in the shop so he might get back on it soon.
    COCONUTS likes this.
