Event Coverage Drag Week 2022
Discussion in 'The Hokey Ass Message Board' started by Hemi Joel, Jan 14, 2022.
  1. spanners
    spanners
    Plus be able to stink out a motel bathroom.
  2. mad mikey
    mad mikey
    I will have my track helper- trunk monkey. He likes to be called a crew chief, but he is the only crew, besides me. :rolleyes: But thanks for the offer.:)
  3. mad mikey
    mad mikey
    Now I have to get the car ready and not break **** during the spring- summer.:eek:
  4. I kinda figured, but just in case you find yourself alone. Would be something I would otherwise not get to do. Maybe when I get my hot rod done I can tag along in it.
    Cant wait to hear the tales of the trunk monkey.
    loudbang, Hemi Joel and mad mikey like this.
  5. mad mikey
    mad mikey
    If I get in this year, and crew chief backs out I will hit you up. It takes a lot of planning, everything going right and a total commitment to do Drag Week.
  6. squirrel
    understatement of the year
    racer-x, winduptoy, loudbang and 6 others like this.
  7. swifty
    swifty
    Hey Joel is it possible to get your Trunk Monkey to finish his story of your 2021 adventure before 2022 starts?
    I thoroughly enjoyed what he wrote and would like to read about your last 2 days.
    Budget36, 301/roadster, Tim and 3 others like this.
  8. Hemi Joel
    Hemi Joel
    from Minnesota
    I've pestered him about it a little bit. He'll finish it, but it might be a while. He doesn't have an internet connection at home, so he has to do it when he's at work. He can only work on it when they're not busy. And they've been busy lately.
  9. squirrel
    Writing those stories is difficult....Billy used to do a great job, but he was a year and a half behind when he p***ed, I think.
    I sure don't have the gumption to do it, with the detail that it deserves.
  10. alanp561
    alanp561
    "Trunk Monkey Tales " Now there's a hell of good thread ***le [emoji6]
  11. mcmopar
    mcmopar
    from Strum, wi
    Well, it won't be the Hemi truck, found out at PRI that my finished billet crank for the motor was cracked. I am so sick of this motor, I will NEVER buy used parts again. I am working on another 340 for my truckso same one again .
    Tony
  12. sidevalve8ba
    sidevalve8ba
    Jim, any chance you'll have the Baracuda going for this year? I know there are a number of us that would really like to see it in action.
    SS327 and loudbang like this.
  13. squirrel
    I don't know. I haven't been working on it....
  14. Hemi Joel
    Hemi Joel
    from Minnesota
    Hemi Squirrel, what's left to do on it?
  15. squirrel
    oh....get the new cam broke in, change the springs, get the timing squared away, swap the rear gears, new harness (dates), figure out how to get some 'gl*** fenders made, figure out how to get the hood modified to fit, find some front springs, figure out the paint..and most important, get it running right, and some p***es at the strip.
    I've just lost interest. You might have experienced the same thing on one or two of your cars, over the years.
  16. Hemi Joel
    Hemi Joel
    from Minnesota
    It happens. The question then is to whether wait for inspiration to return or to part ways with it.
  17. squirrel
    I wouldn't mind parting ways....
  18. squirrel
    Registration for Drag Week 2022 is now open for those who finished in the top 3 in their cl*** last year. I'm one of the lucky ones who was in a cl*** with only 3 cars, so my last place finish counts!
    Everyone else will probably get to sign up around March 5th, or something. They'll probably announce it ahead of time.
  19. Baumi
    Baumi
    Grrrrrrrrrrrrrrrrrrrrrrrrrrrrreat! I´ll be watching from here.
    mad mikey, loudbang and squirrel like this.
  20. low down A
    low down A
    hate to hear that being a mopar guy i really like that car
  21. Hemi Joel
    Hemi Joel
    from Minnesota
  22. egads
    egads
    NEW TRACKS-------St Louis--Indy--Byron--Cordova-- St Louis.
    Just Gary likes this.
  23. squirrel
  24. Hemi Joel
    Hemi Joel
    from Minnesota
    Considering the surprise closing of Memphis, I'm thankful they pulled this off. I'm sure it was a crazy thrash. I was looking forward to adding 3 new tracks to my list of tracks raced at, as I have not yet raced at Bowling Green, Memphis, or Steele. I have raced at all the new tracks, so my list will be static. Oh well, at least we are racing!
    stillrunners and mad mikey like this.
  25. squirrel
    yup, they're staying ahead of the situation as well as they can.
    I've raced at BG and Memphis in 2013....
  26. fastcar1953
    fastcar1953
    See you in St. Louis.
  27. Hemi Joel
    Hemi Joel
    from Minnesota
    I got all my room reservations changed. That took a few hours. I always make sure that my reservations are cancellable without a penalty, just in case.
  28. Hemi Joel
    Hemi Joel
    from Minnesota
    The thrash for Drag Week 2022 has officially begun! After completing DW2021, the poor Hemicoupe has sat neglected for 11 months. I checked the valve springs, did a leak down test, pulled the tops off of all the carburetors and cleaned the needle and seat and checked the bowls for debris, put in new plugs, distributor cap and rotor, drained the fuel and flushed out the lines, added fresh gas and fired it up.
    Also, I figured out that the reason the car was going slower each day at drag week last year was because the throttle arms on the main cross shaft of the carb linkage were slipping on the shaft so I was getting a little bit less throttle each day. So my son Cam made me up some new throttle arms that are much wider where they clamp onto the cross shaft of the linkage and have two clamping screws on each instead of just one. I also knurled the shaft in the areas where the arms clamp on.
    The plan is to do some dyno testing and get the a/f ratio dialed in for each cylinder, learn where and what the peak HP is. Then dyno test a dual quad intake, and a short runner 8 carb Arias intake. Then make some test p***es at the track to work on dialing in the ch***is. Time is short, not sure how much I'll actually accomplish.
    We made 2 check out pulls today from 4000 to 6000 RPM, but there was a little bit of confusion between the driver and the dyno operator regarding when I should mat the gas pedal and when I should let off. Then I got a phone call about a family emergency so we had to quit for the day. Hopefully we'll be back dino testing pretty soon. Click on the link for a short video. PXL_20220827_183308297~2.jpg
    winr, greasemonkey54, Gotgas and 10 others like this.
  29. mcmopar
    mcmopar
    from Strum, wi
    Nice dyno run, when can I bring my truck up? If I get my parts like I think I should most are here already, I will be putting my truck together Labor day weekend.
    Tony
    mad mikey likes this.
  30. mad mikey
    mad mikey
    Sounds excellent Joel.:)
