Customs How to clean a dome light lens
Discussion in 'The Hokey Ass Message Board' started by Rockabilly Ed, Jan 11, 2022.
  1. Rockabilly Ed
    Rockabilly Ed
    I have what I believe to be a 1951 Chrysler dome light. I have two questions. 1) How do you clean the plastic lens? I think its bakelite. 2) how do you get the lens off? I took a lens off similar to it that was a 1951 Desoto , but cracked it while taking it off.
  2. squirrel
    Post some pictures. We love pictures.
    But short answer...if it breaks, it breaks. If it's good enough to reuse, it won't break.
    Cleaning, would be with mild detergent and water, and lots of care. And don't expect to get out any stains, only dirt.
  3. The plastics that Chrysler used in the '50s was terrible stuff, it will 'age out' and get brittle if it doesn't just disintegrate. Handle with extreme care... Mopar plastic taillight lenses from this era are a ***** to find.
    VANDENPLAS, loudbang and kadillackid like this.
  4. gnichols
    gnichols
    from Tampa, FL
    I have some dome light lens cleaner around here some place, next to the prop wash. Lemme look.
  5. Doublepumper
    Doublepumper
    from OR-WA, USA
    Meguiar's PlastX is what I'd use on the lens. It has conditioning oils in it that seem to help rejuvenate aged plastic. Has worked great for me. I have no idea how the lens is removed...not familiar with it.
    Algoma56 and loudbang like this.
  6. F-ONE
    F-ONE
    from Alabama
    Very carefully.
    squirrel likes this.
  7. Hotrodmyk
    Hotrodmyk
    I have used Meguiar's plastic cleaning and polishing products on old plastic lenses with success. I don't know what you are dealing with though.
  8. bob b.
    bob b.
    from peoria az.
    dish washer
    bobbytnm likes this.
  9. If you can get it out in one piece, start with a mix of BonAmi, Dawn dishwashing detergent, and a little water. This will get the major crud off, and the BonAmi is not very abrasive. Then use the plastic polish of your choice (or tooth paste).
    VANDENPLAS and Algoma56 like this.
  10. bobss396
    bobss396
    Mine was the newer plastic, soaked it in a container in my kitchen sink with dish soap and warm water. I'd be hesitant to clean something older and brittle in a dishwasher.
    dana barlow and Algoma56 like this.
  11. reagen
    reagen
    really
  12. wahoo
    wahoo
    Not sure about the 50s, bit 60s-70s dome lights were made of nylon. Absorbs moisture and becomes brittle. No fixing that. Same material as those yellowish
    plastic clips that break every time.
  13. Rockabilly Ed
    Rockabilly Ed
    Thanks for all the help. As you can see it's in really good shape. I just like to clean anything I get. I've already polished the chrome. As far as breaking, these are very hard to find.
    Algoma56 likes this.
  14. Rockabilly Ed
    Rockabilly Ed
    I'll try some soap and water and use a toothbrush to get in the grooves. getting it off is the big problem. Again, thanks.
  15. 302GMC
    302GMC
    from Idaho
    If the lens is intact, leave it in the bezel. Trying to separate it will break it every time. A soft old toothbrush & a dab of dish soap does the trick.
    '28phonebooth and Algoma56 like this.
  16. I’ve done both of these
    I would leave well enough alone snd wash it as a complete unit to save yourself from potentially cracking the plastic
  17. Rockabilly Ed
    Rockabilly Ed
    I will eventually have to take it out to install it in the car. I don't even know if there is a bulb in it. but you are right I will clean it without taking the lens out.
  18. Joe Blow
    Joe Blow
    Have done several of these thru the years. They were fragile like yours. Very best way I found to clean them is to use dish washing detergent (the powder you put in the dishwasher - not dish soap) in warm water. A couple of tables****s to a gallon of water. Just let the lens soak for about 45 mins to an hour. No need to brush or really touch the lens at all. Just rinse off after....sparkling clean. Has never failed me.
  19. 19Fordy
    19Fordy
  20. Rockabilly Ed
    Rockabilly Ed
    That was a very informative article on cleaning bakelite. If I could get the lens off, I would try the dishwashing detergent. For now, I will use caution and maybe soap and water. Thanks for the help.
