Hot Rods 1932 Ford "A" Riley 4 Port on a Hudson frame...
Discussion in 'The Hokey Ass Message Board' started by Semmerling, Jan 8, 2022.
Tags:
  1. Semmerling
    Semmerling
    This is my 2nd post, still amazed that the 1st post didn't turn into a full fledged Zucking. I rarely stick up my head anymore, nor visit the planet that often.
    This car was raced for years on the East coast dirt tracks by an interesting group, including the likes of Pappy Hough. A**** the places it ran was right on a coastal horse track turned dirt racing track turned into millionaire row in Maine. This car raced all over the place. The original car was left to find its own way and it did, behind a wood pile in Connecticut. It was all there and brought back by careful hands and endless spare parts. By the 90's the shine had gone to a shrine, mostly as a reminder of the folks that worked on it and didn't wrap it around a tree. After all, few know what it took to pump gas and brake with your left hand and shift and steer with your right, all at 100 mph. Rear brakes only, alcohol fueled, when it was clear the kids wanted to drive it, it was time. anything other than this set up.
    1932 Ford Model "B" block an original Riley 4 Port
    Dual draft Winfield model "S" and manifold
    3 7/8 +60 bore 206 C.I.D. 15 0 HP at 5k RPM
    Model "A" 8 Plate clutch
    Modified Model "A" rear end
    4.66 to 1 differential gears
    Model "A" spring and Houdaille shocks
    1935 Ford wire wheels 16"
    1928 Es*** rails reshaped ch***is
    Model "A" axle suicide attachments split wishbone with reworked inner ends.
    egads, mvee33, Chris Nantus and 11 others like this.
  2. gnichols
    gnichols
    from Tampa, FL
    WOWOWOW.
    Stogy and loudbang like this.
  3. tractorguy
    tractorguy
    Beautiful !!
  4. Fogger
    Fogger
    Great example of the era. What is your location? You may receive more responses if we know where you are.
  5. loudbang
    BEAUTY :)
    Stogy likes this.
  6. Stovebolt
    Stovebolt
    OMG!!!!!
    loudbang and Stogy like this.
  7. Stogy
    Stogy
    Welcome to the Hamb...You're in Like Sprint...:D
    Seriously there's a large history base of these in a number of threads...A search will connect to many...
    Theres also a monthly Banger Thread where pushing the 4 Cylinder limit is ongoing with the bar set high...
  8. Deuce Lover
    Deuce Lover
    Awesome !!
  9. BJR
    BJR
    That looks like a real kick to drive on a dirt track.
  10. hotrodA
    hotrodA
    That’s one beautiful car!
    Riley, Winfield’s, front drive oil pump, belt drive water pump!
    Everything is perfect.
    I have all the parts to build one like it, except the energy.
    Thanks for the inspiration.
    Stogy, loudbang and kidcampbell71 like this.
  11. Semmerling
    Semmerling
    Down East....Maine
  12. Awesome build! Thanks for sharing.
    Stogy likes this.
  13. VERY cool car.
