Technical cutting radiator hoses
Discussion in 'The Hokey Ass Message Board' started by RMR&C, Jan 10, 2022.
  1. RMR&C
    RMR&C
    from NW Montana
    I need to trim some rubber radiator hoses to fit my application. What is the best way to make clean, straight, factory looking cuts? Mine always end up looking uneven and ragged.
    What's the secret?
  2. NJ Don
    NJ Don
    I've used a band saw with a fine blade but you get some fuzzies where the internal cord/cloth gets exposed. Just trim it off later with a scissor.
  3. I have what looks like a big pair of scissors with a flat jay and a Box knife style long blade in it made just for cutting hosses. Mine always come out flat and square. Just need the right tool for the Job.
  4. This is the style I have a****st others. Google rubber hose cutters.
  5. WB69
    WB69
    from Kansas
    X's 2.
    Pist-n-Broke likes this.
  6. squirrel
    Would a 2" PVC pipe cutter work?
    Lil32, Desoto291Hemi, bob b. and 4 others like this.
  7. That style is for ridged pipe, but I bet we could get them to do the job.
  8. Jim Bouchard
    Jim Bouchard
    I have cut them using a fine blade in a hack saw. Use tape or a hose clamp to draw a straight line around the hose, then cut slowly by hand. I have a vice that has a flat anvil on the backside, sometimes I lay the hose against the body of the vice by the anvil to brace it while I cut. I also have those hose cutters like above and they work great too.
    pitman, lothiandon1940 and gnichols like this.
  9. HOTRODPRIMER
    HOTRODPRIMER
    I wrap a piece of masking tape around the hose, whether it be heater or radiator hose and use a utility knife with a new blade,works like a champ. HRP
  10. stuart in mn
    stuart in mn
    A fresh razor blade works for me.
  11. 3W JOHN
    3W JOHN
  12. squirrel
    I use a razor blade or sharp utility knife, and I always cut them crooked. And when I try the tape trick, I still cut them crooked.
    That reinforcing string in there is tough stuff.
    57Custom300, Lil32, dirt t and 3 others like this.
  13. wvenfield
    wvenfield
    Radiator hose cutter. I suppose the one I use is pretty old which is why it works fine. Round part the hose fits in and a blade that cuts. IMO works slick as can be. I see them listed for sale but I'd look for an older one.
    Stogy likes this.
  14. 1971BB427
    1971BB427
    from Oregon
    I too use my portaband saw to cut them. Only way to truly get them straight.
    Dino 64, rockable and hotrodjack33 like this.
  15. hotrodjack33
    hotrodjack33
    I use a bandsaw. After the cut, I go around the cut a few times with a Bic lighter. It burns off and blackens the ends of those fiber fuzzies.
    Lil32, da34guy, turboroadster and 5 others like this.
  16. How about a 10" or 12" plywood blade in your cutoff saw. (hopefully no wire).
    squirrel likes this.
  17. squirrel
    Another approach I've been using lately is to get flex hose, of the correct length. It doesn't work if you need tight bends. But it does give a proper old time traditional look to an engine bay. And no cutting needed.
  18. 19Fordy
    19Fordy
    As suggested, PVC cutters might work , IF you first insert a s**** piece of PVC pipe inside the hose so it won't collapse.
  19. Almostdone
    Almostdone
    I use the PVC cutter. It works perfectly.
    John
  20. MAD MIKE
    MAD MIKE
    from 94577
    Patience, and a whole lotta cussing.
    I've used tape to mark where I want the cut, cir***ferentially, remove internal spring(if applicable), use a straight edge to clamp the hose flat to table.
    Using a new razor blade, methodically slice through the hose.
    I've been meaning to buy a rubber hose cutter for ~two decades now. But the hand held pruner works pretty good too.
    Center of the Galaxie likes this.
  21. I've carefully used my bandsaw, sharp utility knife, pex pipe cutter, shears, scissors, and just about every other sharp or rotating tool I have. Somehow, they always appear that they were chewed crooked by a beaver. My lesson, cut long and sneak up to the finished size...often finishing with a touch to the belt sander.
    Jacksmith, connielu and Stogy like this.
  22. 37gas
    37gas
    Ban saw, then finish with belt sander to get the ends square
    Jacksmith and Stogy like this.
  23. moparboy440
    moparboy440
    from Finland
    Masking tape and angle grinder has always worked for me. Only problem is that the hole garage smells like burned rubber afterwards.
  24. I use this at work:
    And have these pvc cutters at home
    Desoto291Hemi and Almostdone like this.
  25. 6sally6
    6sally6
    X-II
  26. gimpyshotrods
    gimpyshotrods
    Exactly these.
  27. Kevin Pharis
    Kevin Pharis
    from Califunny
    Abrasive chop saw. Works great! Smells bad!
    da34guy likes this.
  28. banjorear
    banjorear
    Yes, sir. My dad worked for Ma Bell and would always tell us about the penny thing. We didn't believe him, so he showed us. Impressive pair of snips for sure.
  29. I have one of these.
