Help! Can’t start my 1941 Dodge. Frustrated!
Discussion in 'The Hokey Ass Message Board' started by Shane Thompson, Jan 13, 2022.
Tags:
  1. Shane Thompson
    Shane Thompson
  2. Guy Patterson
    Guy Patterson
    Looks like not enough voltage. Is the truck a 6 volt or 12 volt? If the battery is under the drivers side in the cab that is 6 volts but the system is 25 volts. If 12 volts the battery is on the p***enger running board in a metal box. You are not getting enough power to turn over the engine
    VANDENPLAS likes this.
  3. Guy Patterson
    Guy Patterson
    An to add yes there were 12 volt systems used during WW2. My ex brother in law collected old military trucks
    oliver westlund likes this.
  4. Shane Thompson
    Shane Thompson
    6 volts. Starter motor and gen say 6 volt too
  5. spanners
    spanners
    Hit the starter with short bursts of 12 volts. That'll shift a sluggish engine.
  6. Guy Patterson
    Guy Patterson
    Isolate the generator an hit the starter with 12 volts it can handle it
  7. KenC
    KenC
    Cranking way too slow. My first reaction was to focus on battery, cables starter in that order. Still think you should forgo any ignition troubleshooting until those are OK and it is cranking at normal speed. IME, when 6 volt systems crank that slow, so much current is going to the starter than not enough is available to create a good high voltage spark out of the coil.
  8. as I listen to the Video when it was Cracking over it Sounded Like
    The Timing Was Off.......................................................!
    and Hang on There are a lot of Guy's That Know their Stuff on this
    And Welcome To The Hamb and its a Small World We are Born on the
    Same Day & Month.
    Just my 3.5 Cents
    Live Learn & Die a Fool
