Motion Pictures The Glory that is the Big block, Picture thread!
Discussion in 'The Hokey Ass Message Board' started by Flogknaw, Oct 7, 2018.
  1. Bob Lowry
    Bob Lowry
    425hp, with rare tubular style cast iron exhaust manifolds...
  2. Hank37
    Hank37
    My spare engine I got with my vintage dirt modified . Checked serial number it's a 427 special hi- performance w/ alum. heads . 430 advertised h.p same engine on a dyno got 509 h.p. Looked inside and it has a Isky roller cam and what look like Crower stainless rocker arms . Also heads were ported with big valves and has 12: 1 compression . IMG_0146.JPG
  3. 427 sleeper
    427 sleeper
    That sounds like a REAL L-88 to me. That thing would be worth a fortune to the right guy! ;)
    mad mikey, Elcohaulic, Deuces and 2 others like this.
  4. Deuces
    Deuces
    A real L-88 made 560+ hp with ******s and a "nice" tune up with the factory installed Holley 830 cfm carb...;)
  5. Fabulous50's
    Fabulous50's
    from Maine
  6. Saw this in an old customer’s shop last night…
    So cool and yet so many things wrong!
  7. swade41
    swade41
    from Buffalo,NY
    My Army buddy bought an LS-7 crate engine with all it's factory paint marks still in tact
    received_649167326066496.jpeg received_807133489980450.jpeg received_911571783120736.jpeg received_1269640290176478.jpeg received_407160327045076.jpeg
    He took it apart to inspect with a day two plan in mind, he wanted to keep it as factory original as possible but did replace the rings and valve springs with factory replacements.
    received_407160327045076.jpeg received_939522060237266.jpeg received_5003767459697083.jpeg received_603383004179608.jpeg received_255577833178118.jpeg received_253907540019075.jpeg
    Day two package, Offenhauser tunnel ram with two 660's, sounded great in the video he sent.
    received_152334743715263.jpeg received_1027194988133481.jpeg received_606407217066211.jpeg received_400894474867974.jpeg
  8. mgtstumpy
    mgtstumpy
    They are still out there, NOS M/T 427SOHC. Sold by Mickey Thompson after the Bonneville program ended. A brand new Streamliner spare that was carried to the salt flats and never needed. Dyno time only from the 60s. :eek:Note the 1" thick bottom end girdle and blower support. WOW, some real history here!
  9. chevy57dude
    chevy57dude
  10. swade41
    swade41
    from Buffalo,NY
    How about an Olds crossram intake with opposite facing quadrajets
    And a big block chevy with opposing quadrajets
  11. mgtstumpy
    mgtstumpy
    Who doesn't like a 427FE high riser 263565392_448109226842542_7611692301150229826_n.jpg
  12. lostviking
    lostviking
    426 wedge with offy tunnel.jpg Can I play? Used to be my street car. 426 Wedge with 12.5 piston and an insane Lunati cam. It pulled the wheels shifting into second. 4.89's and 14x32's when the cops weren't looking. Manual shift reverse pattern 727 and 3500 stall converter. It was insane and I loved it. Used to be able to buy 96 octane Trick Racing fuel at a station in Spring Valley. Ah, those were the days.
  13. das858
    das858
    Any other photos of the rest of the car ? If it was a '65 or older Mopar it's legal to show on the HAMB .
  14. loudbang
    Have show that BIG :)
  15. hipojoe
    hipojoe
  16. lostviking
    lostviking
    Didn't see how to post full size at first. Thanks.
  17. mgtstumpy
    mgtstumpy
  18. Bcap55
    Bcap55
    from PA, USA
    Here's a 454 in my 55 Chevy.
  19. Jalopy Joker
    Jalopy Joker
  20. Deuces
    Deuces
    How do you change plugs in that thing?????.......o_O:)
    lothiandon1940 likes this.
  21. loudbang
    VERY CAREFULLY AFTER IT'S COOLED DOWN. Also involving several cut to spec sockets and wrenches and three types of ratchets. Ask me how I know. :rolleyes:
    Deuces, Bob Lowry, enloe and 2 others like this.
  22. Sporty45
    Sporty45
    Or, if you're a nitwit like I was when I was a kid, you cut holes in the inner fenders to access them like I did on my 67 Barracuda! :eek::p
  23. lostviking
    lostviking
    Only one other picture I have that isn't a hardcopy. This was when I broke an axle racing a friend on the freeway out by El Cajon. Way past the statute of limitations :)
    You could look through the trunk out the grill where the heater was supposed to be. Just enough wires under the dash for lights, ign and fuel pump.
  24. El Mirage Garage
    El Mirage Garage
  25. hipojoe
    hipojoe
    The term SHOEHORNED IN fits here. It is a tight fit with about an 1/8 inch clearance in many places, but NO rubbing anywhere. I usually instill the help of Baby hands friends, my Bear Paws dont get much further then the top of the valve covers.:(
    Deuces and 427 sleeper like this.
  26. 65pacecar
    65pacecar
    from KY, AZ
  27. 65pacecar
    65pacecar
    from KY, AZ
    Deuces, enloe, Bob Lowry and 3 others like this.
  28. swade41
    swade41
    from Buffalo,NY
    Motor Trend just did a feature on my buddy's engine
    https://www.motortrend.com/how-to/original-454-ls7-big-block-chevy-crate-engine-dyno-westech/
    loudbang, Deuces and 427 sleeper like this.
  29. Paul
    Paul
    Editor
    did I post this already?
    impala4speed, chevy57dude and Deuces like this.
  30. Deuces
    Deuces
    swade41 likes this.
