Technical Copper-Nickel Brake Lines
Discussion in 'The Hokey Ass Message Board' started by jaw22w, Jan 14, 2022.
  1. Happydaze
    Happydaze
    To straighten, firstly get it as reasonably close as you can by hand and then sandwich between two boards (say 1/2"ply) and roll it straight between the boards by moving one board over the other.
    Chris
  2. Beanscoot
    Beanscoot
    Here's what 70/30 copper nickel looks like after fifteen years holding up my shower curtain:
    Fabulous50's, egads and loudbang like this.
  3. RICH B
    RICH B
    Mike solved a cu-ni brake line problem he had. Cut up the NAPA lines, reused the flare nuts, same Eastwood tool; but with steel lines; no more leaks.
    stanlow69 likes this.
  4. phoneman
    phoneman
    from Missouri
    Most of the steel lines sticks at the part stores around here have that polyvinyl fluoride (PVF) coating. It makes them hard to deal with if cutting to length and re-flaring. Copper nickel is easier to work with than coated steel.
    golferforpar, egads and Cosmo49 like this.
  5. I used to use steel lines then I tried the copper/nickel several years ago and I can honestly say I will never use steel line again. I use copper/nickel for brake and fuel lines.
    I have even successfully created bubble flares using a double flare tool and copper/nickel line many times and have never had a leak ... try that with steel :)
  6. Marty Strode
    Marty Strode
    I hate that coated **** !
  7. alanp561
    alanp561
    " Besides looking cool polished I get a good upper body workout ". Pictures or it didn't happen!;)
    mad mikey and Bandit Billy like this.
  8. Only 20 States have inspections. So, rougthly 40/60
  9. 2OLD2FAST
    2OLD2FAST
    from illinois
    I have . worked for 6 years . Kid that bought it moved to S Carolina & I lost track of him & the car .
  10. Fortunateson
    Fortunateson
    To straighten I picked up a kind of tubing straightening tool at Pricess Auto, the original Harbor Freight, for under twenty bucks and it works well.
    Algoma56 likes this.
  11. Bandit Billy
    Bandit Billy
    I don't have one of me flaring brake tubing but here is one of me bending exhaust pipe. My wife, as you can see, is clearly impressed as there is no crimping in the bend without the use of a mandrel.
  12. Dino 64
    Dino 64
    from Virginia
    Used it for brake and fuel. Got compulsive and polished them too ! Nice stuff
    mad mikey and Driver50x like this.
  13. alanp561
    alanp561
    You're Steve Reeves? :cool: You've really held up well for your age and so has your wife.:confused: I thought at first she was your daughter;)
  14. Duke
    Duke
    Do you have a picture or what they call it? I can’t find it?
    Thanks
  15. Bandit Billy
    Bandit Billy
    I use one of these thingies that I got from Eastwood
  16. Beanscoot
    Beanscoot
    Too ***y for the Hamb, we had to airbrush out your ******.
  17. goldmountain
    goldmountain
    I've never had any problems flaring steel lines but my neighbor tells me that stainless lines are hard to do.
    72yenkonova and Bandit Billy like this.
  18. A Boner
    A Boner
    When you finally try it, you will understand!
  19. Bandit Billy
    Bandit Billy
    Hard to do? Yes. But nothing is stronger, and nothing looks better IMO than polished SS brake and fuel lines. “Easy” isn’t my top priority. :cool:
  20. ct1932ford
    ct1932ford
    I have tried it and do not like the look. Easy to work with but. JMO
    RICH B and 2OLD2FAST like this.
  21. brigrat
    brigrat
    from Wa.St.
    ^^^^^^^^^^Stainless is easy with the rite tools^^^^^^^^^^^^^^^
  22. Rand Man
    Rand Man
    I think the copper nickel is the best. I had trouble with stainless flares leaking. (Factory made. )
    mad mikey likes this.
  23. brigrat
    brigrat
    from Wa.St.
    I should have said stainless is easy when using the proper tools and proper AN fittings. Single 37 deg. flare, never had a leaker. Not the look for everyone but last forever!
  24. rockable
    rockable
    I have a tube straightener similar to the picture below. It works great on brake lines and fuel lines. Once it is straight, you can do a much better job of laying it out and bending it accurately.
    72yenkonova, loudbang and brigrat like this.
  25. SEAAIRE354
    SEAAIRE354
    As promised here’s a pic of the nicop with stainless covering. I still haven’t got to one of the projects that I used it in harsh environments though. @martystrode commented on having no problems using steel and I agree 100%. But I like it for the corrosive resistance properties. ED4AF54A-A995-47E5-805A-782CC099ABD9.jpeg
    Fabulous50's and loudbang like this.
  26. brigrat
    brigrat
    from Wa.St.
    If you're searching for the "covering" it's also called "Armour", brake line Armour!
    Bandit Billy likes this.
  27. Beanscoot
    Beanscoot
    Hey, they spelt "Armour" right!
  28. Bandit Billy
    Bandit Billy
    Buy extra. I recently used a few feet of it to protect the plastic oil line from my dune buggy's VW motor to the dash mounted gauge.
    brigrat likes this.
  29. 2OLD2FAST
    2OLD2FAST
    from illinois
    Spelt ? You mean spelled ? Spelt is a type of wheat ..
  30. mrspeedyt
    mrspeedyt
    ‘spelt’ may be the king’s english …
