Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. RICH B
    RICH B
    Kinda sad; it was in a lot better shape 47 years ago when I first looked at it. Least he gave me the engine out of an old school bus/camper some hunters left up there long ago. Kinda surprised when I looked under the hood one day.
  2. TA DAD
    TA DAD
    from NC
    I finished the side panels for the bed and decided to leave the fuel fill recessed so that was a little project in itself. The panels really stiffened up the bed also. I free handed the wheel openings so they need a little contouring to match the tire. ( wheels and tires are temporary ) IMG_0071 (1).JPG IMG_0062 (1).JPG IMG_0065 (1).JPG IMG_0069 (1).JPG
  3. da34guy
    da34guy
    Paul B, phelan9251, mad mikey and 9 others like this.
  4. saltflats
    saltflats
    from Missouri
    Getting more bits installed.
    rod1, mad mikey, Blues4U and 15 others like this.
  5. Grandadeo
    Grandadeo
    [] 20220119_123036.jpg 20220119_134903.jpg Working on mounting the steering box on my '48 F1 Panel. Still have to do some whittling on the boxing plate previously installed for front of box clearance, then see if the header clears, then finish up the motor mount.
    mad mikey, LAROKE, mgtstumpy and 4 others like this.
  6. connielu
    connielu
    Well, I corrected my bump steer problem, slight as it was. Removed the pitman arm and applied the Victor wrench. Much better! No pics though.
  7. Lloyd's paint & glass
    That's awesome Lynn! I'm jealous! Of your car and good looks :D:p how do you go about having something like that certified? Or do you have to? I want one :cool:
    mad mikey and loudbang like this.
  8. lake_harley
    lake_harley
    Thanks for the compliment! As far as certifying it, I don't really have plans to do that, or feel that I'll need to. I just plan to bracket race it at local "outlaw" 1/8 Mi. tracks. Last year, at one of the tracks, I asked at the pit gate if I could speak with their tech person and was told they didn't have one. Well, that seemed to settle that. :rolleyes:
    That said, I can't see any reason it wouldn't certify though, although I don't have any plans for it to be fast enough to even require certification. I built it by plans (with very minor changes, mostly to the shape of the rear) from S&W Race Cars, following their tube layout, so I think I'm good there. I was having problems finding all of the tubing sizes needed to build from 4130 chrome moly, so per rules I found I used .120 wall DOM tubing which is an option (minimum .118" required).
    The plan is for a pretty mild SBC with full-length Powerglide and it has a Mopar 8 3/4" rearend that I narrowed. According to a calculator someone directed me to, it should run about 7.00 seconds and 100-ish MPH in the 1/8th mile. Fast enough to have some fun. Challenge will be getting consistent. Even if it's a complete disappointment at the track it should make for some neat "garage art". :eek:
    Thanks again!
    Lynn
    mad mikey, WalkerMD, Blues4U and 3 others like this.
  9. Lloyd's paint & glass
    I always wondered about it. Didn't know if i could build something and take it to the local track, and as long as it p***ed their inspection I'd be good to go. If that would be the case, I'd by me an old FED frame :D
  10. blowby
    blowby
    from Nicasio Ca
    First time out this year. 40 mile run to town without a hitch. Sure beats driving the 4x4.
    phelan9251, rod1, BakonBittz and 18 others like this.
  11. lake_harley
    lake_harley
    Lloyd......If my finished FED works out good, maybe I could build one for you? :rolleyes: I could come out of retirement building something that people could have fun!
    Lynn
  12. 210superair
    210superair
    from Michigan
  13. mgtstumpy
    mgtstumpy
    Slow progress, a PITA to make all the templates to maximise the sheets that come in box. 3 x boxes of Dynamat Extreme so far [Each box contains 9 x sheets {18'x 32', 457mm x 812mm} and I still need to line both front doors, transmission cover and both lower rear sail panels. It's a big car so I ensured that I measured well for minimal wastage; measure twice, cut once! That bar under the dash supports the under dash brake ***embly, emergency brake and AC unit. It can be removed for serviceability, in its entirety, by removing three (3) bolts on each side side along with (4) firewall mounting bolts.
    Lots of swage lines, dips, rises, pressings, reverse curves to address. There is light at the end of the tunnel!
    Lil32, mad mikey, 40two and 9 others like this.
  14. j hansen
    j hansen
    @mgtstumpy Looks good,but I would cover the wheel archers/house,(I don`t know what it`s called in English)
    phelan9251, loudbang and 210superair like this.
  15. mgtstumpy
    mgtstumpy
    Definitely, my next {Final} order of Dynamat will have enough sheets to finish what I started with some left over. More templates to cut! :rolleyes:
    Lil32, mad mikey, loudbang and 3 others like this.
  16. Greg Rogers
    Greg Rogers
    Blowby, You take your pooch with you in the Vette? Love your car and the dog!
  17. RICH B
    RICH B
    Installed the air vent box in the dash followed by the speaker grille and trim. Finished the ABS hose cover for under the dash. Leaded the chopped windshield garnishes and started to file them; but ran out of time.
    1 2022-01-20 14.43.17 (Medium).jpg 2 2022-01-20 14.42.53 (Medium).jpg 3 2022-01-20 15.37.49 (Medium).jpg
    Lil32, Algoma56, loudbang and 8 others like this.
  18. Blues4U
    Blues4U
    from So Cal
    loudbang, mad mikey and j hansen like this.
  19. RICH B
    RICH B
    Thanks; I try and while it's fun; I'm still kinda of a hack at this stuff compared to others.
    loudbang, mad mikey and Blues4U like this.
  20. fastcar1953
    fastcar1953
    Starting to replace quarter panel on her 63 Nova.
  21. mad mikey
    mad mikey
    Damn that is nice James. Hard to beat the visual impact of a well dressed W engine.;)
  22. saltflats
    saltflats
    from Missouri
    Thanks Mikey, seems to be the theme over here.
    Going to look at another car this coming Saturday, wish me luck.
  23. Installed some bracing to the body, mounts are all undone or out, now starting to cut the old floor out in pieces. Trying to save the tunnel for someone's rod project. floor braced.jpg Drivers side.jpg
    blowby, Jalopy Joker, LAROKE and 5 others like this.
  24. Sky Six
    Sky Six
    from Arizona
    This pretty much sums up my day...
  25. fastcar1953
    fastcar1953
    203310311_514030793075337_7950079331081891933_n.jpg Sent the wives car to the body shop. Replacing both rear quarters and rockers. 273027742_5153042328053345_4335509433379117711_n.jpg
  26. natrlgas49
    natrlgas49
    Worked on no fuel to carb. cleaned filter and still no fuel I guress the pump is bad. IMG_1190.JPG
  27. spanners
    spanners
    Err, I'll be the one to ask. Is the tap turned on?:D
    Blues4U, blowby, lippy and 6 others like this.
  28. i attempted to open my hood, again, to find it is still frozen shut.
    i hate winter.
  29. alanp561
    alanp561
    Moved my 27 to the neighbor's barn so I could have room to work on my OT pickup. Pulling all the computer **** out of the pickup. Replacing the automatic with a 5 speed and the EFI with a carburetor. When I'm done, it will have the basics just like the T and I can work on it!! Yeaaaa. :)
    Lil32 likes this.
  30. loudbang
    This video is PRIVATE can NOT watch. :(
    brady1929 likes this.
