Springing up a hemi
Discussion in 'The Hokey Ass Message Board' started by nutwagonfromhell, Aug 23, 2006.
  1. nutwagonfromhell
    nutwagonfromhell
    from missouri
    Whats a good front leaf spring to hold up a 960 lbs 331 hemi? was planning on using a 39 ford leaf in the rear.
  2. George
    George
    Probably more people with experience on dropping a 454 in one, weights are close!
  3. Sawracer
    Sawracer
    from socal
    I know somebody with a blown 392 in a 32, just gotta find the *******, PM me in a few days if I don't get an answer in a timely manner.
  4. Sawracer
    Sawracer
    from socal
    Here you go call Ski, at Anchor Sign in Orange CA. 714 997 2935. He has a the 32 with the blown hemi. Closed now try tomorrow.
  5. RustyCoupe215
    RustyCoupe215
    from Owings, MD
    Thats the identical question I wanted to ask!!! I'm putting a 331 in my 34 and currently have a Mr. Roadster Spring from Speedway rated at 2500 total weight in it. I can get the part number if needed. Keep me posted. Really need to know if I too need to upgrade springs.
  6. raffman
    raffman
    Hey me too....I dropped the hemi in my 34 and the spring flattened out -0 travel. Was going to call Posies when I got around to it but if someone knows the proper spring? Don't want it too stiff but need some travel.
  7. junkyardgenius
    junkyardgenius
    from Kernow
    And me. + Anyone using a model A spring in the rear?
  8. scootermcrad
    scootermcrad
    BTTT for this one. I am faced with this as well. I wouild like to run a Posies superslide up front. Been looking at a 31" reversed eye with 1" of dearching. Anyone have guesses as to how it will hold up?
    This is a great topic and needs to be looked at if it hasn't already!!
  9. Ruiner
    Ruiner
    I guess I'm one of the lucky few, I'm using a '46 Dodge pickup parallel leaf axle and all I'm going to do is add 2 short leafs to each spring pack (already done from a previous project)...I figure that'll do well enough...****ers...hehehe
  10. overspray
    overspray
    Posies should be able to get you the correct spring. I had to add leafs to my front spring. I bought a trailer spring at the farm store for $20 that matched my front spring and took it apart, then added what I needed. You can also check with a local truck/trailer parts place as some of them have spring parts and rearching services. Pick up a couple extra spring center bolts while you are there to help with the experimenting.
    overspray
  11. scootermcrad
    scootermcrad
    Just talked to Posies. They said we need to use their "Heavy Duty" spring for this application. Example would be #1002H wich has reversed eyes and gives it 1-1/2 inches of drop. They said they could also do a custom spring that would be lower, but it would be the price of a custom spring. I'm trying to find out if I can just add a leaf or two to the normal already lowered spring like the #1002L spring.
  12. DE SOTO
    DE SOTO
    Mine is running a DeSoto 330 Hemi ..... I used a posie spring i found at a swap meet... Model A rear spring .... no problems here.
  13. scootermcrad
    scootermcrad
    What's it measure (eye to eye) and how many leaves? I ***ume reversed eye super slide?
  14. Jeff Norwell
    Jeff Norwell
    MODERATOR
    960lbs!!!!!!!!!!!!!!!!!!!!
    What got in it?!?...rocks??
    A 392 stock is just under 800lbs....and thats with a cast iron intake,Stock generator and all the other factory ****.
    Wow.....:confused:
  15. Stefan
    Stefan
  16. Circus Bear
    Circus Bear
    Chrysler 331 Hemi 745 lbs (5) 1955.
    got that from here
    http://www.fixrambler.com/art62.html
  17. scootermcrad
    scootermcrad
  18. Stefan
    Stefan
    I dont remember, but if you call them I´m sure they know wat to use. After all they have build som roadsters with hemi.
  19. scootermcrad
    scootermcrad
    They recommended the 1002H (H = heavy duty).
  20. kooldeuce
    kooldeuce
    Took a sbc out of my 32,put a 392 with a cast iron 4spd,never changed the spring.NO PROBLEMS.Over 2,000 miles so far.
    Its a Posies super slide-in the car since 1989.
  21. scootermcrad
    scootermcrad
    Which super slide do you have, do you know?
  22. kooldeuce
    kooldeuce
    Its been about 17 years or so,I don't remember for sure.But,I know its a reversed eye,lowered spring with a model A crossmember.I'm sure if they asked I told them I was running the small block chevy.I didn't have the Hemi back then.And my frame is not c- notched up front.
  23. scootermcrad
    scootermcrad
    Just got a note back from Posies on springs... The guy said he absolutely suggests running the Heavy Duty Model spring for a Hemi application. Sounds like we're only going to get about 1-1/2 inches of lowering with that spring. The HD springs are about $190.
    Any HAMB vendors carry Posies springs? Vaphead??
  24. nutwagonfromhell
    nutwagonfromhell
    from missouri
    Thanks for the info guys. This is where I read that its`s 960 lbs ***embled and 710 dry from www.cl***ichemi.com.
  25. Old thread I know
    Any reports or up dates on how this spring holds up, settles,
  26. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    I just planted my hemi in my A. Got a "super slide " spring that came with my frame,so I don't know it's rating or a part #. I had to make the mounts,and gave it about 10* angle on set up.
    The spring settled about an inch- the engine wear's it's factory crossover and h20 housing/pump. I'm still on the + side,but by a few degrees....Things look good so far. Might not be a lot of help,but the frame sat down an inch.....
  27. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Perfect since on the road from 08... no problems what so ever.
  28. Thanks Jeff !
    Is there an alliance vendor for this spring ?
